89 Cab convertible top problem | FerrariChat
Discussion in 'Mondial' started by 89Mondi, Sep 16, 2018.
  1. 89Mondi
    89Mondi Rookie
    Sep 6, 2018
    18
    Los Angeles
    Shawn
    Hi all-
    I'm a new owner of a 1989 Mondi T, 21k original miles. In love. I'll post more re the car a little later, but for now...
    I can't get the top down. I'm able to get it to where it's about a foot back from the windshield but then it seems to catch on the guides in the back. Almost like something is in the way of the guides towards the engine that wont let it go back further. Any idea of how I can fix this? I watched videos on youtube, but I'm "stuck".
    Thanks!!!
  2. alexion
    alexion Formula 3
    May 20, 2013
    1,379
    New York
    Make sure your rear windows are down and you lift the bar located approximately parallel to the headrests. It should have ‘hook’ and when you lift it up, it should allow the top to fold back properly.
  3. 89Mondi
    89Mondi Rookie
    Sep 6, 2018
    18
    Los Angeles
    Shawn
    Will this help the top slide down further on the guides? Both sides are hitting something further down on the guides near the engine.
  4. Cadillacbart
    Cadillacbart Formula Junior
    Nov 26, 2013
    436
    Denver, CO
    Hopefully something you see in this video will help:
    gsfent likes this.
  5. PV Dirk
    PV Dirk F1 Veteran
    Jul 26, 2009
    5,401
    Ahwatukee, AZ
    If the top material binds in the mechanism sometimes it won't go back further. Make sure the material isn't getting pinched.
  6. 89Mondi
    89Mondi Rookie
    Sep 6, 2018
    18
    Los Angeles
    Shawn
    I’m able to get the top as far back as this. The top is hitting something in the rails back here (shown in pic) like something is blocking the sliding of the top backwards. As well, my leather has gotten scratched up, in pic.
    Ridiculous that a top is this difficult/faulty on any car.
  7. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,585
    Menlo Park, CA
    Paul Chua
    hmmm, something is definitely not right. Mine only takes about 2-3 minutes to foldback. let me take a video of the mechanism this weekend, maybe it will help stay tuned.
  8. alexion
    alexion Formula 3
    May 20, 2013
    1,379
    New York
    The bar circled in this image has to be lifted up prior to attempting to put the top back. It's in the video posted above.
    If the bar is not lifted, the top won't go back properly.
    Let us know if this helps.
    paulchua likes this.
  9. 89Mondi
    89Mondi Rookie
    Sep 6, 2018
    18
    Los Angeles
    Shawn
    Hi guys, thanks much for your help. I lift the bar with the curved end upwards. Windows down, the rest of the folding parts start folding down, and it goes back as far as you can see in the pic. The long pieces that slide down on either side of the trunk seem to be hitting something back in there, you can actually feel it. Like there is something blocking the rails.
    Does anyone know of a reputable top shop in Los Angeles?
  10. alexion
    alexion Formula 3
    May 20, 2013
    1,379
    New York
    Bring the top all the way back up to the position where it would be latched. Lift the curved bar up first, then try to pull the top back.
    In the picture above, the bar mentioned is not lifted. If it's in the position as pictured above, it's not going to work properly.
    ronfrohock likes this.
  11. 89Mondi
    89Mondi Rookie
    Sep 6, 2018
    18
    Los Angeles
    Shawn
    UPDATE: I took the car to a top shop today. Seems that whomever put the top up last (previous owner) put it so that the lateral bar (in back) somehow got inverted, causing the top to have a very sharp appearance, too angled. We fixed the problem in 5 minutes.
    Easy breezy, boot is on now, and I’m going to get the top reupholstered because it’s very fragile, dry rotted I think. They’ll see my original window is since it’s in mint condition, no fogging or scratches. Gotta keep that pony!
    Thx for the advice guys. Glad to be part of this community
    Cadillacbart, paulchua and ronfrohock like this.
  12. aec
    aec Karting
    Jul 28, 2011
    138
    Weston, MA
    I had a similar problem for a while on my 1990 t. There are two screws/bolts (located near the outer sides of the rear seats) that hold the frame of the cabriolet roof. These can come loose a bit. When they are loose, the frame is not really straight and it becomes very difficult to put the top down. With the loose screws/bolts tightened, it then all works perfectly again.
