430 - A friend w/an F430 has problems shifting into 4th..See Pics. | FerrariChat
430 A friend w/an F430 has problems shifting into 4th..See Pics.
Discussion in '360/430' started by Flea7, Feb 20, 2021.
  1. Flea7
    Flea7 Formula 3
    1,904
    PNW
    SKIM
    He explained that he had problems shifting into 4th. I was shocked when he sent me the pictures. I've never seen hydraulic oil in this condition. He said that the Ferrari dealership did a full maintenance recently. Looks like chocolate milk! LOL
    Is this dirty old oil or more serious underlying problems?
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,680
    Central NJ
    Dominick
    Maybe a result of mixing atf with chf fluid that someone else put in .. never saw something like that
    Or a crazy thought someone ( hoping not) put coolant in there thinking it was the coolant reservoir??
    Sent from my moto g(7) using Tapatalk
  3. Nicolas21
    Nicolas21 Formula Junior
    Jul 13, 2016
    665
    Near a nuclear powerplant
    Nicolas
    F1 pump problem?
  4. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,229
    Santa Clarita, CA
    That has to be a mixture of two different kinds of fluid, or really really old fluid. I’ve never seen atf or hydraulic fluid that color. If a Ferrari dealer just did a full service, I’d send them the pictures and ask what they did, or didn’t do. I’d be really upset with them.
    A F1 pump problem wouldn’t cause the fluid color to change like that.
  5. Jgivoo
    Jgivoo Formula Junior
    432
    New Jersey
    Even old fluid doesn't get this color. Agreed with all above that someone mixed two different fluids. I would send a sample out immediately to determine what it is. And would not drive this car until the entire system was flushed out and the correct fluid added.
  6. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    Is there enough fluid to get a sample , put in a small test tube and let it settle out to see what u get. Will show if water in it or if emulsified.
    Flea7 likes this.
  7. armedferret
    armedferret Formula 3
    Mar 24, 2018
    1,140
    Maryland
    Mark
    oh wow. that's shocking.
    definitely have your friend pull some fluid out with a syringe (10-20mL should be plenty) and then damn skippy I'd at least send the photos to the dealer, if not the whole car, and ask WTF they're doing over there...
    hopefully nothing serious resulted, and if so, the dealership eats the cost.
    Flea7 likes this.
  8. SoftwareDrone
    SoftwareDrone F1 Veteran
    Sponsor Owner Rossa Subscribed
    Jan 19, 2004
    7,540
    San Jose, California
    I have never heard of a heat exchanger failing on a 430, but it wouldn't hurt to check the color of the coolant in the overflow tank.
  9. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,680
    Central NJ
    Dominick
    Software drone .. although that has happened on 430s .this is issue is on f1 circuit which doesn't cross into the exchange circuits .
  10. Flea7
    Flea7 Formula 3
    1,904
    PNW
    SKIM
    I'll see if he cares enough to send a sample to Blackstone. I'm curious what the results would be.
  11. SoftwareDrone
    Jan 19, 2004
    7,540
    Okay thank you for the update. This is what I love about this site - you learn so much!
  12. 24000rpm
    24000rpm F1 Rookie
    that could be a lot of tiny air bubble in a perfect clear atf fluid. only if can see photos more clearly.
  13. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,229
    Santa Clarita, CA
    Flea, did your friend ever figure out what’s going on with the F1 fluid? I’m curious.
  14. Flea7
    Flea7 Formula 3
    1,904
    PNW
    SKIM
    He reached out to Ferrari SF and they gave him the usual response that a car dealer gives you. Didn't even offer to change it out. He guessing it old oil....he's getting it changed out.
  15. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,680
    Central NJ
    Dominick
    What was the usually response .. just curious
  16. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,310
    San Jose
    dc
    Come pay us money
    Flea7 likes this.
  17. Flea7
    Flea7 Formula 3
    1,904
    PNW
    SKIM
    To put it shortly....
    You're on your own sucker! We can change it but you have to pay. He even show the paperwork for the service.
  18. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,680
    Central NJ
    Dominick
  19. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,229
    Santa Clarita, CA
    Any update on this? What was wrong with the fluid? Did it all flush out easily?
