88 TR bad running issues....Need Help | Page 2 | FerrariChat
Discussion in 'Boxers/TR/M' started by MGJBLKTR, Sep 30, 2010.
  1. MGJBLKTR
    MGJBLKTR Karting
    Apr 10, 2006
    222
    Georgia
    MGJ
    I hope to know more by today or tomorrow. I did drive by the dealership and saw the car outside which is a good sign thats its moving under its own power. It would take 50 men to push it up the hill from the service enterance.
    As far as expense......I'm sure it will be considerable.
  2. MGJBLKTR
    MGJBLKTR Karting
    Apr 10, 2006
    222
    Georgia
    MGJ
    I picked the car up today and its running great. New tachometric relay plus they worked on the fuel pump connections at the fuse board. It felt great to drive it again.
  3. Mr.Chairman
    Mr.Chairman F1 Rookie
    Mar 21, 2008
    2,987
    New Jersey
    Robbie
    Where is that relay located? and what numbers should be on it?
    R
  4. Dr_ferrari
    Dr_ferrari Formula 3
    Nov 2, 2003
    1,073
    Pocono Sportscar
    Jim McGee
    #29 Dr_ferrari, Nov 5, 2010
    Robbie,
    Part #8 in the diagram.
    Regards, Jim
  5. Steve Magnusson
    27,018
    #30 Steve Magnusson, Nov 5, 2010
    Although a "bad" tachometric relay really can't cause extended "bad running" as it would shut off both fuel pump relays (and the engine would stop completely) if it was bad. The more typical fault that gets reported is that mode 1 works (so the engine starts OK and the fuel pressure comes up to normal), but the engine dies a short time after releasing the key to "on" (when something's wrong with mode 2, the fuel pumps shut off, and the fuel pressure gradually falls below a useable value).
  6. thornatty
    thornatty Rookie
    Sep 17, 2005
    17
    Coconut Grove, FL
    Thornton McDaniel
    Group: My '85 TR was running perfectly; today, after several weeks of intense rain, the car started right up but without Left bank cylinders firing, no left rear rad fan and no left front headlight motor; elec windows work, as do all running lights, radio, etc.
    I've pulled and cleaned all front fuses but didn't help.
    Is there a main connector for the left electrical side, or another fuse box somewhere?
    Thanks, thorn
  7. Steve Magnusson
    27,018
    #32 Steve Magnusson, Oct 22, 2011
    Does this mean that 1) you know that the 7-12 bank has no spark present, or 2) does it just mean that the 7-12 bank isn't running, and you don't know whether it is caused by no spark or no fuel? On a US '85 TR, no spark on the 7-12 bank would usually also shut the fuel pumps down after the intial start-up (causing the engine to stop after ~10 seconds as the fuel pressure declines) -- so, if yours is a US version TR, continuing to run on only the 1-6 bank is almost certainly a 7-12 no fuel problem, not a 7-12 no spark problem.
    Please confirm version -- US (F113A040 engine family) or euro (F113A engine family)?
    Don't know of any obvious common electrical problem that could simultaneous cause these faults -- and no one has reported such a menage-a-trois before. Have you ever unplugged and inspected the horizontal white connectors at the bottom of the fuse-relay panel (or made modifications to address the known "connector burning" problems there) -- a dead fuel pump and/or a dead water radiator fan is a common symptom from trouble there.
  8. thornatty
    thornatty Rookie
    Sep 17, 2005
    17
    Coconut Grove, FL
    Thornton McDaniel
    This is an '85 US-version #58745...I'll check the white connectors tomorrow. Thanks!
  9. Hawaii
    Hawaii Formula Junior
    Jan 28, 2007
    847
    Maui
    Emery
    It could be the temperature sending unit connector that is plugged into the "Y" water pipe. If not connected correctly it will send a poor signal to the fuel injection and make it idle funny and run on one bank. Wiggle the wires and disconnect and clean that connector.
    Let us know what it was when you track it down.
  10. Il Razzo
    Il Razzo Rookie
    Mar 5, 2011
    4
    San Juan Island,Wa.
    Il Razzo
    Gentlemen, I have experienced all the symptons and problems you have discussed in your previous threads over the last three years with my 1986 TR US version. These problems only got worse with time. The bottom line was the electrical panal(mother board) is breaking down due to heat from poor connections and age. Please "Google" Scuderia Rampante, check out the info on the website and give Dave Helm a call. I am sure you will be satified with the results. regards IL RAZZO
