Additional Air Valve Connector | FerrariChat
Discussion in '308/328' started by craiggo, May 3, 2021.
  1. craiggo
    craiggo Formula Junior
    383
    Redwood City
    Craig
    I'm removing the Expansion Tank and can't seem to figure out how to remove this connector. Is it just a pull off or is there some type of clip. I don't want to break it! Appreciate any guidance. It's on a US spec '87 328.
    Thank you. Image Unavailable, Please Login
  2. thorn
    thorn F1 Rookie
    3,322
    Tallahassee, FL
    Remove the metal clip (I use a 90° angle pick), then slide the plastic part off.
  3. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    15,516
    Dumpster Fire #31
    SMG
    It should just pull off, but yeah they're a bugger and it's easier to pop the metal wire free. I think though that pressing into the wire across the long side it'll bow the sides enough to get it free. But that's a real pita depending on how the connector is placed.
  4. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    As stated they can be a little hard. For sure trying to pop out the metal wire spring with a pick is first choice. But after that I've had good luck rocking the connector to try to get one side of the spring off at a time rather than a straight pull away. If this is difficult, you can see the spring pop out a little when you rock it and can get a pick under it to keep it from re-seating.
    If it doesn't go well, these connectors are available from electronics and auto parts suppliers.
  5. Steve Magnusson
    25,125
    Didn't realize that they had changed the style of those connectors. Here's the other style that has the metal clip that gets pushed inward by a finger to release the connector housing:
    That newer style does look like a beyotch to pull the metal clip outward.
    BLACK HORSE likes this.
  6. Rifledriver
    34,035
    Austin TX
    You are showing the current style. The one in his photo is the old style.
  7. Steve Magnusson
    25,125
    Interesting -- would've thought that a 1987 328 would be the "later" as (I think ;)) I've seen the finger-style used on many early 1980s F models.
  8. craiggo
    383
    Redwood City
    Craig
    Worked like a champ! Thank you all for the advice. I didn't want this 30min job to turn into a 3-day project.
    Craig
  9. Rifledriver
    34,035
    Austin TX
    They have been the replacement for a long time. Switchover was late 80's sometime.
