360 - AC compressor | FerrariChat
360 AC compressor
Discussion in '360/430' started by 78bonanza, Nov 16, 2019.
  1. 78bonanza
    78bonanza Formula Junior
    Apr 1, 2018
    331
    Jim Cear
    Is there a good source for a rebuilt/replacement AC compressor ?
  2. Ghostdiver
    Ghostdiver Formula 3
    1,326
    Southeast Texas
    Wally Hollar
    I found this on the board here.
    8FK 351 102-001 HELLA Compressor air conditioning
    It's not the exact same as the OEM unit as it has a 6 groove pulley vs. the 5 groove but you can pull your clutch off and replace it or just put it on as is. Only difference I found is the Ferrari unit has manifold attached while this one does not so you must transfer it. Not a big deal. This also shipped full of oil.
  3. Rifledriver
    34,011
    Austin TX
    Send it to Austin Rebuilders in Texas or Ranshu with several locations. . Very fast turn around and its cheap.
    Sergio Tavares likes this.
  4. 78bonanza
    Apr 1, 2018
    331
    Jim Cear
  5. Continental AutoSports
    Sponsor
    Aug 22, 2006
    4,393
    Hinsdale, IL
    Bobby Williams / Parts Manager
    We've had some luck with https://www.polarbearinc.com/ rebuilding some compressors.
  6. gidleigh
    gidleigh Karting
    Nov 27, 2010
    141
    Coronado, Ca
    Just had mine rebuilt at Compressor International in LA. I live in the San Diego area. I sent it up on a Tuesday USPS priority. They got it the next day. 24hours later it was back in the post and I received it Thursday. I does not come with oil in it so you or your mechanic need to put 4 ounces of PAG 100 oil in it before installation.
  7. gidleigh
    gidleigh Karting
    Nov 27, 2010
    141
    Coronado, Ca
    I forgot to give the price. $235 + $20 shipping.
  8. Skidkid
    Skidkid F1 Veteran
    8,754
    Campbell, CA
    John Zornes
    I used these guys as well. They did a good job, or at least it kept running for many more years.
  9. Donny360
    Donny360 Rookie
    Aug 10, 2019
    1
    Don sirikhoth
    Found this company Compressor International it rebuild and return core for 350. company called Cool Air Parts brand new not rebuild direct fit 650 dollars for Ferrari 360 ac compressor
  10. Sergio Tavares
    Sergio Tavares Formula Junior
    Nov 15, 2018
    847
    Sergio Tavares
    Did the system have oil before or have you removed 100% of the old oil?
    Adding new to old just increases quantitia oil in system, not always good
