599 gated stick manual Official picture thread | Page 9 | FerrariChat
Discussion in '612/599' started by Zarathustra, Mar 20, 2015.
  1. brogenville
    brogenville Formula 3
    2,252
    Robin
    Think you're wide of the mark there Taz. I can promise you that the electrical systems on the early 612's are a lot more complex than on 575's. Mechanically, the conversion is the same for whatever year of 612; the difficulty all comes down to the electronic programming. Clearly some people have got it to work, to some extent at least.
  2. tazandjan
    39,141
    Robin- Early 612s were Motronic 7.1.1, just like the 575M. Later ones were Motronic 7.3.2 and that makes a difference. There were Motronic ECUs for F1 and 3 pedal 612s, just like there were for the 575M. The programming is no more difficult than it was for the 575M and actually much simpler since the 612 is set up for reflashing through the OBD II connector and the 575M was not. On the 575M, you just replace the Motronics with the 3 pedal versions and the same thing will work for 612s. Reflashing, though, should be much simpler for a 612. So I think you have it backwards, the 612 is actually easier to reprogram than the 575M. All the rest of the 612 electronics have little to do with the basic Motronic interface for F1 or 3 pedals.
  3. brogenville
    2,252
    Robin
    Taz, fully respect your expertise, but there are quite a few errors in what your saying.
    I have a 2005 612, and having read the ecu’s (flash and eeprom), I can tell you that it isn’t a 7.1.1. I’ll open the file tomorrow and share a screen capture if you want- from memory it’s a 7.3.4... I think. I’ll need to check. I can also confirm that the security protocols in place prevent you from accessing the flash over OBD, at least until some re-coding has been done to allow this. Unless you have the Ferrari kit, you need to go in via boot mode, which means getting into the ecu. Again- talking from experience here!
    As for the coding itself, the motronic is indeed configured for either f1 or manual, which only comprises setting (i understand) 4 config words from f1 to the correct manual setting. That’s it! Do that and the engine will run fine in manual mode after the conversion. That’s sadly far from the full story, as the body ecu, abs ecu, and dash ecu are all still going to be in f1 mode. So, the car will run, but will shut down after a predetermined period if it doesn’t see a TCU present. You can leave the TCU in, but clearly you’re going to get all kinds of errors on the dash.
    None of this is impossible to solve, but trust me on this, converting a 612 is more complicated than a 575.
  4. tazandjan
    39,141
    #204 tazandjan, Oct 21, 2019
    Robin- I will take your word for it. Let me know about the Motronic ECUs. Early 599s were 7.1.1 and I thought early 612s were, too, from the tech data I have seen. Will have to look and see if there are separate ECUs for F1 and manual for the other functions. Does not make much sense to tie all those together differently except for the gear display, but who knows? Not the case on the 599, and the two are generally similar. F1A was used on the Superamerica, too, using 7.1.1.
    Knew I had seen that somewhere. Here is the 612 WSM page for the early 612. I thought 612s went to 7.3.2 along with the 599, but if they went to 7.3.4 earlier than the 599 went to 7.3.2, that would be good to know.
  5. brogenville
    2,252
    Robin
    Hi Taz,
    I’ll open the flash file later and confirm for you.
    Another reason I’m so confident is that the ecu reader I was using appeared to be working fine in 7.1.1 mode, but i noticed it was only downloading 512k (flash) files. The 612 uses 1mb flash files, so it was truncating them. Switching to 7.3.4 (again, I’ll check this) and it gave me the full 1mb files.
  6. brogenville
    2,252
    Robin
    Info from driver side ecu from my 2005 612 F1.
    F137 - Model code for 612 chassis
    Me7.2.3
    Just a guess, but I assume 09/11/04 is the date that the file was created by Ferrari. Makes sense as my car was delivered early in 2005.
    (shows how good my memory is!)
  7. Zaza
    Zaza Formula Junior
    Jul 27, 2017
    636
    Brittany & Indonesia
    Xavier
    Hi Gary, pls delete #166146 from the list, mistake from a listing. I had access to Dutch registration details and it is a F141 AB E = F1 gearbox.
    Also access to #162945, also Dutch, which is F141 AB M = real manual.
  8. Zarathustra
    Zarathustra Formula Junior
    May 7, 2006
    875
    Hawaii
    Gary Robinson
    Zaza, thank you for your contributions!
    Updated Ferrari 599 Manual Registry:
    146539 Giallo/Dark-Gray (Euro)
    148702 Black/Black (Euro)
    149311 Titanio met/Blu (Euro)
    149428 one-off Zagato re-body
    150332 Red/Black (Euro)
    150335 Black/Tan (Euro RHD)
    150338 Red/Tan
    150345 Black/Black
    150346 Red/Black
    150549 Black/Black
    150551 Silverstone/Tan
    150620 Red/Black
    150621 Black/Black
    150861 Silverstone/Black
    150863 Black/Black
    150866 Blue Tdf/Grey
    151006 Black/Black (Euro RHD)
    151275 Black/Black
    151564 Red/Black (Euro)
    151849 Red/Tan
    151850 Blue/Tan
    152365 Rubino/Tan
    152366 Red/Tan
    152969 Silverstone/Tan (Euro)
    153027 Silverstone/Tan
    153378 Red/Crema
    153722 Red/Black (Euro)
    153876 Silverstone/Tan
    156243 Titanio met/Tan (Euro)
    156616 Silverstone/Tan
    157523 Black/Charcoal (Euro)
    157988 Green/Black (Euro)
    158461 Fiorano Rosso/tan
    159182 Blue/Red (Castriota's one-off?)
    159626 Red/Tan
    159976 Silver/Red-black
    160180 Blu Mirabeau/Tan (Euro)
    162942 Pozzi/Tan
    162945 Blu Tdf/Blue (Euro)
    164473 Black/Black (Euro)
    166663 Vinaccia/Tan (Euro)
    167583 Titanio/Grey (Euro)
    167772 Black/Tan
    167984 Red/Black (Euro)
    170628 Black/ Black
    172283 Rubino/Tan
    182296 Black/beige
    182599
    Total: 48
    19 Euro & 29 USA
  9. Sturm59
    Sturm59 Formula Junior
    338
    Hi Guys,
    #150866 is Blue Mirabeau, NOT TDF
    https://www.carriagehousemotorcars.com/2007-ferrari-599-gtb-fiorano-6-speed-manual-c-227.htm
    Zaza likes this.
  10. Zaza
    Zaza Formula Junior
    Jul 27, 2017
    636
    Xavier
  11. Zaza
    Zaza Formula Junior
    Jul 27, 2017
    636
    Xavier
  12. Zarathustra
    May 7, 2006
    875
    Hawaii
    Gary Robinson
    150338 Red/Tan
    150345 Black/Black
    150346 Red/Black
    150549 Black/Black
    150620 Red/Black
    150621 Black/Black
    150863 Black/Black
    150866 Blue Mirabeau/Grey
    151275 Black/Black
    151849 Red/Tan
    151850 Blue/Tan
    152365 Rubino/Tan
    152366 Red/Tan
    153378 Red/Crema
    159626 Red/Tan
    162942 Pozzi/Tan
    167772 Black/Tan
    170628 Black/ Black
    172283 Rubino/Tan
    182296 Black/beige
    182599
    Unknown SN red/black RHD HGTE Japan registered.
    Total: 49
    20 Euro / Japan & 29 USA
    Non-factory Ferrari 599 F1 conversions to manual:
    152979
    160463
    Sturm59 and Zaza like this.
  13. Sturm59
    338
    There are 2 converted cars? I only saw the red with tan leather.
  14. Zarathustra
    May 7, 2006
    875
    Hawaii
    Gary Robinson
  15. Zarathustra
    May 7, 2006
    875
    Hawaii
    Gary Robinson
  16. Zaza
    Zaza Formula Junior
    Jul 27, 2017
    636
    Xavier
  17. Zarathustra
    May 7, 2006
    875
    Hawaii
    Gary Robinson
    Dang you're good!
  18. Zaza
    Zaza Formula Junior
    Jul 27, 2017
    636
    Xavier
    159626 Red/Tan
    Total: 49
    [/QUOTE]
    159626 a Canadian manual is also the second "one-off" Zagato re-body spyder registered in England, no more Red/Tan but Pale Blue/Purple
    Sturm59 likes this.
  19. Sturm59
    338
  20. Sturm59
    338
    159626 a Canadian manual is also the second "one-off" Zagato re-body spyder registered in England, no more Red/Tan but Pale Blue/Purple[/QUOTE]
    https://ferraris-online.com/cars/2008-ferrari-599-gtb-fiorano-hgte-159626/
    https://en.wheelsage.org/ferrari/599/zagato_599_gtz_nibbio/zagato_599_gtz_nibbio_spyder/pictures/cw0w16/
    https://exclusivecarregistry.com/ferrari/599gtznibbiozagato/1391920190725230753
  21. Zaza
    Zaza Formula Junior
    Jul 27, 2017
    636
    Xavier
    I do not know if it is a fake but it is noted as a conversion :
    "6-Speed Manual Transmission (conversion by EAG)2008 Ferrari 599 GTB Fiorano Nero (Black)" and S/N is 160463 which is a F1 - you already mentionned it as a conversion. It is true that the background of the car and the background of the gear level is different.....
  22. Zaza
    Zaza Formula Junior
    Jul 27, 2017
    636
    Xavier
  23. Zaza
    Zaza Formula Junior
    Jul 27, 2017
    636
    Xavier
    456-boy likes this.
  24. Sturm59
    338
    #225 Sturm59, Dec 17, 2019
