458 - Advice needed Cat temp sensor acting up | FerrariChat
458 Advice needed Cat temp sensor acting up
Discussion in '458 Italia/488/F8' started by 1cerberus4u, May 11, 2019.
  1. 1cerberus4u
    1cerberus4u Karting
    172
    Bedford NH
    andy sanborn
    so I finally took my 458 out from winter storage and at first it was running really rough at idle and then I got a warning that the Cat temp sensor was out of range. Being the car wasn’t even warmed up I wasn’t concerned about it being plugged and over heating so I decided to drive it home the 30 miles to see if once the car warmed up, if it would trigger the cat sensor to behave.
    Well no luck, just a warning and bell ringing every few minutes all the way home....
    Any ideas on how to test or reset the sensor? Will cycling the battery reset it?
    Any advice is appreciated
  2. Golattus
    Golattus Karting
    227
    JN
    Disconnect the battery and follow startup procedure as per the manual.
    99% you will clear this.
  3. 1cerberus4u
    1cerberus4u Karting
    172
    Bedford NH
    andy sanborn
    Thanks Go!
    I'll try it this week
    Best
    Andy
  4. gobble
    gobble Formula 3
    Owner Regional Sponsor
    Jan 29, 2010
    1,647
    Milwaukee, WI
    Ferrarifobs.com
    I had a similar problem. I got that cat warning and an engine system control failure (or something like that). The diagnostics said misfire on cylinder 3. I swapped plugs between 3 and 4 and the misfire moved. New plugs and the car runs perfect.
    I bought a 2,400 miles car last fall and it sat all winter on 1/8 tank of fuel. The fuel could have been a couple years old for all I know. It must have fouled the cylinder 3 plug.
  5. 1cerberus4u
    1cerberus4u Karting
    172
    Bedford NH
    andy sanborn
    I reset the battery this am and just did start up and the car sounded fine and no code. I plan to go for a drive tomorrow and check it out
  6. Golattus
    Golattus Karting
    227
    JN
    75% of the errors can be cleaned up disconnecting the battery, that’s the reason why Ferrari removed the master switch...
