83 Boxer engine and gearbox rebuild | Page 4 | FerrariChat
Discussion in 'Boxers/TR/M' started by Newman, May 31, 2018.
  1. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,093
    Canada
    Newman
  2. DonB
    DonB Formula Junior
    616
    Florida
    Don Bartz
    FWIW, the rubber covers over the wiper nuts are depicted in the Ferrari parts manual. TAV 116, #3, PN 61035200 Cappucio copridado. My car, 51723 came with them and appeared to be original.
  3. Newman
    Dec 26, 2001
    14,093
    Canada
    Newman
    Thank you! Im not sure why some markets have them. This boxer and my 400 both have the correct black acorn nuts under them.
  4. Newman
    Dec 26, 2001
    14,093
    Canada
    Newman
    One of my new billet diff's in for a preload check with the existing shims and its right on the money. Ill check gear pattern and backlash next.
    The one un-plated stud for the side cover was left in because it felt like it was going to snap if I insisted on taking it out. A case of "the cure is worse than the disease". Its hidden well enough to let slide and the front studs are not visible to anyone but the pedestrian you're running over. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
  5. JimEakin
    JimEakin Formula Junior
    Jun 13, 2015
    988
    Mountain Living
    Jim
    Ferrari castings are amazing - work of art.
  6. Newman
    Dec 26, 2001
    14,093
    Canada
    Newman
    Agreed! Fun to just look at and you can see the passion that went into them.
  7. CarbBoxer
    CarbBoxer Formula Junior
    Oct 7, 2008
    841
    Houston
    PW
    Really nice work.
    Branching out into 400i?
  8. Newman
    Dec 26, 2001
    14,093
    Canada
    Newman
    Thats mine! I was changing the oil over the holidays. I do have some 400 customers too, not just boxers :)
  9. Newman
    Dec 26, 2001
    14,093
    Canada
    Newman
  10. dwhite
    dwhite F1 Rookie
    Ouch, I doubt Nolan Ryan could throw that hard in his heyday. ;-)
    Wish I had my car down here in Fl, I'm in need of a blast.
    Work looks amazing as always in pictures and it's the exact same even in the flesh.
    Newman likes this.
  11. Newman
    Dec 26, 2001
    14,093
    Canada
    Newman
    We made a very light cut on the one block half to allow us to correct the main journal alignment and size. New bearings, fresh paint and reinstalled studs that were pulled to make the cut on the block. Tomorrow Ill bolt the two halves back together.
    Cutting the block on a flat 12 doesn't leave much room for correction like a V8 or any V engine because the engine has to fit the gearbox, the timing cover has to fit the two halves once together and the rear main seal opening has to be taken into consideration as well.
    ago car nut likes this.
  12. 4right
    4right F1 Rookie
  13. Newman
    Dec 26, 2001
    14,093
    Canada
    Newman
    The front timing cover was what I wanted and various studs were worth every penny. I’ve since sold the engine to someone that wanted it after I took what I needed. I had it kicking around in the loft for a couple of years before deciding I really didn’t need this thing sitting here.
  14. Newman
    Dec 26, 2001
    14,093
    Canada
    Newman
    of2worlds likes this.
  15. Newman
    Dec 26, 2001
    14,093
    Canada
    Newman
  16. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    8,867
    romano schwabel
    not even updated to a coffee table? ;)
  17. 53ford
    53ford Karting
    Nov 13, 2009
    112
    hello Paul.....that piston skirt could be damaged. I'd have an expert check it before it goes back in. Cheers, Bernie out west.
  18. Newman
    Dec 26, 2001
    14,093
    Canada
    Newman
    Ill mic it just to make sure!
  19. Newman
    Dec 26, 2001
    14,093
    Canada
    Newman
  20. Newman
    Dec 26, 2001
    14,093
    Canada
    Newman
    Cant get that one past my wife. Wouldn't exactly go with the decor in my house either. I have this in my office though!
    675HP at 10300 RPM! (no thats not me in the background and its really a Cosworth engine)
    turbo-joe likes this.
  21. Newman
    Dec 26, 2001
    14,093
    Canada
    Newman
  22. Newman
    Dec 26, 2001
    14,093
    Canada
    Newman
    of2worlds and George Vosburgh like this.
  23. turbo-joe
    Apr 6, 2008
    8,867
    romano schwabel
    you put in larger intake valves that you have to modify the pistons?
  24. Newman
    Dec 26, 2001
    14,093
    Canada
    Newman
    No, the factory pistons have a similar side notch, boxer, 308 doesn't matter. Although the piston doesn't look much different than a stock one, its far from stock and I needed to put the side notch there for radial clearance only. Even all stock the valve would hit if the factory didn't put that notch there. The exhaust has a mile of clearance to the point I dont see the need for a valve relief. Unless of course you missed a shift and somehow the engine spiked to 12K RPM then maybe, MAYBE it would need an exhaust relief.
  25. turbo-joe
    Apr 6, 2008
    8,867
    romano schwabel
    thx for the info paul. have not known/read that you use aftermarket pistons
