A/C schrader valve size? | FerrariChat
Discussion in '308/328' started by Carbuilder, Jul 2, 2013.
  1. Carbuilder
    Carbuilder Formula Junior
    Aug 18, 2012
    550
    Bolton, ON
    Rick
    I have been playing around with the A/C system in my 328, trying to get it working a little better. It was converted to 134a some time ago, and I "reconverted" it to Duracool. It had the quick connect adaptors on it, the kind that take the original schrader valve core out of the fittings on the compressor, and put them in the adaptors. I took the quick connectors off and put the schrader valves back into the original threaded fittings on the compressor. I think they are leaking and when I tried to get new ones I ran into "what car are they for", "Ferrari?, no we don't list that". Is there another car that uses the same size that I can reference, or is there a particular size to ask for? All I really need are the small valve cores, but I'll buy new quick connect adaptors if I have to. Just trying to get rid of one possible leak.
    Rick
  2. pippo
    pippo Formula 3
    Sep 25, 2005
    1,913
    FL
    pippopotemus
    you say you think they are leaking. How do you know for sure? Did you do the simple soap bubble test? If not, thats the first thing you gotta do. Even with a low charge, you should get bubbles.
    many times, you can tighten them down just a tad more. Then test again with soap. let us know, Rick.
  3. V.W. Porto
    V.W. Porto Karting
    Nov 10, 2003
    52
    San Diego
    Vincent W. Porto
    Hi Rick,
    The valve cores for our 308/328s are a very common, 'standard' size. Try Napa auto parts, p/n 209578. Another brand is FJC (p/n 2672). Most auto parts places should have them, just don't use the ones for tires as their seals aren't meant for refrigerants. You can also get these cheap online. HVAC Tools, HVACR Tools, Refrigeration Tools and Sheet Metal Tools has a 6-pack (with nice teflon seals), (p/n C&D Valve CD4460-6). Put a drop of refrigerant oil on them (or Nylog if you have it), tighten to 'just snug', and you're good to go.
    There are also two "Rotoloc" nylon sealing rings, one between each of the fittings and compressor that could leak. Napa has these for about a buck each (p/n 207165). Too cheap not to replace during a service.
    The original compressor (Aspira/York type) was used in thousands of 1960's-1980 Fords and is still used in large trucks, so unless you have a different (e.g., Sanden) compressor these should fit the original fittings just fine.
    Good luck!
    Ciao,
    Vincent
    P.S. If you don't already have one, get a valve core removal tool. They're really cheap and, unlike needle-nose pliers, they won't nick the core openings.
  4. Carbuilder
    Aug 18, 2012
    550
    Bolton, ON
    Rick
    Thank you for the info. It is usually easier to go in with a part number than convince someone that your Ferrari really does use standard parts here and there.
    Briefly, here is what I've been up to. The system didn't seem to be cooling as well as I thought it should. I read that Duracool works much better than the 134a that was in it; Duracool is available in a lot of stores in Ontario. I emptied the system out and put in the Duracool. Somehow I ended up with it overcharged (even allowing for the correction between Duracool and 134a). At this point I decided to do a better job of it. I bought a used set of gauges and hoses, and converted my compressor to a vacuum pump -- very easy, pulled off the air filters and made a "Y" hose with a bunch of fittings to attach to the A/C hose. Drew a vacuum in the system. It was loosing about 2" Hg in an hour and a half (vacuum pump off at this point). Used the compressor to pump up the system (with air) to try and find the leak. Couldn't find any leak. Vacuumed the system again and filled it up with Duracool. Overnight it lost a fair bit of refrigerant. I realized at that point that when I had it pumped up and was checking for leaks I still had the A/C hoses and gauges hooked up, so I wasn't checking the schrader valves for leakage. I decided I might as well replace them and fill it up again.
    Since I couldn't find new valves, I took the old ones out, cleaned them with brake cleaner, dried them, and lubed them with mineral oil. I put them back in, vacuumed the system again, and filled it up (realizing at this point that I should have originally bought a case of Duracool!). The only caps I had to close off the fittings were plastic ones, but I put thread sealant on them; figured it couldn't hurt.
    So that's where it stands now. I'll see over the next few days how it goes. I'll check for leakage at the schrader valve area with water/soap.
    Rick
  5. ClydeM
    ClydeM F1 World Champ
    11,600
    Wayne, NJ
    Clyde E. McMurdy
    what pressures were you looking for on the gauges when refilling the system?
  6. pippo
    pippo Formula 3
    Sep 25, 2005
    1,913
    FL
    pippopotemus
    Youre doing much good work/care, but note- unless those guages are of extremely high quality, that 2 " Hg over an houur + could be due to guage leakage, and not the system. Just beware......
    good luck, Man.
  7. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,825
    Mike 996
    Thats a LOT of vacuum (leakage) to lose in an hour and a half. So you need to find the leak(s).
    As far as charging...the accurate way to charge is by weight so you have to totally evacuate the system and then install the proper weight of refrigerant. That weight is listed in the owners manual but, of course, you have to adjust the weight for the refrigerant used vs the original R12. The gauges will not help you at all for that particular purpose. OK...they are not USELESS for that but they will not tell you much because system pressure varies based on temperature. So a correct charge that produces X psi on a 70 degree day will produce considerably higher pressure on a 90 degree day. Static pressure will tell you if there is enough refrigerant to activate the low pressure switch so the compressor will run but it won't tell you if there is too little or too much refrigerant for proper cooling.
    How much vacuum was your modified compressor pulling? For best results, it needs to be more than 29.95" and it should hold that for at least an hour (though most shops will not actually hold it that long) and it needs to be pulled with a proper pump for that job. The fresh refrigerant oil in a vacuum pump (as opposed to the old oil in your system) is an important part of filtering and ensuring the removal of all moisture. The oil in the vac pump is not JUST there to lubricate the pump. Vac pump oil should be changed quite regularly for that reason.
    Some would point out that Duracool (propane) is less subject to problems with moisture and therefore pulling/holding a high vacuum to purge moisture is less important than it is with R12/134. This is true but the vacuum is still important to ensure removal of all the old refrigerant and for leak-checking. I wouldn't argue with someone who said you don't need as much but neither would I change what I have been doing and use reduced vacuum.
  8. Carbuilder
    Aug 18, 2012
    550
    Bolton, ON
    Rick
    I really don't know how to find the leak, if I have one. I suppose a dye and ultraviolet light. I did try the soap bubble test, but really just the fittings at the compressor and the receiver-drier. The A/C did work when I bought the car, and it was around 2 months before I started fooling with it, so it did seem to hold the charge. Maybe I don't have a leak, as was mentioned, it could have been the gauges or hoses (wishful thinking?).
    The Duracool does go by weight , not pressure. The correct amount should be just under 2 full cans. Two cans is 12 oz, which is the equivalent of 38 oz of R12; the system should take 2.2 lbs of R12, which is 35 oz. The strange thing is that it took almost 3 cans until the bubbles just stopped on the sight glass (this is the other thing that Duracool says, there should be no bubbles).
    I put in the first 2 cans and drove the car around a bit and the A/C wasn't working well. I left it overnight. At this point the gauges were both reading 90 psi, engine not running. With the engine running the pressures were around 40 & 170. When I topped the system up with the last can, until the bubbles just stopped, the pressures were 43 & 203 with the ambient temp around 23C, 74F.
    Some additional info. The condenser does have some bent fins and some crap on the front of it. I tried blowing it out from the back-side but didn't really feel much/any air blowing out the front. Maybe it is partially blocked (on the air side) or I just wasn't blowing the air in through the louvred plate in the wheel-well. I'll do some dismantling on the weekend and make sure it is clean.
    The compressor/vacuum pump pulls a vacuum very close to 30" Hg. It isn't possible with a gauge to see if it is 29.5 or 29.9+.
    I'm posting quite a bit of detail here since that's what I like to see when doing a search for info. I haven't driven the car with the system properly topped up now so I don't know if it is going to work well and/or how long.
    Rick
  9. Carbuilder
    Aug 18, 2012
    550
    Bolton, ON
    Rick
    I may be nit-picking here, but:
    That isn't possible no matter what vacuum pump you are using.
    Rick
  10. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,825
    Mike 996
    Well, your two cans initially are about right and should have cooled reasonably well...I can't explain that.
    When I first switched to duracoo l(plus new drier and exp valve) I had exactly the same problem - I overcharged it and the system didn't cool well at all. After figuring out the problem, I dumped the charge and re did the entire process (vacuum/recharge), this time with 2 cans of Duracool. Cooling was dramatically better. Then I slowly bled off some of the charge, watching the ac vent temperature with the ac on max and the engine at 2000RPM. It dropped slightly as I bled off, showing that the 2 cans had overcharged it. When it stopped dropping, I quit bleeding off Duracool. On a 90 degree day at 2000 RPM I was showing approx 170/35 PSI. The system worked pretty darned well for a 3x8 Ferrari for several years though this year I developed a system leak that I have yet to chase down. I suspect the oem original hoses have permeated.
    There is as much art as science involved in this stuff..
    Did you install a new expansion valve and drier? They should be considered a normal part of the recharge job though your static/high/low gauge pressure indicates the exp valve is working.
    One thing I did (there are posts of it here from a few years ago) that helped was to I remove the louvered panel from the rear of the condenser. I also straightened some bent fins and made sure the entire condenser was clean. I replaced the louvered panel with some heavy gauge but large-opening screen wire. This made a noticeable improvement in cooling, especially when moving slowly. There is very little airflow through the condenser at low speed with the fan running and the panel in place compared to the flow with the panel removed.
    I will not say that I ever got the ac to be better than what I'd call "fair," but it was good enough to be reasonably comfortable in the car at cruise speed in temps up to the low 90's. That being said, I like the cockpit to be in the low 70's and on a day in the 90's with the sun full on the dash, the ac could not keep it down to that level. Around 80 was as good as it could do in those conditions. Vent temps were low. The problem was that the evaporator was just pushing enough cold air into the cabin. If the sun was not full on the dash, regardless of outside temp, the cockpit was comfortable to me.
  11. Carbuilder
    Aug 18, 2012
    550
    Bolton, ON
    Rick
    Thanks for your help and suggestions Mike. When searching for info I did find and read all of your older posts on your A/C work.
    No, I didn't replace any parts. I thought this would be a quick-and-dirty fix for now.
    Did you find that with the correct amount of Duracool there were no bubbles in the sight glass?
    I did read your info on replacing the louvered condenser panel and it does seem worth looking into. I'll take the panel off to clean out the condenser and see about improving the airflow through it. I assume the fan kicks on fairly soon after starting the A/C. I know of some people with other cars that wire the condenser fan to run all the time the A/C is on to improve performance. Would there be any gain in this?
    I had an '87 Porsche 911 a few years back and the A/C, when working right up to spec, really didn't cool well at all. I'm not after an ice-cold car, just something reasonable.
    Rick
  12. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,825
    Mike 996
    Hi Rick,
    My replacement drier did not have a sight glass but everything I have been told and read re this is that a sight glass is only useful with R12 - that only R12 has a correct charge when the glass just clears of bubbles. Anything else - 134/propane derivatives, etc, will have bubbles at the glass with a correct charge and therefore sight glasses are no longer useful. That's why many modern car ac systems do not have sight glasses at all and modern automated ac charging systems function totally by weight. Years ago, R12 systems were recharged by simply adding R12 until the sight glass cleared. Life was simpler then! :)
    The comment that your Duracool guy said - charge until the glass is clear - is the first time I have ever heard such a recommendation for charging with anything other than R12. When I contacted Duracool after I overcharged, the guy I talked to said to charge it strictly by weight (converting from the R12 weight to the appropriate Duracool weight.
    I have no idea why Duracool would make such a recommendation; clearly, it doesn't work that way in real life. I overcharged mine with DC the first time by looking for a pressure reading as opposed to weight. Duracool ends up with slightly lower pressure readings than R12 and FAR lower than 134 with the system cooling at best efficiency.
    Good Luck! I'll be away from where my 328 is located for several months so I won't be able to do any work on my leakage issue until September...
  13. Carbuilder
    Aug 18, 2012
    550
    Bolton, ON
    Rick
    I thought I had read about eliminating bubbles with Duracool, but can't find it now so maybe I was wrong. Looking at your pressures and mine maybe I am overcharged again.
    I had read about "subcooling" a few times but didn't know anything about it. Doing some quick research it might be good to try and measure/calculate it. I did find some charts and graphs with Duracool info so maybe I have what I need to do that.
    When I was measuring the vent temp the first time I charged the system (overcharged it) the vent temp was not consistent. I think the compressor was cycling on and off and the vent temp was changing so it was hard to know exactly what it was.
    I think the first order of business is to clean the condenser to make sure it is OK, then maybe do some measurements of temps and pressures and see what I find. Would an infrared thermometer measuring the metal pipe temperature near the drier work?
    This is a good learning experience. A/C systems are one of the few things on a car I've never worked on until now.
  14. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,825
    Mike 996
    " A/C systems are one of the few things on a car I've never worked on until now."
    I can identify with that! Other than adding some R12 in the "old days" I knew nothing about ac and didn't WANT to know anything about it. But two trips to shops that were allegedly experts, one of them a Ferrari specialist, where they succeeded twice in making the ac work WORSE, convinced me I needed to learn to do it. So my 328 became my "learning experience." Now I have all sorts of "friends" who want me to work on their ac!
    "Would an infrared thermometer measuring the metal pipe temperature near the drier work?"
    Maybe, but I don't know if that would give you an accurate measurement of what you need to measure. The standard method still seems to be a thermometer in the center vent.
    Make sure when you are testing that the windows are fully open and the settings are for max cool. If you don't open the windows, the interior could cool down enough to cause the compressor to cycle off, thus raising the vent temps until it cycles back on, lowering them again. I had both DOORS wide open to ensure there was no way for the interior to cool and shut off the compressor! :)
  15. BigTex
    79,321
    Houston, Texas
    Bubba
    Our 308s use a York similar to that on the Porsche 911, to answer one of your simpler questions...:D :D
  16. Carbuilder
    Aug 18, 2012
    550
    Bolton, ON
    Rick
    Yes, but I'm pretty sure my 328 uses a Sanden.
  17. NW328GTS
    NW328GTS Formula 3
    Nov 16, 2009
    2,191
    Washington
    Hal
    The only way to accurately fill a AC system is using an accurate temperature probe and a pressure gauge to measure the temperature and pressure of the superheated refrigerant entering the compressor, the temperature of the air at the condenser and evaporator and then matching the numbers to a chart for the refrigerant and determining the degrees of superheat of the vapor going into the compressor.
    The original design of the system took a lot of stuff into account and they determine where to put the sight glass so that on a normal temp day the fluid going going past the glass is a subcooled liquid. Changing refrigerant and/or the system layout or volume throws that location off and you cant use it to determine charge levels.
    Look up superheat and subcool on the internet to find the right charts and how a system operates. For propane or Duracool you need to find a chart for R-290, you could use R22 chart though as the numbers are pretty close.
    With a low side pressure gauge and a temp probe clamped to the inlet line to the pump and a thermometer for air readings you can determine charge levels and get the system efficiency as its optimum levels.
    Using sight glasses or just a gauge set without superheat charts and temps... is just a guess. For a standard automotive system, the guesses can be pretty good... but its still only a guesstimate. When you swap refrigerants or change component sizes or capacities... the accuracy goes down fast.
    Learn about subcooled liquids and superheated vapor and you too can get your AC running as good as it can with the parts ya got.
  18. Carbuilder
    Aug 18, 2012
    550
    Bolton, ON
    Rick
    I found the saturation table for Duracool (very close to R12 above 85 psi or 80F), so working out the superheat and subcooling can be done. The problem is, what should it be for this car? It is fine to know what it is, but that will only help in general terms without knowing what it should be.
