83 QV Idle misfire issue after going hard | FerrariChat
Discussion in '308/328' started by FerrariMech1, Mar 12, 2018.
  1. FerrariMech1
    FerrariMech1 Karting
    Dec 14, 2014
    78
    Dayton, OH
    Michael Wilson
    I'm going to be candid and say I don't normally run my car up to redline all that often. Once in a while I get saucy and decide to go crazy on back roads to really feel the 308 shoulder into corners and make Italian music for all to hear. 5,000RPM is usually a good number to aim for on my normal drives.
    Lately, I came across an issue that only seems to come out after bringing it up to redline. What will happen is: I'll launch out, slam gears for a few miles and when I come to a stop the car will settle back into its idle, only to "lope" and run rough. It sounds for sure like it's running on all 8, but just sorta uneven and abnormal. Blipping of the throttle does nothing; it takes a shutdown and restart for the idle to return to normal.
    On a normal basis, the car runs perfectly fine. Cold and Warm starts are good, there is balance through the entire RPM range, and the A/F Ratio was verified good before my run today.
    Now, I've had the fuel distributor and CPR rebuilt by Larry Fletcher some years ago and the ignition system has been gone through by me (wires, iridium plugs, cap, rotor, and two of the three flywheel sensors replaced)... the RPM sensor is still original.
    Does anyone have any theories? Ideas?
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    12,661
    San Carlos, CA
    Mitchell Le
    We don't even have any idea what year and model this car is, Michael?
  3. FerrariMech1
    Dec 14, 2014
    78
    Dayton, OH
    Michael Wilson
    #3 FerrariMech1, Mar 13, 2018
    it’s in the title... 83 Q.V.
    Edit: i guess I should’ve added 308 cause it’s not a Mondial
  4. FerrariMech1
    Dec 14, 2014
    78
    Dayton, OH
    Michael Wilson
  5. Steve Magnusson
    25,038
    What version '83 QV?
    Do you mean:
    1. I turn off the engine when having the idle problem, and I immediately restart, and the idle is fine,
    or
    2. I turn off the engine when having the idle problem, and let everything cool down to ambient for maybe a few (or more) hours, then at the next restart, the idle is fine?
  6. thorn
    thorn F1 Rookie
    3,322
    Tallahassee, FL
    Given you aren't posting in the mondial forum + your post title + your details page, I assumed it was a '83 308QV.
  7. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    10,629
    CT
    John Kreskovsky
    Drive the car and enjoy it. Probably nothing to worry about. Not over heating and good oil pressure? Get in a drive. It will let you know if it something needs attention. That's my idea.
  8. thorn
    thorn F1 Rookie
    3,322
    Tallahassee, FL
    I think the car is doing that. ;)
    Hard to do much more than throw out theory at this point, but I'd start by checking for a vacuum leak while the engine is running at rough idle.
  9. FerrariMech1
    Dec 14, 2014
    78
    Dayton, OH
    Michael Wilson
    #1 matches my remedial action perfectly
  10. FerrariMech1
    Dec 14, 2014
    78
    Dayton, OH
    Michael Wilson
    Sorry, it’s a US car with all the emission stuff removed. No air pump, manifold ports blocked off, etc... the only thing that is still in place is the EGR
  11. FerrariMech1
    Dec 14, 2014
    78
    Dayton, OH
    Michael Wilson
    Is it possible that the EGR is sticking open?
    I know they are normally only open at idle but I’m sure it’s possible that the WOT is causing some sort of malfunction with the device
  12. Steve Magnusson
    25,038
    That's not bad news IMO - and seems more like an upstream control problem than anything wrong with the WUR or fuel distributor themselves.
    Let me have a peek at your OM this afternoon to refresh my memory about your EGR system and operation. My memory is that there is an electrovalve involved in the control of the EGR valve so you might be able to deduce (or force) something there about the EGR system working or not working
  13. FerrariMech1
    Dec 14, 2014
    78
    Dayton, OH
    Michael Wilson
    #13 FerrariMech1, Mar 13, 2018
    There’s a three outlet electro valve in the circuit. One end goes to the top of the throttle body, another to the EGR, and last one goes to another electrovalve on the front bank which goes to who knows what...
    I’m going to try and work on blocking off the EGR ports (or taking away the vacuum) to see if that changes anything
  14. johnk...
    Jun 11, 2004
    10,629
    CT
    John Kreskovsky
    Yes, it's a typical temperamental Italian. DO you go to the doctor every time you sneeze?
  15. tatcat
    tatcat F1 World Champ
    Sep 3, 2001
    10,966
    panama city beach FL
    rick c
    Do you still have the cat
    Sometimes after a hard run it can overheat and cause problems
  16. Steve Magnusson
    25,038
    That sounds ideal. Pages N11-N14 in the 281/83 Mondial8/QV WSM would be your best reference (downloadable from http://ferrari.cdyn.com). At warm idle, there should be no vacuum applied to the EGR valve diaphragm so you can just unplug the vacuum line going to it to force that condition. If the EGR Valve itself is just (wrongly) remaining stuck open after returning to warm idle (with no vacuum applied), then blocking off the exhaust gas path some other way would be a good test. Good hunting!
  17. ME308
    ME308 Formula 3
    Nov 5, 2003
    1,542
    Munich, Germany
    Michael
    me too was thinking of that ...
    but how does one explain then, that the idle is immediately smooth after a hot re-start ?
    if the egr valve where to be stuck open during the time the engine exceeds 5000rpm, I`d guess it would stay that way even after a shut down & immediate re-start
    anyway, taking the egr valve completely out of the game would be good start ;)
  18. johnk...
    Jun 11, 2004
    10,629
    CT
    John Kreskovsky
    When the car is idling badly just get out and tap the EGR valve and see if it evens out, or pull off the vacuum line and hold your finger over it.
  19. Steve Magnusson
    25,038
    Agree that's an unlikely scenario, but even something like the starter motor cranking might give enough vibration to get it unstuck (so johnk...'s suggestion to just it it a whack seems a logical first step). I was hoping that the OP could first confirm that his EGR system configuration still matches the figure on page N11 (since he reported a lot of other emission modifications): Image Unavailable, Please Login
  20. FerrariMech1
    Dec 14, 2014
    78
    Dayton, OH
    Michael Wilson
    Steve, the configuration noted here is the exact way it is set up. Albeit, the only thing that could potentially be a problem is the electrovalve and the temp sensor... I have no clue if they still work
  21. FerrariMech1
    Dec 14, 2014
    78
    Dayton, OH
    Michael Wilson
    So, I went ahead and removed the vacuum line at the EGR and plugged both the EGR itself and the tap on the throttle body. Took it for a drive getting it nice and hot before putting the car through its paces.
    I was beginning to think I was in the clear after going at it for half hour or so until it decided to misbehave. It did so in the same way as described before... giving the EGR a good whack didn’t seem to change anything
    Back to the drawing board!
    PS: I’ll try to get some video the next time I go out
  22. jcurry
    21,376
    In the past
    Jim
    Long shot, but maybe the valve is set at too low of vacuum and the exhaust is opening it slightly even when disconnected. There is a set screw on top to adjust the spring.
  23. FerrariMech1
    Dec 14, 2014
    78
    Dayton, OH
    Michael Wilson
    Is that what that is? Ill try and fiddle with it to see if that changes anything.
    Thank you!
  24. FerrariMech1
    Dec 14, 2014
    78
    Dayton, OH
    Michael Wilson
    Jcurry mentioned something about the throttle bypass valve which had the “tail” incorrectly routed to the plenum instead of the electrovalve.
    I really need to work on removing the EGR before I can move on. Does anyone have any ideas on plugs for the intake outlet?
  25. jcurry
    21,376
    In the past
    Jim
    not me, but let us know if that fixes things
