812 VS Rumors | Page 83 | FerrariChat
812 VS Rumors
Discussion in 'F12/812' started by Frenzisko, Feb 10, 2018.
  1. abdulla.alhajri
    abdulla.alhajri Karting
    Jul 16, 2015
    124
    I believe it was MY2020, ironic how the market will be supplied by 2 versions of 812 GTS
  2. KarlA69
    KarlA69 Formula Junior
    Oct 9, 2017
    759
    Karl
    I don’t think that’s correct. Everything I’ve seen and heard suggests only one version of the GTS - with GPF fitted. Not sure why the modis code you’re referring to wouldn’t reference GPF
  3. Avia11
    Avia11 Formula Junior
    864
    San Diego, CA
    There is only 1 version of the 812 GTS with the GPF. I asked about deleting the GPF for my north american car. The factory reply was, no because there is no emissions testing without the GPF. So from the factory all 812 GTS will have GPF, and it will be a limited 2 year run.
    456-boy likes this.
  4. KarlA69
    Oct 9, 2017
    759
    Karl
    The good news is that Novitec and Kline are actively working on GPF-delete options. Details TBC but we should see something before year end, I think.
    Caeruleus11 and Avia11 like this.
  5. aobao1993
    aobao1993 Formula Junior
    Feb 3, 2017
    415
    When will it come ?thx!
  6. Albert-LP
    Albert-LP F1 Veteran
    7,784
    around Modena, Italy
    Alberto Mantovani
    uhn2000, of2worlds and lamborarri like this.
  7. Prancing12
    Prancing12 Karting
    May 8, 2005
    61
    Interesting!
    Any idea what this could interpret to ?
    F152DB 2P V12 EURO6D GPF GOL A
  8. JTSE30
    JTSE30 F1 Rookie
    Oct 1, 2004
    3,251
    Austin TX
    GPF-based 812 model using Euro6D homologation
    The curious part is "GOL" (the trailing "A" is most likely "ADAS")
    That position of the code is typically used to indicate the Country or Region.
    It appears you are in Germany? Is this code from a German Ferrari dealer (probably not since I believe 812SF cannot be ordered)?
    I would guess that "GOL" might indicate "GLOBAL", so, maybe this code is from an area in the middle east?
    of2worlds and Prancing12 like this.
  9. abdulla.alhajri
    Jul 16, 2015
    124
    The code i saw from cars in dubai has the those letters too GOL
  10. Prancing12
    Prancing12 Karting
    May 8, 2005
    61
    Yes, Middle East.
  11. ppg70
    ppg70 Formula Junior
    Aug 22, 2017
    928
    I am pretty sure that day355 not only saw the car....
    as look it reminds to me a donkey version of TdF with a specific element for rear inspired by Deborah......also bonnet has a specific element
  12. JTSE30
    JTSE30 F1 Rookie
    Oct 1, 2004
    3,251
    Austin TX
    That sounds curious. Never thought to use the word donkey and TdF together like that...and I wonder which rear element of (SP38) Deborah:
    Probably the rear slats as 4 exhaust tips above the bumper might look odd.
    Any details of modifications to the engine/powertrain?
    of2worlds and Caeruleus11 like this.
  13. Challenge64
    Challenge64 F1 Veteran
    6,306
    Ron
    That doesn’t sound good at all!
  14. Lagunae92
    Lagunae92 Formula 3
    2,052
    SoCal
    It will be good. They aren’t in the habit of messing these VS cars up.
    stavura, ewright, JagShergill and 7 others like this.
  15. MANDALAY
    MANDALAY F1 World Champ
    Owner Rossa Subscribed Silver Subscribed
    May 23, 2013
    11,098
    AUSTRALIA
    ANGELO
    IF the GPF is anything like the F8 i.e a part of the silencer and no sensors before or after it its a no brainer and can be taken out .
    I mean countries that don't give a rats yet.
    Lagunae92 likes this.
  16. JTSE30
    JTSE30 F1 Rookie
    Oct 1, 2004
    3,251
    Austin TX
    The F8 has sensors, take out the GPFs and you will get codes within 75 miles of driving.
    The 812GTS GPFs are part of the catalysts (4-way catalyst) and like all GPF devices (no matter the manufacturer) it has sensors connecting into the ECU. The GPFs also create extra back pressure (chokes the exhaust channel with restricted flow) and that is also measured.
    The only "defeat" devices I know of for Ferraris inserts a device into the OBD2 port and intercepts the codes to prevent the ECU from reading them...
  17. JagShergill
    JagShergill Formula 3
    Dec 31, 2014
    1,669
    England
    Jag shergill
    Hopefully the bonnet specific element is a clear Window as in the SP3JC.... Image Unavailable, Please Login
    stavura, PTG1 and Bundy like this.
  18. JagShergill
    Dec 31, 2014
    1,669
    England
    Jag shergill
    Really been massively hoping for some time that some of the design elements from John Collins’ (2!) 1 offs, the SP3JC , as I’ve been lucky enough to get close up to see the cars in person. Although mostly based on the TDF it lends itself to design elements in the new VS /VSAperta
    of2worlds likes this.
  19. Lagunae92
    Lagunae92 Formula 3
    2,052
    SoCal
    Interesting with an F 12 in there.
  20. MANDALAY
    May 23, 2013
    11,098
    AUSTRALIA
    ANGELO
    The GPF according to the schematics has absolutely no plugs for any sensors at all. see below
    If you look carefully there looks like 2 pipes one before and one after the canister.. what connects to that will be interesting. As you can see its a separate unit not a part of the catalytic converter.
  21. KarlA69
    Oct 9, 2017
    759
    Karl
    I'm not sure where this diagram comes from but I doubt it's the 812 exhaust. I obtained from a Ferrari dealer service dept directly the parts diagrams showing the current 812 (see attached - bottom) and also the new model with GPF (top). I imagine the GTS would be exactly the same (with GPF version). The diagram shows the GPF integrated with the cats and various sensors.
    BTW I have spoken to Kline and Novitec recently and both are currently examining the 812 GTS exhaust and looking into GPF replacements. I estimate we will see a solution by year end
    Karl
  22. ppg70
    Aug 22, 2017
    928
    nope....unfortunately!
  23. MANDALAY
    May 23, 2013
    11,098
    AUSTRALIA
    ANGELO
    What I posted was the F8. I commented whether the 812 was the same but clearly not :(
