A/C Woes | Page 2 | FerrariChat
A/C Woes
Discussion in '365 GT4 2+2/400/412' started by SouthJersey400i, Aug 9, 2020.
  1. SouthJersey400i
    SouthJersey400i Formula 3
    Mar 14, 2007
    1,605
    Romulus, NY (Finger Lakes)
    Ken Battle
    As I placed order for the Teflon gaskets, I saw a listing for the complete Rotalock assembly (Compressor fitting, hose fitting and Shraeder valve). With this assembly they included the Teflon gasket and a green o-ring like the one I plan to use on the hose fitting. I feel better about using that o-ring and I'll have the Teflon gaskets for the compressor fitting in a few days. :)
  2. raemin
    raemin Formula 3
    Jan 16, 2007
    1,869
    Lyon (FR)
    R. Emin
    It's a bot of a mixed bag, some fittings are dudgeons, some are newer types with O-rings. I suspect 365 were dudgeon only whereas 412 is O ring only, but if your car is in between, chances are that it's a mix. On my (1981) car I've got O-rings next to the rota-locks, the dryer and evaporator but dudgeons on the condenser.
    Note that the green O-rings are for the new refrigerant, whereas black O-rings are for R12. Not sure if the green ones are backward compatible with the old Gas.
  3. SouthJersey400i
    Mar 14, 2007
    1,605
    Ken Battle
    Making progress (my old body only allows an hour or so per day in the garage). Going back to the early parts of this thread, I was convince that nasty desiccant muck had blocked the two evaporator valves which would explain my symptoms. I have now removed both valves. They are clean. I blew thru them at room temp, at 50 F in the garage and submersed the small tight coil in ice water. In all cases the valves were open and easily blew through. I thought the ice water would have closed the valves. I put the valves in my freezer and then the valves shut. Conclusion, no crud in valve, it does stroke open and closed. Calibration may be a bit to the cold side before throttling / closing. I plan to blow through hoses from dryer to each valve connection but I see no reason to go for the solvent cleaning treatment. I have replacement valves and will use them.
    Comments please.
    Ken
  4. SouthJersey400i
    Mar 14, 2007
    1,605
    Ken Battle
    Note on o-rings. The green ones were shown to be good for R134a and R12. I am switching to DuraCool (propane) which is kind to most all o-rings.
    Ken
  5. raemin
    raemin Formula 3
    Jan 16, 2007
    1,869
    Lyon (FR)
    R. Emin
    Freezing evaporator means the the refrigerant flow did not stop despite the numerous safety mechanism meant to prevent this. Evaporator valves were the more obvious culprit, here are the few other suspects that come to mind:
    - Pressure switch clogged by desiccant
    - Valve sensing bulbs not properly installed
    - Thermo switch(s) (snowflake button) out of specs
    You would have to analyse the potential impact of dual AC valve stuck or clogged by desiccant (I have single AC)
    We can speculate on a few scenarios:
    1/ wrongly located valve sensing bubs and failed pressure switch.
    2/ wrongly located valve sensing bubs and bad snowflake button.
    3/ ???
    All in all, as long as you put a new dryer (i.e pressure switch) and new valves (with proper sensing bulb installation), your AC should stop when the refrigerant becomes liquid (regardless of the snowflake and dual AC valve). So you could give it a try if you are confident these components (dryer and valves) are properly operating.
  6. SouthJersey400i
    Mar 14, 2007
    1,605
    Ken Battle
    Raemin
    Thanks again for input. My evaporator coil has NOT been freezing; I resolved that a few years ago. My problem was no or little cooling at all. Air temp. at vent only dropped 1-2 C below ambient with compressor pressures in spec.
    I still need to check the two solenoid valves. I will test blow thru from evaporator back to compressor suction. Relays and solenoids are still suspect. I sure hope it is not the solenoids! Access to them is terrible even with battery out, and I'm not sure if there is a generic part for them.
    Your photos will be helping get the things in correct place around evaporator; so far my parts all look in right place.
    One step at a time.
    Ken
  7. raemin
    raemin Formula 3
    Jan 16, 2007
    1,869
    Lyon (FR)
    R. Emin
    Maybe you should (temporarily) short the thermo-switch and let the expansion valve in charge of stopping the AC when maximum cooling has been reached. At least this removes one point of failure.
  8. SouthJersey400i
    Mar 14, 2007
    1,605
    Ken Battle
    Note the two solenoid valves are on the return vapor line from the evaporators not on the liquid lines. I originally thought they were on liquid to evaporators but not that way on schematic.
  9. SouthJersey400i
    Mar 14, 2007
    1,605
    Ken Battle
    I tested the two solenoid valves under various conditions from key off to simulating AC compressor and motor running and thermostat switches on and off, all together about 5 tests for each solenoid. In all cases air would blow thru the solenoids indicating they are open all the time. Since they are energize to close, they are not getting power to close. Next I will checking fuses and relays. Previously I could get the solenoids to "stroke" by applying 12 V direct to the solenoids. I have no intention to replace the solenoids.
    In the worst case that I cannot resolve getting the solenoids to close via the thermostat signal, I will still be able to run the AC and it should cool, maybe freeze if the new evaporator valves do not restrict the cooling enough.
    Ken
  10. raemin
    raemin Formula 3
    Jan 16, 2007
    1,869
    Lyon (FR)
    R. Emin
    Have you checked the thermoswitch (snowflake) for continuity? They are supposed to keep the circuit closed until evaporators do reach the desired (freezing) temp.
  11. SouthJersey400i
    Mar 14, 2007
    1,605
    Ken Battle
    I will check this by checking relays. If relays do not switch I will go back to the snowflake. This weekend.task.
  12. SouthJersey400i
    Mar 14, 2007
    1,605
    Ken Battle
    Well, I seem to have found the problem with the Anti-frost solenoids, but not sure what to do about it. Using a voltmeter and motor not running, I followed the manual procedure to test the system. I have Drier Pressure Switch jumped to simulate pressure is okay and I have the oil pressure switch disconnected to simulate motor running. The three relays are all switching correctly: Common relay (X) pulls in with key on. Front Relay (V) and Rear Relay (W) correctly respond with their respective fan switches on and the snowflake switches. Lower setting on snowflake and relay gives power output to solenoid valve to stop Freon flow; raise snowflake setting to call for more cooling and relay shuts power to solenoid. Remember the solenoid valves are Energize to Close. Here's my problem. The output from the relay to solenoid (white and red wire to front and white and blue wire to rear) is only 4.5 V! The common relay has 12 V. So where am I losing the voltage? Do the solenoids pull so much current to draw down the voltage? Am I losing the voltage in the relays and wiring? Note that the Common and Rear Relays are new purple ones. I see no need to change the front one as results match the rear system.
    Note that I previously tested the solenoids with the battery removed. Using same test procedure the front solenoid made a very wimpy click sometimes and the rear not at all. I fed 12 V direct to solenoids and they gave a nice sharp click to open and close. So I believe solenoids will be OK if I can feed them 12 V.
    Okay, any ideas? Can anyone measure their voltage from relay to solenoids? This can be done at the relay panel; no need to remove battery.
    Now that I have established I have an electrical issue (or bad solenoids) I plan to start closing up the Freon system with the new evaporator valves, drier and lots of new o-rings.
    Ken
  13. raemin
    raemin Formula 3
    Jan 16, 2007
    1,869
    Lyon (FR)
    R. Emin
    You've got a gen2, maybe you should consider the sort of upgrade you did for the fuel pump relays?
    Before any major surgery I would try to swap relays. See https://www.ferrarichat.com/forum/threads/some-random-blathering-on-relays.463273/#post-143424524 : new relays do somehow require a break-in period and do have a significantly higher resistance than older ones.
    Also bear in mind that the relay coil does require 200ma in order to properly operate. Maybe the snowflake button is not delivering enough current to the relays?
  14. SouthJersey400i
    Mar 14, 2007
    1,605
    Ken Battle
    I will take relay's out and stroke them at battery and measure resistance on the power contacts (to solenoid). I can switch around relays or even go to some older ones that I have kept. Snowflake seems to stroke the relay coil okay.
    I read the link but I only have a fairly good "multi-meter". I think it can measure ohms down to a pretty low level. More tomorrow.
  15. SouthJersey400i
    Mar 14, 2007
    1,605
    Ken Battle
    I could test a relay setup like the fuel pumps but a solenoid should not require such a drastic measure.
  16. SouthJersey400i
    Mar 14, 2007
    1,605
    Ken Battle
    After doing a bit of a logic check I changed paths. Since both A/F relays had identical output voltage (4.65V) and one relay is old type and one new type, clearly the relays are NOT the problem and problem was "upstream". The common relay with neither A/F relay activated had only 5.5V, so current to solenoids is not the problem. I delved into the wiring diagram to follow the power supply to these relays. After seeing what all is powered in this one circuit I am surprised there is any voltage left at all! This circuit powers the RH cooling fan (but I have done my fuel pump trick on the three front fans), the two AC fans and the compressor clutch. So I followed the voltage by testing fuses (2) with the AC fan switch on. Voltage losses was minimal 12.3 to 11.9V, and virtually the same with one of the A/F relays activated. Then I measured at the compressor pressure switch and got only 6.8-7V,I checked the feed wire as it connects to fuse board and it was 8.3V. So the clutch load is dropping the voltage 1.5V. The feed to A/F relays is from the clutch wire and since it feeds the common relay at 6.8V there is minimal loss on the return wire to the circuit board. Yes, after all the wiggling of wires and contacts the voltage to the A/F relays is now up about 1V from this morning. Conclusion, clutch is pulling too many amps or wire is undersized in the design. ?? I will recheck all these voltages after plumbing is all assembled. I may freshen up some of the contacts on the circuit board. Clearly there are some voltage losses in the circuit board too, lowering feed to clutch from 12 down to 8.3. I replaced the one fan relay the main power feeds thru but this made no difference.
    raemin likes this.
  17. raemin
    raemin Formula 3
    Jan 16, 2007
    1,869
    Lyon (FR)
    R. Emin
    That's really interesting, as this would also explain why the AC blower is lacking juice on single AC cars: the rotary speed switch feeds both clutch and blower together. Time to add some relays on mine...
  18. SouthJersey400i
    Mar 14, 2007
    1,605
    Ken Battle
    One relay right at the Drier pressure switch would do the trick. Feeding a strong 12V to the clutch would supply 12V back to the fans and relays for the dual air system. I'll wait until I have a system that cools (too much).
  19. raemin
    raemin Formula 3
    Jan 16, 2007
    1,869
    Lyon (FR)
    R. Emin
    My car is bullet proof against such a failure : 206cc compressor, single evaporator and R134a ...
  20. SouthJersey400i
    Mar 14, 2007
    1,605
    Ken Battle
    All components installed and all hoses and fittings snugged up. Vacuum drying and vacuum leak test this weekend.
    Ken
  21. SouthJersey400i
    Mar 14, 2007
    1,605
    Ken Battle
    The first can of Dura Cool has been charged plus a can of Dura Dry to capture any moisture left after vacuuming system. Ran compressor for a few minutes to charge the Dura Dry; the Dura Cool went in without the compressor running. This fluid, propane, is charged with can inverted so liquid is fed but flashes into the system. With local weather only in the 40's no way to determine cooling yet. According to Dura Cool instructions 2 more cans are required but they say this may vary and not to exceed normal pressure limits. Pressure is 2.5 Barg on Lo and Hi side with system static. I will leave for 2 days to see if it is holding pressure. It held vacuum for 2+ days.
    Il Tifoso and raemin like this.
  22. SouthJersey400i
    Mar 14, 2007
    1,605
    Ken Battle
    Second can of Duracool charged. It's holding pressure, so no apparent leaks. :) It's now too cold to do further testing; hoping for a warmer day.
    Ken
    Il Tifoso likes this.
