A "not-so-expensive" brake upgrade for F355 | Page 9 | FerrariChat
Discussion in '348/355' started by eric355, Sep 18, 2009.
  1. F355Bob
    F355Bob Formula 3
    Kit has everything you need. Easy bolt on. I have cross-drilled which is fine for mostly street. They have the potential for cracking under heavy tracking. I have mine for 10 years with street and some track days with no cracking. For street it is a choice for looks. The Trophy calipers are more expensive but are lighter. Will fit with Challenge rims or stock
    Steve355F1 likes this.
  2. Steve355F1
    Steve355F1 F1 World Champ
    Aug 26, 2011
    17,152
    Adelaide, South Aust
    Steve
    Excellent, thank you.
    The pads? Fine for that purpose? Mainly street, very occasional track
  3. FLORIDAsnakeEyes
    FLORIDAsnakeEyes Formula 3
    1,154
    Sarasota, Florida
    OC
    Also I gave an extra set of the block adapter for the fronts, should anyone want them for $200. They are the cnc unobtainable adapters for the F355, big brake conversion.
    PM me if anyone wants them.
    Sent from my SM-G955U using Tapatalk
  4. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,013
    NE FL
    Ken
    #204 kenneyd, Aug 25, 2019
    Go for it then.
    All the information was in this post, it wasn't that difficult. You buy it Ferrari 550 rotors, Porsche 993tt calipers, and the adapter. That's it Bolt on and go
    It fits all my wheels challenge, stock, pg3.
    I used to get horrible Fade with the stock brakes, never had any issues with these at the track.
  5. F355Bob
    F355Bob Formula 3
    Don't know if this is crucial or not but Stoptech uses front and rear calipers with the correct piston size for the car application that works with the stock master cylinder. Maybe your Brembo caliper application has the same size pistons as Stopteck kit so it's a mute point? What size are the 550 rotors?
  6. jeffdavison
    jeffdavison F1 Rookie
    Jul 29, 2002
    2,544
    Suwanee Georgia
    Jeffrey Davison
    550 Girodoscs $1000 pr., 993TT calipers ( least expensive new) $1600 pr., Adapters $170 pr., SS brake lines $80 set. Total = $2850.
    JD
  7. vjlax18
    vjlax18 Formula Junior
    687
    Nottingham, MD
    I have a set of the 456 GTA/M rotors if anyone wants them for this kit. One never used and one mounted to mock up the brackets I had made. They are the 330mm rotors that are the same size as the 550, but are blanks and not cross drilled. $200
    ILLA NOIZ likes this.
  8. ILLA NOIZ
    ILLA NOIZ Karting
    Mar 28, 2015
    132
    Concord, North Carolina
    Drew
    I know this thread is old.... but can we assume a brake set for the 550 (complete) would bolt right up? Maybe just carriers for the Calipers.
  9. evo11
    evo11 Karting
    Sep 21, 2020
    188
    K
    Guys, is there any bolt on kit that uses oem ferrari parts?
  10. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Bolt on, not a chance. Conceptually if there was... would one think one would prefer to do this? Stoptech's bolt on though.
  11. evo11
    evo11 Karting
    Sep 21, 2020
    188
    K
    so porsche calipers and 550 discs and adapters....where I can order adapters?
  12. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    It all in the thread. Ohh and the Evo 8 was better.;)
  13. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,013
    NE FL
    Ken
    Ferrari 355 challenge brakes are bolt on. usually cost around $30k however
    Yassa likes this.
  14. judd10
    judd10 Formula Junior
    478
    Seattle, WA
    It really does look great and sounds like a good price. Just to confirm, however, one will also need to push the wheels out with wheel spacers for clearance ?
  15. vjlax18
    687
    Nottingham, MD
    I have the 550 rotors sitting on a shelf still if you need a set.
  16. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,013
    NE FL
    Ken
    spacers are NOT needed
  17. judd10
    478
    Seattle, WA
    ok, wasn't sure as in post 78, Johan says that the wheel spacers are needed to clear the rims. So they aren't?
  18. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,013
    NE FL
    Ken
    ILLA NOIZ, tres55, jimmym and 4 others like this.
  19. judd10
    478
    Seattle, WA
  20. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    SoCal LA/OC/New Mexico
    Tim Dee
  21. PhilB
    PhilB Formula 3
    Feb 17, 2004
    2,311
    Southern New Jersey Shore
    Phil
    Ken - what wheel bolts are you using?
  22. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,013
    NE FL
    Ken
    They are titanium bolts. I had them manufactured a few years back had to buy like 20 sets, I sold the rest, kept several sizes for me.
    swoshsteffo likes this.
  23. tres55
    tres55 F1 Rookie
    3,564
    Canada
    I have a set of titanium bolts for my 355 when it arrives.
    I think I bought them from someone off this site years ago.
    There's many companies out there now that produce them.
  24. GTUnit
    GTUnit Karting
    May 25, 2014
    143
    Socal
    Jack
    Brand New Brembo Bog Brake kit with floating rotors is 3400.
    I would prefer to drop another 600 and have the new, effortless, kit from Brembo.
  25. EVOeng
    EVOeng Karting
    Jul 1, 2011
    77
    London, England
    Design911 in the UK have copy versions of the 993TT 'Big Red' brake calipers - they're popular in the UK. Item 3604209301.
    I assume these are correct?
