599 Tire Choice | Page 4 | FerrariChat
599 Tire Choice
Discussion in '612/599' started by 500drvr, May 16, 2014.
  1. phil the brit
    phil the brit Formula 3
    Jul 7, 2013
    1,215
    Colchester+Clermont
    Phil Taylor
    Correct me if I am wrong but surely the HGTE came out with a softer tyre than a standard 599.
  2. MaseratiCorse
    MaseratiCorse Formula Junior
    Nov 13, 2014
    472
    Melbourne, Australia
    Nicholas
    I think it was P Zero Corsa System compound in the normal P Zero tread pattern.
  3. MrF355
    MrF355 Formula Junior
    Mar 4, 2008
    493
    Kimi
    I am running Michelin Pilot SPort Cup 2 tyres on HGTE rims 245 35 20 at the front and rears are 325 30 20. No problems with this set up and the wider rear tyre has improved rear traction on acceleration and cornering. Excellent tyres but they do wear quickly and are not to be used in the wet.
  4. Rotti
    Rotti Rookie
    Feb 27, 2013
    20
    Canberra
    Alex
    Those tires are huge! Do they cause any problems with the e diff and traction control? I have GTO rims on my '08 GTB and my dealer will not put the GTO tires on (285 front, 315 rear) as they say it will upset the e diff and potentially be unsafe. The front 255's look pathetic on the GTO rim, as the rim is wider, though the 305 is less noticeable on the rear GTO rim in terms of width mismatch.
  5. DK308
    DK308 F1 Rookie
    Aug 13, 2013
    2,738
    Europe, way north.
    AB
    Tyre width and rim diameter will NEVER cause any electronic issues. There's only one way you can get a problem, and that is if the wheel speed sensor gets confused. This means you need to keep the front to rear diameter bias within +/- 3% of OE. The car will never know how large the tyre diameter is, can't know the rim diameter, nor will it know about the tyre width. The only thing the car systems can know, is whether the front and rear wheels spin within a certain margin in relation to each other. If they keep the OE front to rear diameter difference %, you can make the tyres as wide as you like, the rim diameter the size of wagon wheels and the rubber the diameter of monster truck tyres. Just keep that front to rear diameter in check.
    If your dealer, tech or know-it-all car buddy tells you anything else, roll your eyes and change the subject.
    George Vosburgh likes this.
  6. TheBluesMan
    TheBluesMan Rookie
    Dec 16, 2018
    22
    Santa Monica
    Ira Boren
    I have a 2009 599 GTB. After a nationwide search I can't find the MPSS in 305/35/20's. I'm interested in following up with the suggestion to use 315/35/20. It appears that this size would change the speedo read by .5% - 1%. Quite insignificant, but I wanted to know if you're aware of anything else to consider. Also, since this size is manufactured for various vehicles, it's profile is actually different for different cars. Do you know which would be the ideal choice for Ferrari?
    Thanks!
  7. TheBluesMan
    TheBluesMan Rookie
    Dec 16, 2018
    22
    Santa Monica
    Ira Boren
  8. Skidkid
    Skidkid F1 Veteran
    8,682
    Campbell, CA
    John Zornes
    I just put on MPS4S in 315/35 and 245/35. It is what I was running before in MPSS and there are no issues. Got them from TireRack in 2 days and the date codes are only about 6 months old.
  9. TheBluesMan
    TheBluesMan Rookie
    Dec 16, 2018
    22
    Santa Monica
    Ira Boren
    Thanks skidkid for confirming that. Did you happen to order by size alone, or did you specify a Ferrari specific tire?
  10. jimshadow
    jimshadow F1 Veteran
    Feb 19, 2006
    5,743
    Indiana
    JIM
    Talk to someone at the Tire Rack. I just ordered a set of 255/35/20 fr & 315/25/20 rear for my /07 599 two nights ago. The rears will be in on 3/26/21 and I’ll pick them up the following weekend/have them install. (I’m in Indiana). They have several coming in after a nationwide temp shortage of the tires.......
  11. tazandjan
    37,984
    That was an old post, I would definitely recommend the MPS4S now, and they are available in 305/35 20 now, although no problem fitting GTO size 315/35 20. They are nowhere near large enough to bother the ABS, which freaks out somewhere around 4-5% difference from stock front to rear diameter differential.
    My 575M has MPS4S tires.
    Hawkeye likes this.
  12. Skidkid
    Skidkid F1 Veteran
    8,682
    Campbell, CA
    John Zornes
    You went 315/25 and 255 up front? Why that selection? It looks a bit odd.
  13. tazandjan
    37,984
    One size up on both fronts and rears, I assume. Here is hoping he meant 315/35 and not 315/25 or the ABS is not going to be happy.
    Skidkid likes this.
  14. Skidkid
    Skidkid F1 Veteran
    8,682
    Campbell, CA
    John Zornes
    I just ordered them last Thursday and they were at my mechanic on Saturday. As I recall, the rears are a Ferrari spec and the fronts are not. Honestly, I think most are WAY over thinking this. Yea, if I am pushing 99% on a track I might care but you won't even be able to tell the difference on the roads. The primary difference is tread depth/wear rating.
  15. Skidkid
    Skidkid F1 Veteran
    8,682
    Campbell, CA
    John Zornes
    But front stock is a 235 as I recall. 245 is one up as is 315. 255 would be 2 up.
  16. tazandjan
    37,984
    John- 245/35 is OEM.
    Tyres for HGTE package Inflation pressure (cold)
    Pirelli P Zero 245/35 ZR20 305/35 ZR20 32 psi (2.2 bar) 29 psi (2.0 bar)
    Skidkid likes this.
  17. TheBluesMan
    TheBluesMan Rookie
    Dec 16, 2018
    22
    Santa Monica
    Ira Boren
    Thanks everyone. It helped a lot! I’ll get a set ordered on Monday.
  18. odf911
    odf911 Formula Junior
    Nov 30, 2013
    520
    London UK (Chelsea)
    Olivier
    I have the GTO wheels and tires 285/315 k1 and no issue with the car. I had 255 before and I agree they look too small. The added grip is also a benefit here.
  19. jimshadow
    Feb 19, 2006
    5,743
    Indiana
    JIM
    Oh man, sorry for the confusion!! Yes, 255/35/20 on the front and 315/35/20 on the rears.
    Skidkid and DZ-96 like this.
  20. DZ-96
    DZ-96 Formula 3
    1,775
    South Germany
    Daniel
    That is the best choice for the Monolitic and HGTE rims.
    Daniel
    Skidkid and George Vosburgh like this.
  21. Hawkeye
    Hawkeye F1 Veteran
    7,462
    #96 Hawkeye, Mar 14, 2021
    I'm just not a fan of Pirelli tires for the 599, Michelin is on another level IMO, Pilot Sport4S is the choice.
    C4YES likes this.
  22. Justin Hughes
    Justin Hughes Karting
    153
    Oxfordshire - UK
    Hughesie
    Just ordered a couple of new rears for our Euro trip in May to the South of France. 315/35/R20 MPSS K spec from Cam Skill in the UK, £540, + £50 off from Michelin so £500 delivered and I'll get my local guy to fit them before we head off.
    Currently have 3mm left on the rears and 5 on the fronts.
  23. duxducis
    duxducis Rookie
    Nov 29, 2016
    25
    I have just installed Michelin Pilot Sport 4S, 245/35/20 K2 front and 315/35/20 K1 rear on Challenge wheels.
    Many posts suggesting 255 front tyre should be installed on minimum 8.5J rim and not on 8J rim, but don't we have similar situation rear, where 315 is installed on 11J rim instead of minimum recommended 11.5J ? Image Unavailable, Please Login
  24. tazandjan
    37,984
    Not sure where you got that info, but the recommended wheel widths for the 245/35 20s are 8-9.5" and for the 315/35 20s are 10.5-12.5", so you are fine.
  25. George Vosburgh
    George Vosburgh F1 Rookie
    It looks fabulous! Very similar to mine. Is your car lowered?
