"A knock from the suspension when turning left at low speeds is noted" | FerrariChat
Discussion in 'Mondial' started by sixcarbs, Mar 28, 2020.
  1. sixcarbs
    sixcarbs F1 World Champ
    10,623
    SF
    "A knock from the suspension when turning left at low speeds is noted."
    What would cause that in a T? Is that the CV joints I have read about in the past or something else?
  2. Cadillacbart
    Cadillacbart Formula Junior
    Nov 26, 2013
    436
    Denver, CO
    If turning on smooth surface and hearing knock, I would guess cv joint.
    If knocking with even small bump, I would guess CA bushings.
  3. Rifledriver
    37,310
    I have heard posi chattering so bad it sounded like a knock and posi noise is the worst at low speeds. May also be a sway bar bushing. Control arm bolts are supposed to be tightened at services. Almost never done and in our TR it will make a loud knock when a bushing rotates due to a bolt not being tight enough.
