83 Boxer engine and gearbox rebuild | Page 10 | FerrariChat
Discussion in 'Boxers/TR/M' started by Newman, May 31, 2018.
  1. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,523
    Canada
    Newman
    Belt covers are not wrinkled, they're cast and painted silver just like the block and gearbox.
    Water pipes are anodized.
    turbo-joe likes this.
  2. Newman
    Dec 26, 2001
    14,523
    Canada
    Newman
    of2worlds, mikael82, crinoid and 4 others like this.
  3. CarbBoxer
    CarbBoxer Formula Junior
    Oct 7, 2008
    844
    Houston
    PW
    What’s the zinc plated piece around the distributor cap?
  4. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,593
    romano schwabel
    it is for suppression of induced voltages/frequencies ( right word?? )
  5. Newman
    Dec 26, 2001
    14,523
    Canada
    Newman
    Prevents radio interference like the old corvettes had but in chrome. Injected boxers came with a radio from the factory.
    crinoid likes this.
  6. ago car nut
    ago car nut F1 Veteran
    5,523
    Madison Ohio
    David A.
    Who want's to listen to the radio when beautiful music is coming from the 12cyl!
  7. Newman
    Dec 26, 2001
    14,523
    Canada
    Newman
    Sign of the times. No different than Ferrari offering a targa roof car in their model line.
  8. Newman
    Dec 26, 2001
    14,523
    Canada
    Newman
    of2worlds, crinoid and turbo-joe like this.
  9. Newman
    Dec 26, 2001
    14,523
    Canada
    Newman
  10. Newman
    Dec 26, 2001
    14,523
    Canada
    Newman
    crinoid likes this.
  11. Newman
    Dec 26, 2001
    14,523
    Canada
    Newman
    Once I road test the car they will take on a nice golden colour from the heat cycles. So when they were new they were silver. Testarossa, 328, all the same in that they turn gold in a very short period of time.
    crinoid likes this.
  12. Ludwig
    Ludwig Formula Junior
    Mar 27, 2006
    307
    Redmond WA
    Ludwig Allegra
    looks great
    I hope to follow suit very soon. Waiting on a new ignition module prior to being able to put the engine back in.
    looking at the Pertronix digital HP with Bluetooth control. This allows for easy setup and rev limit also you can disable the ignition via the app.
  13. Ludwig
    Mar 27, 2006
    307
    Redmond WA
    Ludwig Allegra
    Paul, do you have a link/part # for the "Rp racing" clutch
  14. Newman
    Dec 26, 2001
    14,523
    Canada
    Newman
    No link. Its an AP Racing clutch I get from the usual sources like Rutlands or Eurospares.
  15. Ludwig
    Mar 27, 2006
    307
    Redmond WA
    Ludwig Allegra
    Thanks, misread the markings.
  16. George Vosburgh
    George Vosburgh F1 Rookie
    Paul, how do you know everything is good inside the mufflers? I've seen cans that look great from the outside, but are totally corroded from within?
  17. Newman
    Dec 26, 2001
    14,523
    Canada
    Newman
    These mufflers are stainless steel and if there's nothing rattling around and nothing comes out its good. But the Ansa mild steel mufflers if you listen very closely on a quiet night you can hear them rust.
  18. Newman
    Dec 26, 2001
    14,523
    Canada
    Newman
    mikael82 likes this.
  19. Newman
    Dec 26, 2001
    14,523
    Canada
    Newman
    Drop gears case and bearings.
    Stock 512 Boxer bearings on left, top is input support bearing. Right row is Testarossa, note top and bottom bearings. Testarossa rollers on the top are longer to spread the load and they're larger in diameter. The 365 boxer had no upper bearing here. The input shaft relied on the pilot bearing in the crank and the bearing in the bell housing only. Even the first 512 boxers had no support bearing in the drop gear case so the input shaft, upper gear and drop gear case was different. No doubt the gears were trying to push away from each other under load. Not sure when the 512 got the upper support but a check of the parts book could probably tell me the chassis number split.
    So as the cars progressed the upper bearing was added then the bearings were beefed up and then the TR got an additional oil supply line from the box to the drop gear case. The Testarossa gears are also cut on a steeper angle.
    The bottom bearing is a much better part and a number of additional balls. A nice upgrade if you're changing them anyway.
    New rear heat shield has been test fitted and drop gear case is ready.
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
  20. turbo-joe
    Apr 6, 2008
    9,593
    romano schwabel
    you can already hear them rusting in the sales brochure ;)
    George Vosburgh likes this.
  21. pshoejberg
    pshoejberg Formula 3
    1,863
    Denmark
    Peter H
    So true....I just cut up the Ansa sport exhaust's on my BBi and both units were completely rotten away and disintegrated under the fairly nice looking skin. Corrosion protection has never been a part of the thought process in that company.
  22. dwhite
    dwhite F1 Rookie
    What are you replacing them with?
  23. Newman
    Dec 26, 2001
    14,523
    Canada
    Newman
    of2worlds likes this.
  24. pshoejberg
    1,863
    Denmark
    Peter H
    A pair of Nouvalari sport exhausts are ready on my shelf. Newman, did you paint that nice clutch housing?
    Best regards Peter
  25. Newman
    Dec 26, 2001
    14,523
    Canada
    Newman
    I did
