Advice on a 355 GTS I found | Page 2 | FerrariChat
Discussion in '348/355' started by sgtpeper, May 23, 2020.
  1. phrogs
    phrogs F1 Veteran
    7,362
    Kzoo Michigan
    stop guessing on the cel you must pull codes so you know for sure.
    I have gutted cats and have no cel.
  2. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Easy stuff to work through except for the crank seal.
  3. sgtpeper
    sgtpeper Formula Junior
    May 4, 2004
    427
    Denver
    Jeff
    The codes were pulled - the PPI says CEL on for Catalyst left and right due to being below threshold central cat ECU failure due to the Capristo bypass valve.
    Crank seal is super minor he said. Not even dripping. He said no reason to do anything with that yet.
    Does that make sense?
  4. jjtjr
    jjtjr Formula Junior
    Aug 29, 2016
    763
    Vermont
    john truskowski
    Yes that does make sense. Often, seals will "seep" a very slight amount of oil, or it could be the grease that comes with a new seal melting and weeping out. If you were to inspect any 2 year old vehicle closely you would find at least 1 or 2 seals doing this. To me, a dripping seal is one that needs attention.
  5. sgtpeper
    May 4, 2004
    427
    Denver
    Jeff
    Does that CEL make sense? What's the best way to solve that?
  6. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    There is lots to learn on that and voluminous info on here about it. It may need new cats, possibly fixed with minicat extenders. Not a deal killer imo.
  7. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    The cat's... not as simple as "just unplug the battery for 2 minutes and it will reset". Run some searches, I have seen some interesting threads on that one with 355's. Solvable for certain yes, and not a deal beaker no exactly as John says but to be clear.... expect aggravation.
  8. sgtpeper
    May 4, 2004
    427
    Denver
    Jeff
    The seller will currently take 73k. Based on the info I've provided, good deal or bad deal?
  9. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Have you seen the car yet? I mean, in-person? No way I'd spend that kind of money sight-unseen on the car "with needs".
    Based on what you've said already, it sounds like an example of deferred maintenance to me.
  10. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Is that a virtual dealer? In other words, are you able to communicate with the actual owner/seller and verify it's location?
    Here's the VIN (from the BaT ad) for future reference - ZFFXR72A5V0107930
  11. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Times are tough, market is down, it is what it is, go in with lower offer.
  12. sgtpeper
    May 4, 2004
    427
    Denver
    Jeff
    Dealer hasn't seen the car. Seller lives in Germany now. Communication is through the broker who talks to the seller's realtor who then talks to the seller in Germany.
    The vin from BAT is off by a digit. The one I sent is correct.
  13. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Sounds really phishy to me. Can you repost the VIN, I didn't see it earlier.
    I didn't think it would be possible for BaT to misidentify the VIN.
  14. sgtpeper
    May 4, 2004
    427
    Denver
    Jeff
    ZFFXR42A5VO107930 is the actual vin. When I ran the one with 72 in it doesn't find anything.
    The odd thing is that in the BAT auction they show the carfax and it shows like 15 records. When you run it now, it shows 1. The records disappeared.
  15. sgtpeper
    May 4, 2004
    427
    Denver
    Jeff
    The vin with 42 is also shown in the image of the carfax on the old BAT auction. It's just a typo in the description section.
  16. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Thread Post------ ZFFXR42A5VO107930
    Wades-------------- ZFFXR72A5V0107930
  17. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Currently on eBay as well.
    https://www.ebay.com/itm/254608120991
    Still, I'd go and look at it first.
    Considering that the AutoCheck states only three owners it certainly has been around.
  18. sgtpeper
    May 4, 2004
    427
    Denver
    Jeff
    Figured out the carfax issue! The broker ran it with a O instead of an 0. Found all records on Cardax now.
  19. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Not sure how many 97, Red, 355 GTS, manual gb, with CD Apline stereos of the same model are out there, its the same car I think.
  20. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
  21. sgtpeper
    May 4, 2004
    427
    Denver
    Jeff
    Yea, I fixed the carfax. Also clean there and follows the 30 pages of records the car has as well.
  22. sgtpeper
    May 4, 2004
    427
    Denver
    Jeff
    He also said 73k is as low as they'll go or it's being shipped to him in Germany
  23. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Ahhh yes... the old creating urgency bit.
  24. texasnoiz
    texasnoiz Rookie
    Oct 7, 2018
    35
    Sugar Land
    k s
    All of this really depends on what you’re willing to put up with after you buy a 20+ year old car. If you dig it - go for it. Make sure you have a good shop and tech that will take care of issues that will arise. F360 F430 are less of a headache to deal with for these reasons... I would not buy unseen though...
  25. Natkingcolebasket69
    Natkingcolebasket69 F1 World Champ
    I had interest in this car as well but decided to pass
