83 Boxer engine and gearbox rebuild | Page 8 | FerrariChat
Discussion in 'Boxers/TR/M' started by Newman, May 31, 2018.
  1. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,155
    Canada
    Newman
  2. Newman
    Dec 26, 2001
    14,155
    Canada
    Newman
  3. Newman
    Dec 26, 2001
    14,155
    Canada
    Newman
  4. Newman
    Dec 26, 2001
    14,155
    Canada
    Newman
  5. Gleggy
    Gleggy Formula 3
    Sep 22, 2004
    1,449
    Land of Oz
    Gleggy
    Image Unavailable, Please Login Lovely work Paul. Good to see.
    You should make a purpose build trolly stand for the BB engine you do that many of them.
    I don't know if you remember mine, but it works well. The mount set up is the copy of the chassis and mounts in the car.
    of2worlds likes this.
  6. Newman
    Dec 26, 2001
    14,155
    Canada
    Newman
    Pretty but I don't have the room for things like that and mine works on everything I put on it including a gearbox upside down, 308, boxer, Countach, V8 anything engine on its end etc.
  7. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,680
    Central NJ
    Dominick
    That looks like a piece of art
    Temping me to send my car to you :)
    Sent from my moto x4 using Tapatalk
  8. Newman
    Dec 26, 2001
    14,155
    Canada
    Newman
    Thank you :)
  9. Newman
    Dec 26, 2001
    14,155
    Canada
    Newman
    Just wanted to comment on a detail of the 512 (and up) oil fill hole. Note the oval machined boss for the fill plug. When the 365 came out it had a round boss in a lower position (bottom of the oval to be exact). Ferrari came out with a revised insert that went in that fill hole that looked like a tube that curved up so the oil level could be increased without running out of the fill hole. Later ferrari altered the mould to eliminate the curved tube and machined the fill hole in the higher position.
    JimEakin and turbo-joe like this.
  10. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    8,931
    romano schwabel
    how do you see if there is only a little water dripping from inside?
  11. Newman
    Dec 26, 2001
    14,155
    Canada
    Newman
    You do the test before the engine goes on the gearbox and if there's a leak you'll see it dripping off the end of the liners.
    turbo-joe likes this.
  12. Newman
    Dec 26, 2001
    14,155
    Canada
    Newman
  13. turbo-joe
    Apr 6, 2008
    8,931
    romano schwabel
    I thaught so already because otherwise you not can see if dripping
    so when you not remove the gearbox and make a pressure test you may have a problem later without knowing why. but I think once the liners are tight they will not start some day to drip? or you once had such a problem paul?
  14. Newman
    Dec 26, 2001
    14,155
    Canada
    Newman
    Ive had a leak before going on a gearbox and its safe to say it shouldn't leak later if it passed that initial test. I haven't had to take one back out for such a thing and now Im jinxing myself!
  15. turbo-joe
    Apr 6, 2008
    8,931
    romano schwabel
    ? what does this mean? jinxing? can not find in the translator :(
    but if you perhaps have the engine out and install for example new headgaskets and new waterpump do you separate then the engine from the gearbox to make the pressure test or keep it together?
    it is normal for me when you overwhaul the complete engine that you make this test without gearbox.
  16. pshoejberg
    pshoejberg Formula 3
    1,696
    Denmark
    Peter H
    QUOTE=I blasted the rear cover, it was a real mess then hit it with the same paint I use on the block and gearbox.
    Are those castings normally painted?
    Best regards
    Peter
  17. ago car nut
    ago car nut F1 Veteran
    5,267
    Madison Ohio
    David A.
    Romano, by saying no problem (JINX) means now a problem will happen because I said I have no problem. Like knock on wood for good luck. But the opposite.
  18. Edward 96GTS
    Edward 96GTS F1 Veteran
    9,301
    jinxing= to bring bad luck
  19. Ludwig
    Ludwig Formula Junior
    Mar 27, 2006
    307
    Redmond WA
    Ludwig Allegra
    When I pressure tested with air I pushed it to 30 PSI and did see a very slow drop over many hrs- At 1 hr virtually undetectable. I can detect no leakage around the pump with soapy water. Do you expect absolutely no drop after 12-24 hrs?
  20. Newman
    Dec 26, 2001
    14,155
    Canada
    Newman
    Depends how late the car is in 84. Ive seen bare gearboxes like Testarossa boxes but an 83 is painted including the cover. Things like the water pump castings, oil filter adapter and cast brackets are bare regardless of year. They stopped painting gearboxes the end of the boxer run.
    pshoejberg likes this.
  21. Newman
    Dec 26, 2001
    14,155
    Canada
    Newman
    30 is excessive to me, makes me think I could compromise something and have a failure later because of it like distort the pump seal which would suck
    Rifledriver and turbo-joe like this.
  22. Newman
    Dec 26, 2001
    14,155
    Canada
    Newman
    Stripped the upper plenums and wrinkled them so they match the runners.
    Finishing up the top before the plenums go on.
    WUR and fast idle valves were on clear zinc brackets instead of yellow zinc. I've seen them both ways so the best way is to just copy what the car had provided it appears original rather than change it to what you think it should be.
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    tbakowsky likes this.
  23. Newman
    Dec 26, 2001
    14,155
    Canada
    Newman
    bjunc, mikael82, pshoejberg and 3 others like this.
  24. Newman
    Dec 26, 2001
    14,155
    Canada
    Newman
  25. Ludwig
    Mar 27, 2006
    307
    Redmond WA
    Ludwig Allegra
    as always really gorgeous.
    Back to the coolant system side- I was planning to utilize a waterless coolant such as Evans which would then operate a zero pressure and reduce all stresses on the pump seals etc. Jay Leno has used this in multiple exotics and highly recommends. any thoughts?
