599 Shocks | Page 4 | FerrariChat
599 Shocks
Discussion in '612/599' started by Hawkeye, May 22, 2013.
  1. tazandjan
    38,087
    George- No, the 599 was the first Ferrari with Magneride shocks. Optional on the California, too.
    G. Pepper likes this.
  2. Da Butcher
    Da Butcher Karting
    Jan 9, 2018
    211
    Jose Marie Alandy
    Gents FYI - the Magnetorheological shocks' design on the 599 (and all Ferrari thereafter as option or standard) was sourced by Ferrari from GM / Cadillac (or Delphi as manufacturer) which originated / patented the design. The shock body carries hydraulic fluid with floating / suspended magnetic particles that via electrical impulses can be instantaneously hardened (stiffened) or softened.
    Ferrari chose this design rather than use an air type suspension system (similar to the design of the Mercedes-Benz ABC on their passenger cars) because Ferrari's desire for much quicker action / reaction for its sports / GT cars.
    I would guess that the premature leakage of these magnaride shocks has to do with elastomer and/or thermoplastic seals that may deteriorate due to the combination of exposure to the type of hydraulic fluid used along with activating electrical impulses and exposure to external incompatible contaminants. Having worked myself in aerospace, space and motor racing hydraulic system designs for decades, it is a fact that modern sealing systems still remain to be sometimes a compromise given the variety of factors in which the materials are exposed to. Often, long-term lab testing may show positive results based on a given set of test parameters, but which may not hold up in actual long-term road or real world application!
    Temuri, LightGuy and Makuono like this.
  3. dc348
    dc348 Formula Junior
    May 27, 2006
    384
    Luckily back in HK
    DC
    Hi HK Mondial, PM sent. Perhaps a group buy!
    My right front has a small leak and am told the fronts are on back order.
  4. Motorama
    Motorama Karting
    Jul 10, 2018
    157
    Stijn Van Loffelt
    Did anyone got theirs rebuild After all or not?
  5. Tridentity
    Tridentity Rookie
    Nov 14, 2011
    14
    Madrid, Spain
    Not news about the Poland company rebuild?
  6. Luxury Collection
    Nov 24, 2017
    3
    Finland
    Harri Järvinen
    Update on my case.
    We decided to change all four shocks. One of the them feels alright on the hand, three of them are rock hard.
    After replacement everything works alright.
    I presume that the one that moves is actually the one that is broken and the three other was adjusted hard by the control unit. For some reason the control unit couldn't adjust them back to normal, or either give fault code.
    I have this set of shocks in stock, i am also interested if someone knows how to repair them.
  7. Motorama
    Motorama Karting
    Jul 10, 2018
    157
    Stijn Van Loffelt
    I called them. 350 plus vat a pièce. I ll send mine thid winter
  8. LightGuy
    LightGuy Three Time F1 World Champ
    39,949
    Texas
    David
    Thats cheap.
    But for a few Euros more one could convert to normal shocks and be done with it.
  9. Mor
    Mor Karting
    Oct 14, 2017
    95
    Today I’ve checked mine front suspension cos I hear some noise. Front right shock is out though no leakage. Sometimes **** happens.
    Wysłane z iPhone za pomocą FerrariChat
  10. Motorama
    Motorama Karting
    Jul 10, 2018
    157
    Stijn Van Loffelt
  11. Skidkid
    Skidkid F1 Veteran
    8,762
    Campbell, CA
    John Zornes
    Looking forward to a report when they get back.
  12. George Vosburgh
    George Vosburgh F1 Rookie
    I got the bad news yesterday that my left front has a slight leak. I'll drive it for a while until it gets worse.
  13. afwrench
    afwrench Formula Junior
    Nov 24, 2004
    593
    NY
    In addition to my 599 I have a 1971 365gtc4. The C4 comes standard with a rear load leveling shock that is also prone to failure. While they can be repaired ,Koni makes a coil over replacement that works great. I put a set on years ago and have not looked back. Do we have a cost effective conventional 599 replacement that anyone in the community has used with satisfaction? Mike
  14. George Vosburgh
    There is a conventional shock but it won't function with all the electronics in the suspension. Fernando at Competizione & Sportscar says "don't do it".
  15. Motorama
    Motorama Karting
    Jul 10, 2018
    157
    Stijn Van Loffelt
    Rex71, HK Mondial, Skidkid and 3 others like this.
  16. Skidkid
    Skidkid F1 Veteran
    8,762
    Campbell, CA
    John Zornes
    Looking forward to a report once they are installed.
  17. afwrench
    Nov 24, 2004
    593
    NY
    Much anticipation from me as well. Can you give a run down on the install procedure and calibration? I am sure we would all appreciate it. Thanks ,Mike
  18. Motorama
    Motorama Karting
    Jul 10, 2018
    157
    Stijn Van Loffelt
    It's basicly a Bolt off bolt on procedure. Only the pre tention can be adjusted
  19. afwrench
    Nov 24, 2004
    593
    NY
    Thanks, no issues with the electronics? Plug back in ? Is there a need to reset anything? Mike
  20. Rex71
    Rex71 Formula Junior
    Mar 24, 2007
    353
    Jeddah,Saudi Arabia
    Majd B.
    I am also very interested in hearing the updates .
  21. Motorama
    Motorama Karting
    Jul 10, 2018
    157
    Stijn Van Loffelt
    When i reinstalled the shocks it said suspension control system error. I forgot to disconnect the battery before the removal. But the next day everything was fine again. The only thing i m gonna do is letting someone alline every shock so there is the same weight on every wheel. Should be fixed then. It was about a 5 hour job
    Skidkid likes this.
  22. br110
    br110 Rookie
    Nov 10, 2014
    4
    paris
    bernard
    Hello Motorama,
    Thanks for your help to propose a cheap solution for the leaking shock.
    Do you still have the active damping system with your regenerated shocks in place?
  23. Motorama
    Motorama Karting
    Jul 10, 2018
    157
    Stijn Van Loffelt
    yes, works fine... Like before..
  24. afwrench
    Nov 24, 2004
    593
    NY
    Does this company attach a warrantee with the rebuild? Mike
  25. Motorama
    Motorama Karting
    Jul 10, 2018
    157
    Stijn Van Loffelt
