83 Boxer engine and gearbox rebuild | Page 11 | FerrariChat
Discussion in 'Boxers/TR/M' started by Newman, May 31, 2018.
  1. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,649
    Argent/Brasil
    Guido
    Additional oil supply line from the box to the drop gear case = from what oil supply line can you connect that extra oil line ? Is there a hole allready or can a hole being drilled somewhere in the box ?
    Guido
  2. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,505
    romano schwabel
    with what paint? 2 compound?
  3. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,436
    Canada
    Newman
  4. Newman
    Dec 26, 2001
    14,436
    Canada
    Newman
  5. Ludwig
    Ludwig Formula Junior
    Mar 27, 2006
    307
    Redmond WA
    Ludwig Allegra
    Beautiful as always, and really helpful in terms of the correct routing and hose type.
    Regarding the fuel distributors, which I have rebuilt, do you have a test bench to check for injector volume balance and function? I was thinking of building a basic test station to do this before the final installation.
  6. Newman
    Dec 26, 2001
    14,436
    Canada
    Newman
    I have them rebuilt and calibrated, same goes for the WUR's. No headaches that way especially on a fresh engine.
  7. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    3,001
    Hi Paul,
    Looking wayy back on gearbox pics - - - Am I seeing correctly that reverse has a synchro?? I looked it up in parts book and appears to be so. The boxer is a pretty refined car! If memory serves, 308's do not.
    Thanks.
  8. Newman
    Dec 26, 2001
    14,436
    Canada
    Newman
    Yes reverse is syncronized which comes in handy of you didn't adjust your selector shafts correctly!
  9. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    3,001
    Beautiful job on the exhaust! (And everything else).
    Newman likes this.
  10. raysur
    raysur Formula Junior
    614
    So. Cal.
    Jeff
  11. ago car nut
    ago car nut F1 Veteran
    5,495
    Madison Ohio
    David A.
    It looks like it was a simple design inclusion that warranted sychro on reverse. Or to equal Lambo?
  12. Newman
    Dec 26, 2001
    14,436
    Canada
    Newman
  13. Statler
    Statler F1 World Champ
    Jun 7, 2011
    17,389
  14. MS250
    MS250 Two Time F1 World Champ
    Dec 10, 2003
    26,564
    Avvocato
  15. Ludwig
    Mar 27, 2006
    307
    Redmond WA
    Ludwig Allegra
    Hi Paul, again, really nice. Would you be so kind as to post some hi-res images of the visualized front of the engine, firewall area as well as from below- This would really be helpful as I am close to re-installing the engine. I want to be sure that all hose and wire routing is "correct". Even though I have probably 1000 images it is amazing to see the ones I didn't take, not to mention the fact that a mechanic had previously been there.
  16. Newman
    Dec 26, 2001
    14,436
    Canada
    Newman
    Here's a few dirty and clean.
    Put as much on as possible before installing the engine. Ferrari installs both oil lines on the engine but the long one requires someone under the car feeding it through the chassis so I leave the long one on the car. I install the engine with alternator belt tension set and once in I undo the right lower alternator bracket - the alternator hardly moves - then I can attach the long hose to the fitting in the gearbox.
    In this case the short oil line to the tank was left on the car, dont do that. I also attach the 3/4" hose to the lower coolant pipe near the water pump so I dont have to reach in there after the engine is installed. The top coolant pipe comes down and lines up with the oil pressure gauge sending unit so if you put it right in front of the sending unit you can tighten the hose clamps knowing it'll line up with the central pipes on the car.
    And the pic of the fresh engine was taken before I put the line on. Ill post more pics.
    I leave the bell housing off and install it once in the car
    . Image Unavailable, Please Login Image Unavailable, Please Login
  17. Newman
    Dec 26, 2001
    14,436
    Canada
    Newman
  18. Newman
    Dec 26, 2001
    14,436
    Canada
    Newman
  19. Newman
    Dec 26, 2001
    14,436
    Canada
    Newman
  20. Newman
    Dec 26, 2001
    14,436
    Canada
    Newman
    76 engine shows large oil line. You want it to pretty much touch the driver side filter (for us with LHD cars) and then when its hooked to the tank it will clear the filter.
  21. Ludwig
    Mar 27, 2006
    307
    Redmond WA
    Ludwig Allegra
    Thanks! very helpful-I am probably going to reinstall the engine within the next month. I am sorting out the wiring and mounting of the new ignition box-I went with a Pertronix HP digital which is interesting in that it is Bluetooth linked to a phone app to allow all parameters to be set.
    And despite the superb service access to the front of the engine I don't want to omit all initial routing and connections.
  22. Newman
    Dec 26, 2001
    14,436
    Canada
    Newman
    Post pics in your thread before you put it in.
  23. Newman
    Dec 26, 2001
    14,436
    Canada
    Newman
