812 - Swapping seats | FerrariChat
Discussion in 'Technical Q&A' started by James5599, Jul 20, 2021.
  1. James5599
    James5599 Rookie
    Jul 20, 2021
    1
    James Sampson
    Hi everyone ,
    Hopefully you can help,
    I have a 812sf with standard seats , being tall I find them very uncomfortable , can’t get them low enough .
    I wanted to swap them for racing seats as I believe they go much lower ,
    i ve seen a set of 2019 -488 goldrake racing seats available for sale - question is are they compatible with the 812 ?!
    Thanks in advance for your help!
    best
    James
  2. windsock
    windsock Formula 3
    1,069
    Regardless of seats you choose you are going to need to reprogram the Proxi as manual/sport seats will be missing modules that the network is looking for. Using seats from another model will also likely result in airbag issues.
    Your best bet is to have a good upholstery shop shave some foam from the seat cushion to get you some additional clearance.
  3. plastique999
    plastique999 F1 Veteran
    Nov 9, 2008
    8,573
    SoCal
    Edward
    A little tangent, are 458 seats easy to switch with Speciale seats? Just plug and bolt ?
