550 trunk struts | FerrariChat
550 trunk struts
Discussion in '456/550/575' started by bobwass, Jun 28, 2020.
  1. bobwass
    bobwass Karting
    145
    Los Angeles
    Bob Wass
    my 1998 550 trunk struts are exhausted and can no longer hold open. i ordered new ones but how do I install them without cracking the factory paint on the mounting studs? is there a 'trick'? anyone deal with this in the last 22 years?
    Sent from my Pixel 3 XL using FerrariChat.com mobile app
  2. ferraridriver
    ferraridriver F1 Rookie
    Aug 8, 2002
    4,137
    Bay Area Calif.
    Dave
    There is a small clip on each rod end, pry it open and pull out, then the rod ends will snap off the mounting studs
    Qavion, wbklink and 308 GTB like this.
  3. wbklink
    wbklink F1 Rookie
    3,315
    Los Angeles
    Bill Karp
    haha good old Dave !
  4. bobwass
    bobwass Karting
    145
    Los Angeles
    Bob Wass
    duh? i knew there was a simple answer. my bad.
  5. 308 GTB
    308 GTB F1 World Champ
    11,189
    New Jersey
    Barry Wolinsky
    Bob,
    Now that you got your new struts installed, how would you like to have your trunk lid open at the touch of a button on your key remote? Dave can help you with that as well. :)
    Barry
  6. ferraridriver
    Aug 8, 2002
    4,137
    Bay Area Calif.
    Dave
    Not anymore, I'm not doing those anymore, I'm happy to share a pic but that's about all I have, no schematic.
    Qavion and Il Tifoso like this.
  7. 308 GTB
    11,189
    New Jersey
    Barry Wolinsky
    Well, he'll just have to do it the old-fashioned way. At least now his trunk lid will stay open. :)
  8. bobwass
    bobwass Karting
    145
    Los Angeles
    Bob Wass
  9. 308 GTB
    11,189
    New Jersey
    Barry Wolinsky
    The same retention clip is found on each end of the strut, Bob. Remove them both...
    Your new struts came with pins 57 and 58 attached with those same clips. You can also replace your existing pins if you'd like or just replace the struts.
    Barry
  10. bobwass
    bobwass Karting
    145
    Los Angeles
    Bob Wass
    Qavion likes this.
