$800 For a battery for an FF!!!!!!!! | FerrariChat
Discussion in 'FF/Lusso' started by msgm1, Sep 4, 2016.
  1. msgm1
    msgm1 Formula Junior
    Nov 4, 2003
    454
    NYC
    My 2012 FF needs a new battery the dealer just quoted me $800!!!!!!!
  2. AutobahnAndTrack
    AutobahnAndTrack Formula Junior
    Dec 31, 2014
    307
    Frankfurt, Germany
    Stefan G
    Why go to a dealer for a battery?
  3. Innovativethinker
    Innovativethinker F1 Veteran
    8,657
    So Cal
    Mark Smith
    for the battery, or for the battery, install, and inspection?
  4. imcarnuts
    imcarnuts Formula Junior
    362
    Steeler Country
    Duffy
    I replaced my battery myself in my 599 GTO (gone). The dealer told me to go to the Interstate battery store & get model # xxxxxx. Turns out I knew the manager from years ago. He gave me a small tour downstairs where they were labeling & boxing batteries. The same exact battery was receiving many different stickers - Mercedes, Toyota & Interstate were just three. There were others. Same battery just different sticker & box. He said they supply many different "OEM" batteries. Get the measurement of the battery or take it to an Interstate store and have them match it.
  5. ml321
    ml321 Formula Junior
    Aug 26, 2008
    254
    London/Munich
    From memory my battery cost sth like 650 euros, they fitted a stronger one as the stadnard battery is too weak (do I believe the story, possibly, but even if not the price difference was only 100 euros). Expensive it is, but figured no point in sorting it out myself if they already have the car and I need it back in working order
  6. msgm1
    Nov 4, 2003
    454
    NYC
    The diagnosis, the battery and resetting the computers...
    Seems excessive to me
  7. Brian L
    Brian L Formula 3
    Jun 17, 2015
    1,943
    Los Angeles
    Brian
    Never a dealer for a battery ....
  8. CrazyMD
    CrazyMD Formula Junior
    Mar 10, 2012
    404
    Southern California
    I put a battery in my FF for $200 and 30 minutes of my time.
    andyrichter likes this.
  9. msgm1
    Nov 4, 2003
    454
    NYC
    did you have to reset the computers?
  10. CrazyMD
    Mar 10, 2012
    404
    Southern California
    Of course not. There is just a way to lock/ unlock the doors the first time which is listed in the user manual and on many posts on this forum. Something like lock the doors, then press unlock once, open driver door. I can't remember and someone can chime in or you can look in the user manual.
    All you need if I recall correctly is a 10mm socket and an Allen wrench to open the few Allen screws holding the trim piece and having a friend helps because the battery is heavy.
  11. Solid State
    Solid State F1 Veteran
    9,639
    Maximus Decimus Meridius
    I paid $3,400 for a cup holder but couldn't forgive myself if I didn't swap a battery myself outside of warrantee. Of course, if you've never done it many, many times before on other cars then that's a different story.
  12. kylec
    kylec F1 Rookie
    3,574
    Orlando
    Johnson Controls makes most batteries.
  13. DK308
    DK308 F1 Rookie
    Aug 13, 2013
    2,738
    Europe, way north.
    AB
    Just get a quality battery and do it yourself. The Farrari supplied batteries are crap and a ripoff. Consider a good dry cell battery. It's better for the car in the long run. Alternatively you can get a Braile lithium battery and save a lot of weight. Some members here are using them with great results.
    800 for a new crappy battery at a dealer? Good grief.
  14. imcarnuts
    362
    Steeler Country
    Duffy
    Correct. When the Mercedes, Toyota, etc. is new it does not have the Interstate battery. Interstate supplies many replacement batteries to dealers with the factory branding on them.
    That is why OEM was in "" Probably was not clear on that.
  15. AutobahnAndTrack
    Dec 31, 2014
    307
    Frankfurt, Germany
    Stefan G
    Ok, this adds up to way more than $800. But nevertheless maybe you had some priceless fun swaping the battery.
  16. otakki
    otakki Formula 3
    Mar 24, 2016
    1,624
    Where did you buy the battery from? What's the battery brand and model number?
  17. CrazyMD
    Mar 10, 2012
    404
    Southern California
    I can go take a picture. I believe pep boys and it's a Bosch. Will take a photo and post
  18. ttforcefed
    ttforcefed F1 World Champ
    18,874
    that's ok - it builds character. welcome.
  19. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    I paid about £70 for a 75Ah battery for a 430 and it works fine. I see a lot of crazy prices quoted but if the battery starts the car and will start the car with the headlights on, then it is doing its job.
    Cannot see how anyone thinks a battery costs hundred of pounds or dollars is better than other make.
    I have been using standard batteries in a ferrari for over 23 years.
  20. Brian L
    Brian L Formula 3
    Jun 17, 2015
    1,943
    Los Angeles
    Brian
    As long as it's the quoted Ah rating, any battery brand will do ... but the modern cars need the full juice.
    They have all kinds of things running when the car is parked, that's why they need a charger every week or two if not driven.
    430 is more analog, today more digital.
  21. PAP 348
    PAP 348 Nine Time F1 World Champ
    Dec 10, 2005
    99,342
    Mount Isa, Australia
    Pap
    The Brother is a Diesel Mechanic and I am a car Mechanic. We have seen it all in regards to batteries. lol
    His 2005 BMW 750Li required a new battery around 3 years ago. It came up on the display screen telling him the battery needed to be replaced.
    The battery was 8 years old and it was the original OEM battery in the car as it was dated early 2005 and the car was a late 2005 build.
    He called the dealer and they told him the warning is there in place to tell you to change the battery asap as it will eventually leave you stranded.
    No worries the Brother told them, said he will go and buy a battery tomorrow from our local battery shop.
    The BMW dealer advised against this telling him he will not find a battery the same physical size that will have the same CCA rating.
    His battery is slightly larger than normal and it has a HUGE 1200CCA output. For a battery that size, they only come in 600-800 CCA ratings here in Australia.
    So it's going to be well down on CCA if he tries to match one up locally. We can get a 1200CCA battery, but it will definitely not fit into that small battery space in the boot.
    The dealer then told him that the 7 series cars have a big electrical system in the car and if he does decide to fit a smaller CCA rated battery that it just won't last.
    The big loads put on that battery will kill it within a year or less. They have been there and done that already with other customer cars over the years they told him, it's not worth the effort fitting a non-OEM battery in these cars.
    Better off buying a genuine BMW *Bosch* battery and it will last another 8 years before it will put up another warning on the dash.
    Because we know a lot about batteries, electrical loads and charging systems etc, the Brother agreed to buy an OEM BMW battery for his car.
    $800 Aussie dollars for the battery! Lol
    He was happy to pay though. They sent the battery out from Townsville which is our nearest BMW dealer from here, around 600 miles away.
    We fit it and it was still flashing the battery warning light in the car. He called the dealer again and they told him they need the car there to reset that light with their scan tool.
    So when the Brother went to visit his in-laws a few months later, he went past the dealer and they reset that warning light/code for him and dated it the same day the battery was fitted.
    He sold that car around 2 years later, *earlier this year* and never had a problem with it.
    He kept the old battery and it's still going strong at home. We use it to jump start everything from the kids motorbikes to cars. It just keeps going. Lol. An 11 year old battery now.
    The Brother keeps a battery tender on it to keep it fully charged. We have never checked the CCA rating to see if it's dropped a cell, but we should as I have a tester here.
    This is just an interesting story I thought I would share. Good luck with whichever battery it is you want to fit to your car mate.
  22. otakki
    otakki Formula 3
    Mar 24, 2016
    1,624
    Thanks. Looking forward to seeing the picture.
    Thanks for the infos. I think as long as a battery is connected to a smart trickle charger that also desulfates, the battery can last for a very long time. Even though most batteries are made by a few manufacturers and simply labeled differently, I wonder why the oem battery chosen by Ferrari is so weak and sub-standard in quality.
  23. PAP 348
    Dec 10, 2005
    99,342
    Pap
    Yeah, not sure why the battery in this FF only lasted bugger all. A little disappointing to see.
  24. MalibuGuy
    MalibuGuy F1 Veteran
    Sep 18, 2007
    5,280
    Sometimes I get a $0.99 cup of coffee at the drive thru. I frequently stow it in the cup holder.
    I apologize!
    Though I feel better about buying a $800 battery.
  25. willcrook
    willcrook Formula 3
    Feb 3, 2009
    2,139
    the standard FF battery is awful
