shattered mine tonight does anyone know where I can purchase a repro or new one? I assume it’s diff from the reg TR On a second note my car is a 92 what’s best place to buy rotors without getting clobbered? Mine are not cross drilled thanks all
I know ferrparts had a repro in the works/available. You might be better off just rebuilding yours though if it’s only cracked or broken 1-2 parts. I had the same issue about 3 years ago where I cracked my spoiler driving the car on a storage lift. I ordered a new OEM replacement from them, but they sent the repro which was alright but still obviously not at the OE level of refinement (mediocre mold) which would need minor rework/sanding to look like a top notch match. I ended up returning it and getting a cracked used OE lip which I personally epoxied and refinished. One user (beast 360) years ago (2010 timeframe if I recall ) had a carbon spoiler fabricated for his car which I saw first hand at the 2014 meet that looked great. OE Rotors routinely are on eBay and I think they are actually a brembo supplied rotor, so don’t be fixated on getting a yellow box rotor.
I had mine repaired. Send pics, let me see the extent of it and see if the place I took it to would be interested in repairing it.
Gt car parts Phoenix Arizona Front new original rotors are about 450.00. I just bought a set to have as a spare (623) 780-2200.
Pics attached Image Unavailable, Please Login Image Unavailable, Please Login Sent from my iPhone using FerrariChat
That’s not bad at all. Do you have the other pieces? If you do - put it back together with epoxy - goop it on and sand all the seams smooth with a sanding block. It will look like Frankenstein, but once that’s all done hit it with a few thin coats of paint until it looks fairly smooth and all the crack seams are minimized. You may have to sand and repeat a few times. Once satisfied, then take a flat black 3M vinyl wrap (I used a carbon fiber pattern) and properly wrap it. The 3M wrap will hide all defects, assuming you sanded properly and gives you an “as new” near perfect cosmetic surface.
