550 Spongey Brakes and Floppy Sun Visors | FerrariChat
Discussion in '456/550/575' started by Peter Roe, Jun 23, 2020.
  1. Peter Roe
    Peter Roe Rookie
    Mar 28, 2020
    3
    Peter Roe
    Hi. My 1997/8 550 Maranello, which I've owned for four years, has spongey brakes. My local specialist has thoroughly flushed the system and all calipers to little effect and suspects the fault lies with the ABS actuator pump. Apparently these are not available new and if they were they cost £1800. Eurospares can't help, Does anyone know where i might source one - or have experience of companies claiming to be able to rebuild them? There are a couple of second hand ones for sale in Germany and Poland but I'm reluctant to take a chance. Or is there something else that might be causing this? Also, the sunvisors do not stay up due to lack of friction at the detachable ends. Is there a simple fix to this? Thanks all. Peter
  2. wbklink
    wbklink F1 Rookie
    3,317
    Los Angeles
    Bill Karp
  3. tazandjan
    38,082
    Peter- Does your local specialist have a diagnostic tool that allows him to empty and bleed the ABS system? Just bleeding the calipers may still leave water and air in the ABS system.
    root likes this.
  4. ferraridriver
    ferraridriver F1 Rookie
    Aug 8, 2002
    4,137
    Bay Area Calif.
    Dave
  5. wbklink
    wbklink F1 Rookie
    3,317
    Los Angeles
    Bill Karp
  6. hwyman
    hwyman Formula Junior
    Jun 25, 2015
    329
    Canada / Los Angeles
    +1 on Daves visor fix :)
  7. root
    root Formula Junior
    472
    Bay Area, Ca
    ABS in the 550 Maranello is Bosch 5.0, similar to those used in the '95 Corvettes and other large GM passenger cars of that period. Don't know if they can be direct fit for the 550 but worth looking into. There are no bleed valves or scan tool for that module. According to Ferrari WSM bleeding should start from front brakes and from both caliper sides.
  8. Peter Roe
    Peter Roe Rookie
    Mar 28, 2020
    3
    Peter Roe
    That's really helpful about the visors. Sounds like Dave/ferraridriver is the man. Apologies but I'm a novice on forums/threads and can't figure out how to contact Dave. Please can you advise - my email is [email protected]
    Thanks also for ABS thoughts which I will follow up.
  9. tazandjan
    38,082
    Just click on his link above and later start a private conversation with him.
  10. fatbillybob
    Aug 10, 2002
    26,423
    socal
    I would like to know how that diagnosis was made...I do not buy that as a reason for spongy brakes.
  11. tazandjan
    38,082
    Peter- Guess no diagnostic tool, but one thing you might try is replacing the old, possibly much weaker than they were originally, rubber brake lines with stainless wrapped ones. Often provides a much firmer brake pedal.
