‘87 TR fuse blows after honking horn a few times - bad compressor? | FerrariChat
Discussion in 'Boxers/TR/M' started by xplodee, Jul 19, 2018.
  1. xplodee
    xplodee Formula 3
    Jan 3, 2017
    1,101
    Allentown, PA
    Tim
    Hi All-
    The fuse blows on my ‘87 after honking the horn a few times. Could it be a bad compressor? Any maintenance on these compressors or buy a new one?
    Bad ground?
  2. thorn
    thorn F1 Rookie
    3,322
    Tallahassee, FL
    Checked the amp draw when you activate the horn? And yes, look for a short.
    xplodee and Natkingcolebasket69 like this.
  3. Natkingcolebasket69
    Natkingcolebasket69 F1 World Champ
    Fuseboard tend to be very faulty on tr’s. Hopefully u have just a short; but if not ur mechanic can sort it out without too much of an expense. Several posts of boards here have been posted which can help u diagnose
    xplodee likes this.
  4. 302Tim
    302Tim Formula 3
    Jul 2, 2011
    1,182
    Northern California
    Tim
    For maintenance remove the top cap and add a few drops of light machine oil occasionally to lubricate the bore. It should spin more freely and possibly not draw as much power. Simple system.
  5. lear60man
    lear60man Formula 3
    May 29, 2004
    1,829
    Los Angeles
    Christian
    302Tim.......good lord, he has the pictures.
    Natkingcolebasket69 likes this.
  6. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,112
    Mel
    #6 Melvok, Jul 20, 2018
    Great Tim !
    This shows why WE ALL should make pics of all our maitenance …: to showall our (future) followers who will face the same problems.
    Hope it is a simple maintenance problem.
    Is there not a plastic notch on the compressor in which you should put some drops of oil ?
    BTW, if I recall well I made a seperate relay for my horn in the 512TR; oem wire activated that relay …
    I wonder why I did that :) (Front bumper removed here … extra two relays for the headlights and one for the horn)
  7. 302Tim
    302Tim Formula 3
    Jul 2, 2011
    1,182
    Northern California
    Tim
    Mel, on the Testarossa no way to add oil without removing the top (but it's just 3 screws)
    Melvok and Natkingcolebasket69 like this.
  8. Natkingcolebasket69
    U give the most detailed and best advice! Very valuable to us tr lover!!thanks
    Melvok likes this.
  9. Melvok
    Jul 25, 2008
    14,112
    Mel
    Friend Tim Xplodee,
    How did you cope with that fuse / horn problem ?
  10. Streetsurfer
    Streetsurfer Formula Junior
    Dec 16, 2015
    934
    near Chicago
    Ron
    Oil can be added at the air hose nipple at the compressors that feeds the trumpets (in my experience with fiamms). . Back door so to speak. That’s the way I have always oiled the comprssors and a dry one can cause fuses to be blown from the strain to run.. You may detect a weaker sound or delay in spool up when it’s getting dry.
    thorn likes this.
  11. xplodee
    xplodee Formula 3
    Jan 3, 2017
    1,101
    Allentown, PA
    Tim
    I oiled the compressor then honked the horn. Got 8 honks before blowing the fuse again. Going to inspect the rotor, oil again and see if it fixes it.
    Fwiw the rotor was bone dry when i first opened it.
  12. 302Tim
    302Tim Formula 3
    Jul 2, 2011
    1,182
    Northern California
    Tim
    I'm guessing you are heading towards the solution--good luck!
  13. Steve Magnusson
    25,124
    Sounds like you are on the right path, but one other thing to do if you still have trouble would be to try a different ...113 relay in the relay A position for the horn. It's wired such that the 20A #1 fuse provides +12V power to both run relay A and the horn motor (so if something goes bonkers inside relay A itself that could also cause fuse #1 to blow). Additionally, that same "always +12V line" from fuse #1 goes to run the stuff in the glove box, including the auxiliary power socket, and it wouldn't be unheard of for someone to have used that same wire as a convenient always +12V source for running something added like an alarm system, power amp, etc.. Anyway, just wanted to point out there might be some other issues.
    xplodee likes this.
  14. xplodee
    xplodee Formula 3
    Jan 3, 2017
    1,101
    Allentown, PA
    Tim
    Is Fuse #1 20A or 10A? Right now the Fuse #1 spot (the one that is blowing) is running a 10A fuse. I was under the impression it's a 10A not 20A
  15. Steve Magnusson
    25,124
    It should be a 15A minimum IMO (and 20A would be no sin) -- here's the F documentation references that I have for the TR fuse #1 rating:
    TR WSM 330/84 (covers early euro TR) = 15A
    TR OM 344/85 (covers early euro TR) = 15A
    TR OM 451/86 (covers 1987 US TR) = 15A
    Late euro wiring diagram 459/86 = 15A
    1986-1987 US TR wiring diagram = don't have a copy of this
    1988-1991 US TR wiring diagram = 20A (this also has the seat belt buzzer function so don't know if they increased it for this, or just bumped it up a little as they thought 15A was marginal)
    Do you have any evidence for it being 10A, or is that just what was in there?
  16. 302Tim
    302Tim Formula 3
    Jul 2, 2011
    1,182
    Northern California
    Tim
    This is listed as a 15A fuse (WD 457/86)
  17. xplodee
    xplodee Formula 3
    Jan 3, 2017
    1,101
    Allentown, PA
    Tim
    My fuse cluster listed it as 20A. Have replaced the fuse with a 20A and all seems good
  18. Steve Magnusson
    25,124
    Thanks for the information. I always trust the specific wiring diagram book for a particular year/model/version the most (more than the OMs which don't always get updated well), but, if the label on the inside of xplodee's fuse-relay panel door says "20A", must have been something they missed in making the 457/86 wiring diagram book, or was such a late design change that it didn't get incorporated into it. That's the type of fix I like -- simple. Toot on! ;)
    xplodee likes this.
