A/C Fan Switch | FerrariChat
A/C Fan Switch
Discussion in '308/328' started by ToddFC, Nov 29, 2022.
  1. ToddFC
    ToddFC Karting
    Jun 11, 2022
    140
    Charleston, SC
    Todd
    I'm hopefully to have my AC ... as functional as it gets... pretty soon. I'll know in a week if it was a small fix or will be a fully upgrade. Hey, at least its in advance of next summer right :).
    My question is about the AC fan switch which came off in my hand trying to use it over the summer. A look at the post underneath clearly shows what the trouble is. I have tried to tighten the set screw but there isn't enough of a flush surface for the setscrew to lock against any more.
    So while I was ordering some other small interior bits, I was going to try and find this switch. As I'm sure many/all of you know, this switch is no longer available from Ferrari. I've seen one used one for quite an insane amount of money, and one new for insane X2.
    Does anyone have an idea how to fix this? I thought about trying to file that flat spot back into the post.. but its plastic, The switch is at least functional right now. The knob will rest on the post and if your careful.. turn it fully on/off. It's lays loose though and eventually it won't be able to continue to grab enough of that post to turn.
    Any ideas are welcome.
  2. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,129
    SanFrancisco BayArea
    1983 US 308 GTS QV
    Yike! If the switch is still working there must be a way to build the plastic back up. JB Weld? Epoxy? You’ve got nothing to lose since you can find a (expensive) replacement if rebuilding material fails.
    To be clear, I am not suggesting you glue the knob onto the stalk; just wondering if you can rebuild the stock with a hard glue then replace the knob.
    330gt likes this.
  3. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,826
    Mike 996
    I agree with trying some JB weld to build up the plastic. I would drill a small hole or two in the bad part of the plastic and insert something like a small nail (brad) to give a stronger purchase for the JB weld. When the JB is cured, sand the shaft/JBweld/brads to accept the knob.
    As an aside... I would think there is nothing special about that rheostat and a replacement could be found at a supplier like McMaster Carr, etc. It doesn't matter what it looks like below the console.
    2dinos likes this.
  4. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    I agree with Mike - I doubt there's much special about that part. Pull it out and find someone who knows electronics. I doubt McMaster, but Newark or something like that will have something.
    20 years ago this part would have been on a peg at your local Radio Shack.
    2dinos likes this.
  5. Lawrence Coppari
    Lawrence Coppari Formula 3
    Apr 29, 2002
    2,184
    Kingsport, TN
    Lawrence A. Coppari
    The AC blower switch is more than merely a rheostat. It also causes the AC clutch to engage. There are 4 leads that come off it.
  6. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,826
    Mike 996
    Yes, it's an on/off switch as well as a rheostat but again, I can't believe there isn't a suitable replacement available. But if not, a two-pole would work if a small relay was incorporated to handle the load of the compressor clutch. It's all under the console so wouldn't matter appearance-wise.
    That being said, I'd certainly try to repair the existing switch with JB weld or something similar and only if that failed would I try to find a replacement switch, etc. If it's felt that just applying JBWeld/filing/sanding to shape might not be strong enough, another option would be to cut off the plastic shaft several mm above the metal part of the switch and cut/file a step in the end of what's left of the shaft. Then get a piece of the same diameter plastic (or metal) rod, cut a corresponding step in the rod so that it mates with the step in the shaft, thus extending the shaft to the necessary length. Drill a small hole through the steps, put some JB Weld on the joining surfaces and insert a pin through the hole. After JB sets - do the necessary sanding/filing so the knob fits.
  7. ToddFC
    ToddFC Karting
    Jun 11, 2022
    140
    Charleston, SC
    Todd
    I'll take a closer look tonight. We are talking about some VERY small dimensions here. The flat surface is more indented and rounded over the top so when you tighten the screw it pushes the knob off the post rather than tightening against it. I don't think there is any chance of putting a nail/screw in for more to anchor too.
    More likely I would have to file down the flat side 1mm till its flat again and then possibly build it back up with a little JBW.
    No way to do this in the car, would have to pull the knob to attempt a repair, which from my reading means pulling the seats and center console out.
    Little things right.
  8. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,129
    1983 US 308 GTS QV
    I own a 308 but I checked photos on the internet and it looks to me like the top cover holding the switches on a 328 can be removed without removing the console itself. The 308 has that sort of panel and the 328’s just looks bigger.
  9. ToddFC
    ToddFC Karting
    Jun 11, 2022
    140
    Charleston, SC
    Todd
    I hope that is correct. This is the writeup I was looking at.
    https://www.ferrarichat.com/forum/threads/removing-328-center-console.282208/
  10. spirot
    spirot F1 World Champ
    Dec 12, 2005
    14,947
    Atlanta
    Tom Spiro
    In the 328, the switch panel is held down by screws in holding the ashtray in place. once you take those out the whole thing lifts out. Its been a long while since I had mine apart... I think the switches are held in place by collar screws under the black switch plates its easy to get out, just don't bend the switch cover. As for the switch itself, the knob is held on with a tiny set screw - I'd file the top flat and get a longer set screw vs. JBweld etc.. OR file, and glue in a smaller screw so that your stock set screw can make contact. Be very careful of the plastic covers, they have small indents that grab the leather and can be easily broken. if that happens you end up with switch plates that rotate. The switch plates with the blue are not available anywhere... I think the one with fan speed is easy to find.. but $$$$
  11. spirot
    Dec 12, 2005
    14,947
    Atlanta
    Tom Spiro
    you don't have to remove seats or the center console to get the switches out. taking the center console out is easy - the wiring is confusing. If you do be very careful of the edges of the LED switches, they are brittle and can be easily cracked / broken... these are super hard to find and $$$$$$$ when you do.
  12. Brian Harper
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    A pot with an on/off switch built-in is super common. I don't know the specs of the Ferrari switch, but here's an example.
    https://www.jameco.com/z/RV24A02F-10-15S1-B500K-Taiwan-Alpha-1-2-Watt-24mm-0-59-Inch-Shaft-500K-Ohm-Linear-Taper-Potentiometer-with-SPDT-Switch_2268671.html
    Probably the Ferrari switch says right on the back the full scale resistance, if it's linear or log taper. You'd need to know the shaft diameter, that's easy.
  13. ToddFC
    ToddFC Karting
    Jun 11, 2022
    140
    Charleston, SC
    Todd
    I'm liking that idea. However think I'd need a wiring diagram or some spec sheets. From the photos I've seen nothing is on the outside and 6 wires. Not sure what to make of the knob at the bottom? (see last photo)
    How would you find the wiring diagram?
  14. Steve Magnusson
    26,512
    #14 Steve Magnusson, Nov 30, 2022
    That's not a knob -- it's a quarter-turn (or maybe half-turn) cover that holds a small 1A fuse. If yours is still working electrically = the fuse is OK, and you should invest whatever it takes to restore that shaft end form (doesn't look like it would be that difficult to me) -- see below.
    Unfortunately, F doesn't show the internal schematic of the components/ECUs on their schematics. My guess would be that it would be very similar inside to the earlier TR fan speed ECUs that have 6 wires like yours (as both use the same common-emitter power transistor scheme for variable speed operation and closing a relay for full speed operation). On the later TR, they went to the 140151 that has fewer (4) wires, but that was more because they simplified the downstream wiring architecture (not because they changed what was basically inside the fan speed ECU). Here you can see the ridiculous complexity of what's inside 140151:
    https://www.ferrarichat.com/forum/threads/ferrari-testarossa-blower-fan-speed-controller-50009003.665668/#post-148750453
    but I don't know if they are identical. (It does seem way more complicated than what it needs to be to function to me, but I'm just happy when mine works ;)).
  15. Steve Magnusson
    26,512
    Forgot to add that maybe Oddparts (as referenced in that other thread) could help you with the shaft repair, if needed.
  16. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    2,953
    I just did a quick search. Un believable! I did see some staggering prices.
    Re-originals?? Gt Car Parts?? T Rutlands?? Algar?? Ferrari of Denver?? Those last two dealer sources have amazed me with their NOS supplies of odd interior bits. Also, the prices were not terrible (relatively).
    Good luck!
  17. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,826
    Mike 996
    "Here you can see the ridiculous complexity of what's inside 140151:"
    WOW! Clearly the philosophy of: "Why use ONE component to do a job when we can use EIGHT?" Can't think why all that circuitry is necessary to simply turn on/regulate the speed of a motor. FWIW, I first ran into that philosophy working on a Mercedes...
    In any case, I'm confident the shaft on the switch in question can be repaired to operate as new using JB Weld and (possibly) an additional piece of plastic/metal rod.
    2dinos likes this.
  18. Brian Harper
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    Holey moley, that's not what I was expecting. There's a lot going on. Yes, the basis is a pot with a switch as I suggested, but there's a lot of extra stuff on top of that. Ok, yes, now I'm in the camp of trying to fix the shaft somehow. It's at least worth a shot. Only after that would I attempt to try to replace the pot. Last resort I have no doubt this could all be recreated with off-the-shelf individual parts, but it would be a project and probably not very pretty. Hopefully the guy on the Testarossa thread is serious about making replacements. Also interesting to note that the TR version seems to have a metal shaft, and I'm sure you see the advantage there!
  19. Steve Magnusson
    26,512
    I believe Ferrari's only defense is that it was probably the HVAC Vendor's design ;). I haven't studied the 6-wire version as much as the 4-wire version, but AFAIK, it just supplies a variable small variable current in the b-e leg of the power transistor to do the variable speed fan motor operation and then closes the relay when put to full speed in the hope that that would save the power transistor from baking to death, but the human nature of not setting things to full speed in the thought that using 3/4 or 7/8 speed was less-stressful on things worked against that and promoted cooking the power transistor -- which happens a lot (best IMO to use variable speed for 0 to 1/2 speed and then just go to maximum, to use the relay for the big motor current, if you want more airflow).
    Lawrence Coppari likes this.
  20. ToddFC
    ToddFC Karting
    Jun 11, 2022
    140
    Charleston, SC
    Todd
    Photos sent to oddparts to see what they think.
    one solution or another will emerge soon.
  21. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    It's really the inside that makes the difference. Are the switches illuminated (I've never sat in a 328)? I think if you cracked the black box open, it's going to look rather simple to replace the pot.
  22. Milkshaker0007
    Milkshaker0007 Formula Junior
    Sep 22, 2012
    432
    Midlands,uk
    Paul
    Yes they are illuminated, should be able to get inside this like the heater control units?
  23. ginoBBi512
    ginoBBi512 F1 Rookie
    3,535
    SO CAL
    GINO RUGGIERO
    You should try the parts dealers mentioned above, and also call Ferr Parts 916 974 1939 . Ive been buying parts from them for many years, sometimes Ferrari released bulletins that I believe show discontinued parts which are now available, that is what happened when I bought brand new rear Konis for my 89 328. Or , just take it in the ass and buy one thats on EbaY lol .
    Big G
  24. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,826
    Mike 996
    ASSUMING there is nothing wrong with the function of the switch, I would repair the shaft! With the switch out of the console, it would take maybe an hour's worth of work to do any one of several possible repair techniques. Seems way over-the-top to me to purchase another switch if the only issue is the damage shown in the pics.
    OTOH, do whatever YOU are comfortable with. If that means finding an OEM replacement switch, then do that!
  25. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    2,953
    My BMW windshield squirter quit. I thought - $40-60 little pump assuming it's not just a fuse...w r o n g !! The pump is not getting juice and it looks like it's wired through the ECU. I give up, the car never had that feature as far as I'm concerned!
    Might there be a way to take an elegant step backward? Wire up the fan like the basic 308's and just use the 328 fascia and knob? If that's too much of a step backward, perhaps find another motor control unit?
