812 GTS driver feedback please. | Page 8 | FerrariChat
Discussion in 'F12/812' started by khal360, Jul 27, 2020.
  1. SeattleStew
    SeattleStew Formula Junior
    983
    In the rain
    Stew
    Must be only a Ferrari problem. All my other cars seem to accurately state the redline on the tach that is published in the documentation.
    Also, we are talking about new cars here. If you want to talk about inaccurate tachs, go back to the forums with the 80s and older cars. These days the RPM signal being sent to a tach is accurate within something like .1%. That would be point 1%. The tach itself shouldn't be reading 200-400rpm off, there's a reason why they show an additional 1000 rpm. That way you aren't at the absolute maximum range of the tach, which is where you would tend to find some inaccuracy. Once again, new cars, very good electronics, and a multi-billion dollar manufacturer. I'd be willing to bet that the tach is incredibly accurate. Or at least not hundreds of RPM off
    ForeverCar likes this.
  2. ForeverCar
    ForeverCar Formula Junior
    Jan 20, 2017
    307
    Of course, this is a good reminder. Either way, these are observations that, hopefully, are helpful to some.
  3. REALZEUS
    REALZEUS F1 Veteran
    Feb 16, 2011
    7,669
    Bournemouth, UK
    No, it's a universal thing. If you plug in a can-bus module and record the actual RPMs, you will see that there is a difference (not by much, more like 200-300 RPM) between that reading and the analogue tach.
  4. BarryK
    BarryK Formula 3
    Dec 17, 2016
    1,160
    Europe
    Barry K
    Care to show any evidence to support that it is universal?
    Not universal at all in my experience. None of my modern cars show an systematic bias, of even a few hundred rpm.
    SeattleStew and ForeverCar like this.
  5. hs355
    hs355 Karting
    Feb 1, 2014
    110
    Sorry to answer quite late, but I have to tell you that I have Installed a capristo valve controller in my GTS (delivery August) From the very first day.
    Sound is incredibly much better with valves open (of course) and I only drive it that way (valves open from start to stop). There is no electronic problem or anything like it.
    Furthermore - if anyone cares (I do) - the start/stop device can be deactivated and remains deactivated. I did not expect that possible as it is different to my 812 SF, Pista and Portofino. But I love it...
    of2worlds, KenU and LMH like this.
  6. Avia11
    Avia11 Formula Junior
    864
    San Diego, CA
    I was told by 2 dealers that you would get a CEL if you opened up the valves. Does the capristo exhaust bypass that issue?
  7. junc
    junc Formula Junior
    501
    Chicago/Laguna Beach
    Jun
    Oh thats good news on the start/stop. Do you deactivate it through the menu on the dash?
  8. Il Co-Pilota
    Il Co-Pilota F1 Veteran
    May 29, 2019
    6,023
    Hopefully some place nice.
    A.B
    Good stuff.
    Do you have a part number for that Capristo controller? I have a Lusso kit sitting, and wonder if it is the same as used on the GTS. Would be great come feb:)
  9. KarlA69
    KarlA69 Formula Junior
    Oct 9, 2017
    759
    Karl
    I’m bringing my GTS in tomorrow for Novitec rear boxes, x pipe and Capristo controller. All taken from my 812 SF. Not expecting any CEL or other issues but will report back later this week.
    Also will report on the change in sound... can’t wait for some roof down, valves open action!
    of2worlds, Avia11 and LMH like this.
  10. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    Karl do you by any chance have the box with your Capristo controller sitting? If so, could you check and see what the part number on it says? Would be greatly appreciated:)
    Should be 04AZ00703002
  11. KarlA69
    Oct 9, 2017
    759
    Karl
    This is a pic, hard to read but I think the part number is virtually as you said
    KenU likes this.
  12. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    Ah sweet! If that works, I have a controller just waiting for my GTS:)
  13. ForeverCar
    Jan 20, 2017
    307
    Any experience with 100 or 200 cells catalytic converters (do they trigger CEL)?
    Are there options to remove GPFs and not trigger a CEL?
  14. JackCongo
    JackCongo Formula Junior
    781
    Jacques
    Yes, very good news. It is like this on my tdf but on.my pista spider it has to be turned off after every restart and I find it very annoying...
  15. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    Nobody has made a GPF delete yet. On a non-GPF car sport cats will trigger a CEL. Just install a Capristo OBD Wizard.
  16. ForeverCar
    Jan 20, 2017
    307
    Thanks. Would love to hear how a GPF delete and factory cat car sound eventually. They all sound fantastic so it is mostly fine tuning for personal preferences and recording can be hard to tell to.
    Does the Capristo OBD wizard basically monitor for the cats efficiency codes and auto clear them? That way, no ECU modification is needed.
  17. of2worlds
    of2worlds F1 World Champ
    16,475
    ON
    CH
    A.B did you go with Grigio Silverstone Opaco or something else in a paint color choice for your Gts?
  18. SeattleStew
    983
    In the rain
    Stew
    Would be curious if this is done in the settings on the car or if you had to have a dealer program it.
  19. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    Nope:)
    Verde Zeltweg w. Nero calipers and gold wheels.
    Thecadster, tomc, gliazzurri and 2 others like this.
  20. hs355
    hs355 Karting
    Feb 1, 2014
    110
    I didn‘t do anything - it was like that from the First Start. Maybe it is a special feature for cars delivered via Belgium to clients in Luxembourg , but honestly I don‘t know. My other cars need the button in the roof panel pressed after every restart, in my 812 GTS I did it once and it’s done...
    of2worlds and SeattleStew like this.
  21. SeattleStew
    983
    In the rain
    Stew
    Wow, that's very fortunate! I wish my 812SF would do that lol. I'm waiting for my next in person visit at the dealer to try and convince them to program it to always off. Otherwise I'll have to DIY it
  22. sampelligrino
    sampelligrino Formula 3
    Apr 16, 2017
    1,149
    sweet mother of God
    Thecadster likes this.
  23. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    Sooo, is that a good thing?...
  24. sampelligrino
    Apr 16, 2017
    1,149
    Very :) Sorry that was my initial reaction. Should have added - that is going to be one bella macchina.
    of2worlds likes this.
  25. gliazzurri
    gliazzurri Formula Junior
    Jun 11, 2016
    336
    Maryland
    You have any mock up photos of that to show? Sounds very interesting.
