355 - a place to rebuild power steering pump | FerrariChat
355 a place to rebuild power steering pump
Discussion in '348/355' started by bellwilliam, Sep 1, 2021.
  1. bellwilliam
    bellwilliam Formula Junior
    Oct 25, 2014
    399
    looking for a shop to rebuild a F355 power steering pump.
    talked to AAE this morning. They said they've stopped F355 pump rebuild. Claiming some quality issue with some of the components. so AAE is a no go.
    thanks.
  2. phrogs
    phrogs F1 Veteran
    7,312
    Michigan
    what is AAE
  3. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,384
    San Carlos, CA
    Mitchell Le
    Buy a used one. There are no rebuild kits ...
  4. WATSON
    23,460
    WI
    Atlantic Automotive Enterprises
    ....to the OP, that sucks as they did a great job on mine 5 years ago. (although they sprayed it black so I needed to clean that off, which was my reason for popping in here)
  5. SeattleM5
    SeattleM5 Formula 3
    1,259
    Kirkland, Washington
    Ettore Palazzo
    View attachment 3198985 View attachment 3198986 View attachment 3198985 View attachment 3198986
    Rebuild kits are available and DIY rebuilds are feasible if you have any familiarity with replacing seals and such. The pump is a LUK Model VT65 2106326 (Ferrari part# 158114). The same pump was used on e30 era BMWs and BMW sells a rebuild kit with the following BMW part number: 32411133023. When I did my engine out a few years back I rebuilt mine without much difficulty. There was no issue with the pump but for fun I decided to rebuild all of the components including alternator, water pump, AC compressor, etc. while the engine was out.
    INRange, GTUnit, 308 GTB and 2 others like this.
  6. yelcab
    Nov 29, 2001
    13,384
    San Carlos, CA
    Mitchell Le
    Where were you when I was looking for the kit 10 years ago.
  7. spaghetti_jet
    spaghetti_jet Formula Junior
    Jan 5, 2005
    921
    Europa
    Bob
    Excellent post. Thank you for sharing.
    What did you do to your A/C compressor & which parts did you use?
    jimmym likes this.
  8. SeattleM5
    SeattleM5 Formula 3
    1,259
    Ettore Palazzo
    Took it completely apart, cleaned all components, rebuilt with new gaskets and oil. The AC compressor in the 5.2 cars is a Sanden SD7H15 7840F (Ferrari part$ 157355). This task is a bit more complex and I recommend doing some research before jumping into this one. There are a few special tools needed. I suggest starting with reviewing the Sanden SD Compressor Service guide: https://www.sanden.com/servicemanual.html.
  9. jimmym
    jimmym Formula 3
    Sep 30, 2008
    1,990
    Northeast U.S.
    Jim
    Nice work. Great post.
    GTUnit likes this.
  10. spaghetti_jet
    Jan 5, 2005
    921
    Europa
    Bob
    Very nice post. Thanks.
    GTUnit likes this.
  11. Clarence Cazimero
    Sep 17, 2019
    25
    New York
    Clarence Cazimero
    Weren’t there some bearings on the power steering pump to replace too?
  12. SeattleM5
    SeattleM5 Formula 3
    1,259
    Ettore Palazzo
    Qavion likes this.
  13. emac
    emac Formula Junior
    851
    upstate SC
    ernest
    If the parts are similar to BMW, this guy has a good reputation in the BMW community for rebuilding pumps and compressors. Who knows, he may want to expand his service to Fcars.
    https://www.jaysbmwparts.com/
  14. EFerrari34
    EFerrari34 Formula Junior
    535
    Dallas, Tx
    Timothy
    Do you know the BMW exact product number for the actual pump? Or what year & models look the same part? I'm trying to find the bmw vehicle that used the same power steering pump. Thanks
  15. Flynt
    Flynt Rookie
    Aug 23, 2013
    45
    E30 325iS pump part is 32411141207. Appears to be the same if you plug it into google image search, but no way to know without both in hand..
