A procedure to reset ECU and TCU learning ?
Discussion in '612/599' started by bennzwel, Mar 26, 2022.
  1. bennzwel
    bennzwel Karting
    Nov 30, 2018
    111
    B N
    Hi all,
    Is there a procedure ( without SD3 ) that resets the ECU and TCU learning on 612?
    I know some other cars have procedures involving pressed accelerator pedal before start and etc. was curious if such a thing exists for 612 .
  2. brogenville
    brogenville Formula 3
    2,217
    Robin
    According to the workshop manual, cutting the battery supply resets the adaptive fuel trims on the engine ecu's:
    As for the TCU, there's nothing there you would want to reset per-se. The TCU needs to go through a specific learning procedure to measure the position of all the gears and to set the PIS.
    bay and bennzwel like this.
  3. bennzwel
    bennzwel Karting
    Nov 30, 2018
    111
    B N
    Is there a way to obtain a free copy of workshop manual ? I’m so passionate to learn about these cars and it’s a great reading material
  4. brogenville
    2,217
    Robin
    PM me. :)
  5. :GVIIRex
    :GVIIRex Karting
    59
    Long Beach
    Is the procedure on a 458 different?
  6. ViperGTS
    ViperGTS Karting
    Jan 24, 2023
    83
    Konrad A
    Question (related to the 599): If this procedure is not followed, will there be error codes thrown? I just had my battery disconnected so that I could change the fuel pumps. I did not follow this procedure and I have a couple of fuel trim errors. Could this be related? It seems silly that every time the battery is disconnected for service the the car must be left idling for 10 minutes. Just sayin....
