599 Fuel pump | Page 2 | FerrariChat
599 Fuel pump
Discussion in '612/599' started by HK Mondial, Sep 27, 2018.
  1. Samuel Misrasi
    Samuel Misrasi Karting
    Jun 7, 2019
    61
    Clinton, Utah
    Samuel Misrasi
    Same/similar design, but different plastic. Originals are white, new replacements are yellow. Time will tell if the replacements will fail too. My originals lasted 13 years. I would be just fine with the replacements lasting that long.
    George Vosburgh likes this.
  2. afwrench
    afwrench Formula Junior
    Nov 24, 2004
    593
    NY
    Hi Sam ,where did you source the pumps and any special tools required? Ring nut hand tighten or wrench needed? Thanks ,Mike
  3. Samuel Misrasi
    Jun 7, 2019
    61
    Clinton, Utah
    Samuel Misrasi
    I bought the pumps from Ricambiamerica.com, and I used a coupon code from the “Normal guy supercar” YouTube channel for a little bit of a discount. No special tools needed. Everything unclips and unscrews like a normal car. The ring nut is plastic, and I tightened it by hand, then used a hammer and a punch to snug it up. The pump housing and the tank are notched, so they only fit one way. It really is an easy job, if you’re a do-it-yourselver.
  4. afwrench
    Nov 24, 2004
    593
    NY
    Thanks man, sounds like a job to do proactively . Mike
  5. gphodge
    gphodge Karting
    144
    Washington
    Sam,
    I don't know what discount code you used to get them both for $400 from post #19 but 6 months later they are $636.56 ea for 181204 and 181205. Inquiring minds want to know how to get them that cheap.
    https://www.ricambiamerica.com/car-diagrams/ferrari/v12/gt-group-2-seat/599/fuel-pump.html
  6. bamaman
    bamaman Formula Junior
    Nov 27, 2015
    650
    Mobile Alabama
    William M (B.J.) Lyon, Jr.
    Sam where did you source the pumps? Thanks
  7. FNCOOL
    FNCOOL Karting
    98
    UAE
    GEZEN BILIR
    These part numbers are listed both for Ferrari and Maserati 4200 but significantly cheaper if sourced as Maserati part. I checked Eurospares but none in the stock.
  8. Samuel Misrasi
    Jun 7, 2019
    61
    Clinton, Utah
    Samuel Misrasi
    I bought them from Ricambi. I haven’t checked lately, but I’ve heard the price went up quite a bit.
  9. bamaman
    Nov 27, 2015
    650
    Mobile Alabama
    Thanks, very helpful. About $600 each. Typical
  10. swift53
    swift53 F1 Veteran
    6,729
    E.S.
    Alberto
  11. ferrari599lou
    ferrari599lou Rookie
    Feb 5, 2021
    1
    Louis J Puig
    Hello Samuel. I would like to change my 599 pumps but fuel started squirting out from the fuel line when I disconnected it from the pump cap. How do I stop this? Disconnect the battery? Please Email me at [email protected] or call me at 3059512839. Thanks
  12. swift53
    swift53 F1 Veteran
    6,729
    E.S.
    Alberto
    Disconnect the battery. Bleed the rails, as there is leftover pressure. Of course, when you open the door,
    the fuel pumps start so possibly your does too. . Careful with auto windows and leave trunk open.
    There are a lot of booby traps to the uninitiated. I got stuck with my trunk shut and the battery
    disconnected, had to energize the system with another battery to the starter motor.
    You might also wait a few days. Mine squirted, so I just dried out the fuel
    by installing secondary hoses to drain any left over fuel.
    Mine is a Maserati, same fuel pumps. Best to buy from the UK.
    Regards, Alberto
  13. swift53
    swift53 F1 Veteran
    6,729
    E.S.
    Alberto
    Mine from Eurospares, or Scuderia UK. Both super reliable and less than $500 including shipping.
    Regards, Alberto
  14. tazandjan
    38,054
    The pros usually drain the tank, but not many of us have a place to drain it.
  15. swift53
    swift53 F1 Veteran
    6,729
    E.S.
    Alberto
    Easier said than done :)
    Where would you drain it from? Into 2, 18 gallon plastic ones, cheap and easy.
    In the case of the Maser, you have to remove the filler neck and that one, is a real doozy.
    When I did find the leak the tank was full, try shuffling it around the trunk, in a 599 might be easier :)
    Regardless, in my case, major pain in the rear.
    Regards, Alberto
  16. Ahtim
    Ahtim Karting
    Nov 8, 2018
    92
    HK/China/England
    W
    Is this a common problem on GTOs? Mine has done 11000km. Thanks a lot
  17. bamaman
    Nov 27, 2015
    650
    Mobile Alabama
    Is the parcel shelf easy to remove in the 599???
