Adjusting the shifter - 1st is actually getting 3rd gear! | FerrariChat
Discussion in 'Mondial' started by Albert Penello, May 5, 2020.
  1. Albert Penello
    Albert Penello Karting
    Jul 21, 2019
    165
    Woodinviille, WA
    Albert J Penello, Jr.
    Hey folks
    As the Mondial project is getting near completion, was driving around yesterday with the family and noticed my car was sluggish off the line. I had felt the car was a little slow off the line and I can't believe it but my car is actually getting 3rd gear from the 1st gear gate. 1st has been VERY hard to get into after we did an adjustment to get second gear better so I assume that we spun some part of the shift rod in the wrong direction.
    I think having 1st gear would make the car a little more fun :)
    What's the process for adjusting the shifter to get proper 1st gear engagement? The service manual just talks about putting the car in 2nd and adjusting from there (which is what we did) but that's how I lost 1st.
    (preferably there is a way to do this without dropping the pan!)
    paulchua likes this.
  2. greatscott73
    greatscott73 Formula Junior
    Sep 1, 2017
    409
    Eastern Tennessee
    Howard Scott
    this might help...
  3. Steve Magnusson
    25,137
    Did you also replace the two silent-bloc bushings in the shift shaft assembly (or verify that they are OK-ish)? Items 28 here:
    https://www.ricambiamerica.com/car-diagrams/ferrari/v6-v8/mondial-group/mondial-qv/outside-gearbox-controls.html
    Slop, or weakness, in these will reduce the rotation transferred to the shift selection mechanism inside the gearbox when you move the shift lever over to the 1-R side.
  4. Albert Penello
    Jul 21, 2019
    165
    Woodinviille, WA
    When I did a physical inspection, both of those actually looked quite good. The shifter is pretty tight - I think what happened is that when we loosened the lockunuts to adjust the Up/Down adjustment, something when loose on the side/side.
  5. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    12,662
    San Carlos, CA
    Mitchell Le
    Replace the two silent blocks. It's a big job but … 35 years old cars have issues.
    To align it:
    Put the car gearbox in neutral
    Put the shifter in neutral by adjusting the turn buckle
    Lock down the shift rod bolt/nut at the gearbox under the car, while making sure that the bolt/nut direction is absolutely horizontal.
    Test all gears while engine is off. You should be able to shift into all gears with engine off.
