84 boxer full restoration | Page 3 | FerrariChat
Discussion in 'Boxers/TR/M' started by Newman, Dec 13, 2014.
  1. ago car nut
    ago car nut F1 Veteran
    5,267
    Madison Ohio
    David A.
    Newman,
    Four piston rings? I didn't know anyone used 4 anymore? Explain.
    Are the bores Nikasil or iron liners? I would love to get my mits in there.
    Ago
  2. ago car nut
    5,267
    Madison Ohio
    David A.
    Newman,
    I always read the rings rotate in use. But I heard of other times rings all lined up.
    Ago
  3. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,159
    Canada
    Newman
    Ferrari went 3 rings on the Testarossa. I hate 4 rings. Iron liners.
    Rings dont rotate. Perfect example....When I worked for Ford there was an engine recall on the 302 lincolns. At the factory a machine would install the rings on the pistons with all the gaps lined up followed by people manually orienting them prior to installing in the engines. The bean counter determined they could skip the manual step and install them lined up because they rotate anyway. The engines consumed oil so the recall was for us to take the engines apart and orient the gaps and put them back together. Think that paid off for ford? lol
    Oil ring end gap positioning around the wrist pin area is essential or you will have oil consumption.
  4. Etcetera
    Etcetera Two Time F1 World Champ
    22,271
    C9H8O4
    Tapered bores?
    WAG on my part.
  5. ozziindaus
    ozziindaus F1 Veteran
    9,799
    Detroit
    Sam
    TDC?
  6. Newman
    Dec 26, 2001
    14,159
    Canada
    Newman
    #56 Newman, Dec 29, 2014
    Liners are machined outside of the block then under compression from a cylinder head clamped on top, they distort causing high and low spots, out of round and taper enough to make you lose sleep at night. You need to machine them in the block and the bore they ultimately live in using a torque plate. Its the only way to get a straight bore.
  7. ozziindaus
    9,799
    Detroit
    Sam
    Well there you go but why specific to 12 cylinders?
    Edit:
    I think you meant in all cylinders rather than specific to 12 cylinder engines. :)
  8. George Vosburgh
    George Vosburgh F1 Rookie
    I love this kind of stuff!
  9. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,190
    Atlanta
    John!
    Is that about where the oil scraper rings stops at TDC? I'd say oil burning above that point and simply inadequate oil control at the top area of the cylinder.
  10. Newman
    Dec 26, 2001
    14,159
    Canada
    Newman
    Any engine, any brand. But after you machine a liner in a flat 12 for example, check it and then move it to another hole and check it again its changed shape. Gotta go back where it was machined and facing the same way it was when it was machined. 308 is no different, daytona, etc etc. Anything ferrari with an iron liner that drops in by hand changes shape drastically once its installed with a head on it.
  11. godabitibi
    godabitibi F1 Veteran
    6,283
    Papineauville, Quebec
    Claude Laforest
    Diesel engine mechanics always mark their sleeves to put them back in the same spot. You only turn them if you have a protrusion problem or if you want to change the outside pitting spot to another place to extend usable life. An old shoe does'nt fit to someone elses foot.
  12. Newman
    Dec 26, 2001
    14,159
    Canada
    Newman
    #62 Newman, Jan 2, 2015
  13. Newman
    Dec 26, 2001
    14,159
    Canada
    Newman
    #63 Newman, Jan 2, 2015
  14. Newman
    Dec 26, 2001
    14,159
    Canada
    Newman
    #64 Newman, Jan 2, 2015
    Rear fire wall in an injected car has the upper panel in aluminum with a pre-painted layer of foam which is then installed after the car is painted body color and black. To make the foam coating look new its best to just remove it. The pad is indented where its pressed against the structural tubes.
    The 76 BB512 prototype has a one piece rear wall and luggage shelf at the base of the seats that was put in prior to paint or undercoat. So the firewall was heavily coated with the spray insulation then painted. Interesting thing is Ive heard of 365 boxers prior to the first 512 with that foam pad thats between the tubes and rear firewall. So they have been changing the process back and forth.
  15. Newman
    Dec 26, 2001
    14,159
    Canada
    Newman
    #65 Newman, Jan 2, 2015
  16. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    8,934
    romano schwabel
    it is always the question if luigi on munday morning did this job or paolo on friday afternoon :)
  17. 4right
    4right F1 Rookie
    If you were restoring an American car you would probably find a Coke can under the jamb plate.
  18. wlanast
    wlanast Formula 3
    Jan 9, 2007
    1,177
    Santa Ana,California
    William
    great documentation, Paul! You likely know more than most that judge these cars, I am sure that is right around the corner for you in your spare time, lol!
    I was impressed this year at Pebble. As my duties had me in only one judged section, I listened to each judges/car representative dialogue. When items are inconsistent with "known" standards, documentation always wins the day. Ferraris are consistently inconsistent.
    As always, keep posting and thanks!
    W
  19. bernardo66
    bernardo66 The Crazy Cat Man
    Dec 14, 2003
    26,294
    Montreal Canada
    Bernie
    Signature material right there. :)
  20. ferraripete
    ferraripete F1 World Champ
    when the boxers make it to the lawn at pebble...I would hope paul will get the invite!!
  21. 4redno
    4redno Formula 3
    Mar 21, 2006
    1,066
    Seattle, WA
    Keith Mitchell Wintraub
    I hope the lawn at Pebble will still be above sea level by then. ;-)
    Michael Call likes this.
  22. Newman
    Dec 26, 2001
    14,159
    Canada
    Newman
    #72 Newman, Jan 11, 2015
    Some interesting running changes in the model. No reason I can see to black out the area that they did, the older cars were blacked our even more. Injected cars have an internal throttle cable that runs through a tube which you can see beside the shifter hole. The main floor pan has a moulded hump to clear the tube which carb cars dont have so no hump in them. Ferrari is using only modern seam sealer where panels join rather than a fiberglass strip like bonding strip then covered in a thick sound deadener sprayable material. When I see the differences on this 84 vs the 76 I do see a better built car, something no longer in the dark ages! Sorry carb'd guys!
  23. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,006
    Simon Ashley
    Great work, notice that there are bits of masking tape all over as well found these on my 308 and they had used tape to hold the harness.
  24. Newman
    Dec 26, 2001
    14,159
    Canada
    Newman
  25. Newman
    Dec 26, 2001
    14,159
    Canada
    Newman
