A/C leak detection question | FerrariChat
Discussion in 'Technical Q&A' started by eyeman1234, Nov 14, 2009.
  1. eyeman1234
    eyeman1234 Formula 3
    Dec 25, 2006
    1,881
    Boca Raton, FL
    Is it reasonable to switch from R12 to R134 for a few days only and use dye to find a hidden A/C leak that persists after the replacement of a compressor (York) in a '86 328 GTS?
  2. Dodici Cilindri
    Dodici Cilindri Formula Junior
    Feb 21, 2006
    548
    Great Plains
    Why would you want to switch back? R12 isn't getting any easier or cheaper to find. Just make the change to 134A and be done with it.
  3. sowest
    sowest Formula Junior
    Aug 18, 2006
    899
    A good electronic leak detector will work with either R12 or 134a and it should be able to find even the smallest leak. It is a matter of choice, but I still keep R12 cars on R12 if possible. I have two reclaimer machines and I use the one with the re-cycled R12 to leak check systems. When the system is "tight" and working, I evacuate and re-charge with "virgin" freon.
    So far, I have not had trouble getting R12, but to be sure, it is more expensive. Still to charge a single car it is about $70 to $90, which isn't all that bad.
    The advice in the post above is good. If you do the work to change over, it it is hard to make a case for changing back. I don't think that the system performance difference is all that great, although I have not done any meaningful testing.
  4. tazandjan
    39,007
    R134a is a less efficient refrigerant than R12 (Freon), so unless you intend to change some of your components to higher capacity, more efficient modern ones designed to work with R134, you are better off to stick with Freon. Most shops have the equipment to work with Freon without leaking fluorocarbons, so it is not a big deal one way or the other.
    Taz
    Terry Phillips
  5. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    The O-Rings for R-12 are not compatible with R-134a systems and the labor associated with changing all the O-rings over to an R-134a system is one of the biggest contributors to cost of converting a system.
    If you need a brand new, York A/C compressor that is compatible with R-12, R-134a, R-22, etc I have an extra one left over from a dual project for $348 plus s&h. Manufacture date of June 2009, never mounted, only removed from the box for inspection and has a 40% higher cfm than the original yet has the same universal mount.
  6. 330gt
    330gt Formula 3
    Nov 12, 2004
    2,074
    Seattle, WA
    Kerry Chesbro
    #6 330gt, Nov 16, 2009
    I had a leak in my 330 and the system was completely empty. The A/C guy just released the R12 that was in his hoses (an ounce or so) that connected to the gauges. That was sufficient for his sniffer to find the leak. No need for a full load with leak detection dye. Just find a good A/C tech.
  7. eyeman1234
    Dec 25, 2006
    1,881
    Boca Raton, FL
    Fortuitously a good home A/C tech. working at my house today used his sniffer to find a significant leak at the site of the new compressor installed one week ago. This is why I had no cold air hours after the replacement was completed. Now to find the exact location/cause!
  8. sowest
    Aug 18, 2006
    899
    Good news! Glad to hear that you are "getting warmer" so that you will soon be getting cooler. An electronic leak detector should have a "lock out" feature that will reject readings less than or equal to the previous high reading. This allows one to home in on a leak even in an area with a background concentration of freon.
  9. eyeman1234
    Dec 25, 2006
    1,881
    Boca Raton, FL
    How would you recommend narrowing down the EXACT location of a major Freon (R12) leak in the area of a newly installed compressor on a 328? It leaked out in one half day after the installation! Trying to avoid filling with Freon and dye- just to have it escape! Will the "lock out" feature of an electronic device enable zeroing in on seal vs. valve etc.?
  10. 330gt
    330gt Formula 3
    Nov 12, 2004
    2,074
    Seattle, WA
    Kerry Chesbro
    I would just take the compressor back to where you bought it for a replacement. You can also ask for the cost of the lost R12, but don't hold your breath.
  11. PAP 348
    Dec 10, 2005
    100,199
    Mount Isa, Australia
    Pap
    A few questions mate...
    Did you fit the compressor yourself? :):)
    WHY, did you replace the compressor in the first place? :):)
    Just curious. :):)
  12. eyeman1234
    Dec 25, 2006
    1,881
    Boca Raton, FL
    A mechanic changed the compressor for me with a new unit b/c it was leaking. Now he wants to perform a quick check for the exact leak site (by the new compressor) with dye and R134. Logical?
  13. PAP 348
    Dec 10, 2005
    100,199
    Pap
    Cool man. :):)
    Sounds like he may have pinched an oring when putting the a/c hoses onto the new compressor? :):)
    If the leak is THAT big, then it should be able to be found using the sniffer test. :):)
    Apparently a/c systems that leak overnight are HUGE leaks in the a/c world. :p:p
    Either uses the sniff test or the dye, let him do his thing. I hope HE is paying for the gas. ;);)
    Does this guy know what he is doing? :p:p
    He can use just bottle pressure (little gas used) of R12 or R134A to look for leaks with the sniffer or the dye. If he has no luck, then charge the system up to full pressure to look for the leak. Then, when you find the leak have him recover the gas immediately. That stops it being wasted while he fixes the leak. :):)
    You can also use nitrogen to pressurize the system and check for leaks with the sniffer or dye. Any method can be used, just as long as he knows what he is doing. :):)
    My guess would be a leaking/damaged oring when hoses were put back onto new compressor. Or, the actual hose on the compressor leaking due to the mechanic "upsetting" the hose by bending it out of the way when he removed the old compressor. :):)
    Either way, he should warrant his repair. Good luck with it mate, let us know how you get on. :):)
  14. sowest
    Aug 18, 2006
    899
    Yes, the "lock out" feature of an electronic leak detector is very handy. It lets the unit ignore the concentration of the freon cloud in the vicinity and home in on the higher concentration of the source of the leak. It is almost never necessary to fully charge a system to find the leak. Often just a few ounces of freon is all that it takes. Start with the most likely places to leak: the shaft seal, the roto-lock seal on the compressor head, and the hose fittings. It is going to be unlikely that the compressor is leaking from the case joints. Also look carefully at the hoses where they leave the compressor and pass over the gas tank and disappear down into the chassis. There are many sharp edges and things that protrude that can wear through the hose itself as the engine moves around and vibrates. It is possible that the leak is not a compressor issue at all. Sometimes a big leak can be found with just a little soapy water painted around a suspected area. Sometimes a big leak can be found with just the vacuum pump and listening with a stethoscope or brushing on some refrigeration oil on a suspect joint and looking for the oil being drawn in.
    Happy hunting!!
