'83 Mondial QV Losing Power | FerrariChat
Discussion in 'Mondial' started by JakeTrading, Sep 19, 2007.
  1. JakeTrading
    JakeTrading Formula Junior
    Nov 7, 2001
    667
    A bit of an issue with an '83 Mondial QV.
    When driving above 4,000 rpm, the bar seems to bog down, basically losing power.
    The car just had a new fuel pump installed, new fuel fuel filter and crank sensors.
    There is spark on all 8 cylinders. Timing is perfect.
    Injector issue?
    Also, how many relays are there for the ECU?
    Thanks!
  2. JakeTrading
    Nov 7, 2001
    667
    Funny - I pushed down on several relays to make sure they were connected well, and oila! Fixed. Car is as smooth as it should be.
    I pressed on several relays, so I can't even tell you which one it was.
