812 VS Rumors | Page 197 | FerrariChat
812 VS Rumors
Discussion in 'F12/812' started by Frenzisko, Feb 10, 2018.
  1. Garretto
    Garretto F1 Rookie
    Sep 3, 2003
    4,933
    Bilbao, Spain
    Rodolfo Di Pietro
    Sounds about right as per known facts or probable features. Leaked pic matches prominent hood vents and not standard painted shields :D
  2. Garretto
    Garretto F1 Rookie
    Sep 3, 2003
    4,933
    Bilbao, Spain
    Rodolfo Di Pietro
    Agree 10K rpm sounds optimistic.
  3. Doug23
    Doug23 Karting
    Jun 23, 2017
    193
    Italy
    900Nm seems way too high for an unassisted n/a 6.5L engine
    Inviato dal mio BAH-L09 utilizzando Tapatalk
    350MH83 and F140C like this.
  4. F140C
    F140C Formula 3
    Nov 25, 2016
    1,574
    Piedmont
    Marco
    Thanks for sharing, styling looks incredibly aggressive!
    Agreed, not likely.
    Doug23 likes this.
  5. crinoid
    crinoid F1 Veteran
    9,485
    LaCrinoid
  6. Shack
    Shack F1 Rookie
    May 2, 2005
    2,509
    Earth
    will make the f12TDF look pedestrian
    TP98 and 355TDI like this.
  7. [gTr]
    [gTr] Formula 3
    Mar 11, 2008
    1,024
    Hamburg, Germany
    Great detail and post, I had never realised this venting feature in the SP30. I always thought that this was just a stripe across the hood!
    The rear decklid seems to be a more aggressive rework of the 812 Omologata decklid.
    crinoid likes this.
  8. day355
    day355 Formula 3
    Jun 25, 2006
    2,071
    Cooling function + aerodynamic function;)
    JagShergill and of2worlds like this.
  9. LVP488
    LVP488 F1 Rookie
    Jan 21, 2017
    4,876
    France
    Base price lower than the price of a used F12 TdF would be a bargain, and a true reward for the happy few selected by Ferrari. Not sure I believe it will be the case though.
  10. day355
    day355 Formula 3
    Jun 25, 2006
    2,071
    Ready for the boost guys !?:D
    Jonathan19 and of2worlds like this.
  11. crinoid
    crinoid F1 Veteran
    9,485
    LaCrinoid
    Thanks. I really like the SP30.
    I noticed the same about rear deck lid. I’m guessing no window and a camera based on photo.
  12. jpalmito
    jpalmito F1 Veteran
    Jun 5, 2009
    7,360
    Le caylar (France)
    mathieu Jeantet
    How to boost an engine without turbo or hybrid?;):D
    of2worlds likes this.
  13. Scudmsl
    Scudmsl Formula Junior
    837
    Active back pressure reduction?
  14. Il Co-Pilota
    Il Co-Pilota F1 Veteran
    May 29, 2019
    6,023
    Hopefully some place nice.
    A.B
    Not likely? It's absolutely 100% impossible. Going by some very basic theory of torque potential means that 900 Nm is WAY above what's possible without assist. At if that was a 10000 rpm engine, that would pretty much result in 1150 bhp N/A.
    10000 rpm from a 6.5 litre V12 is in fact not far fetched. There are loads of engines out there that has much higher piston speeds. Valve events are what determines RPM and induction is what limits power. If the air is there and the cam timing is set up for high RPM, then high RPM is what you get.
    The challenge is not to make power, but to increase torque. Spin it faster and you make more hp as long as you don't have valve control issues or run out of cylinder head or intake runner volume. When you increase hp on the same basic platform, you do two things. You start by increasing efficiency if possible, thus make a bit more power at the same RPM, but that's usually very tricky. Then you increase valve lift and duration, thus raising RPM. That's what was done to the TDF. Same basic engine, just more aggressive cams basically.
    Making 900 Nm N/A from 6.5 litres is so far away from what anyone has ever done. It would basically mean that you reinvented the combustion engine.
    Now let's look at that pic again. We were all very adamant that it would not be hybrid, but take a look at those air intakes on the roof. Those are big, that's a lot of air. I'm thinking a ton of cooling. I cannot see any other purpose for those massive intakes.
    That air outlet in the front could be for at least two things. One is to reduce lift on the front, and the other is additional cooling. Remember that the engine compartment in these cars already run with a very hot engine compartment. There's a lot going on there and none of it point in the direction of a car with a mere 30-50 hp.
    I'm switching sides again. Back to some kind of N/A with electric assist. That much air inside the car looks like a ton of cooling to me.
    gzachary, F140C, dcmetro and 2 others like this.
  15. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    Could we please make a separate thread for these leaked pictures. Chances are that not all that have a car coming, are interested in having the surprise ruined by a thread full of "spoilers".
    456-boy and 355TDI like this.
  16. mthompson2376
    mthompson2376 Formula Junior
    Feb 2, 2017
    254
    North East England
    Mark Thompson
    Some of us were guessing some form of hybrid over a year ago
  17. Maximus1977
    Maximus1977 Formula Junior
    Feb 13, 2016
    324
    Let’s hope not.
    That would ruin our little party over here....
  18. NeilF8888
    NeilF8888 Formula 3
    Feb 10, 2005
    1,147
    Miami Beach
    I am really very excited by this “most aggressive street car Ferrari has ever built” (quote from a Ferrari representative) and can’t wait to see the actual unveiling.
  19. Lukeylikey
    Lukeylikey F1 Rookie
    3,085
    The rear cooling ducts are a bit confusing to me. They surely can’t be solely for styling? If you’re directly putting air onto the rear brakes or exhaust, there are much better ways than taking feed from the roof, mainly because you don’t need such a high quantity. If you need such high quantity to direct to the rear, what for? The rear of the car is a decent place to put a battery but what sort of battery needs that much cooling? To sacrifice the rear window is quite a thing, I can’t help but think there must be a reason for it. Just can’t think what it might be. This doesn’t look like an SF90-style hybrid. Could maybe be a new boost system using KERS, with some high performance spec that requires the cooling to be excessive? It seems the power will be high, given the 865 figure quoted (who knows if correct) and the front cooling - supposedly a much larger front intake and clearly much more bonnet/hood venting. If 10,000rpm the power jump will be significant and the noise, well, if you need to ask...
    A lot of power looks very likely from this leak. How exactly it’s delivered remains very puzzling.
    Il Co-Pilota likes this.
  20. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    Considering how good torque filling can improve a naturally aspirated cars response, I honestly don't see much of a downside to a hybrid. Imagine the glorious V12 but without the lack of response while the gearbox "think". You downchange and get on the throttle, but rather than lag while the engine revs up and things fall into place, you get instant response. If it is done right and the car can remain light, then it's just a plus.
    mthompson2376 likes this.
  21. crinoid
    crinoid F1 Veteran
    9,485
    LaCrinoid
    The 812 has ALWAYS been over-styled. A front engine car hardly needs an air intake on the C pillar. I wouldn’t put anything past FCS.
  22. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    My guess is that those intakes leads to battery and motor cooling, which can be air or liquid. It is definitely not for brakes and you don't cool exhaust.
    I wondering if the front duct is in fact a concept similar to the S-duct along with cooling.
    If not, it is always good to vent the engine compartment. A lot of resistance and lift is created by the air trapped in there.
  23. Lukeylikey
    3,085
    Something else; there’s no rear hatch. Presumably a small trunk lid per the GTS. The rear treatment promises to be very interesting, regardless of what the styling looks like.
    crinoid likes this.
  24. Lukeylikey
    3,085
    My first instinct was “a large s-duct” rather than the SP30 idea. But maybe it is indeed a mix of both. To cool a battery, which should be sited low in the chassis, why would you route from the roof and compromise the rear stowage area when you could take plenty of air from underneath or the sides? To cool the motor, say with liquid, that would be the reverse problem of the 365/512 BB and end up heating the cabin. It does seem to be a very aggressive car, in both styling and engineering terms. If the engineering is good and serves to deliver a really aggressive, good driving car, hybrid or whatever is in that thing won’t matter. It will be exactly what Enzo would have done.
  25. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    Those intakes are too big for that. That's a lot of drag for no other reason than styling. Not buying it, especially compared to the relatively small B-pillar intakes on the 812.
    From what I recall, those B-pillar intakes on the 812 are for the transaxle cooling. They are fully functional and a pretty clever way to get air into that area of the car without adding too much drag. This means that you can have cleaner air going under the car.
    Pretty elegant and simple solution.
