I have been looking for front rotors for my 512 tr and found out the following info. diameter 315mm width 32 mm bolt pattern 5 x 108 offset 62 centre bore diameter 67 This is the same spec as a 456 GTA which is readily available for a decent price. Can anyone tell me why the 456 rotors will not work on a 512 tr.
Upon further research. 1 model of the 456 with teves brakes used the same size rotors but they were solid not drilled. Those are impossible to find also! Sent from my iPhone using FerrariChat
I finally contacted a young man named Martin at ************ and it happens that he knew about the 315mm rotors for the 456, because he has a 456. But after discussing my problem he said that they could make me a set of slotted floating rotors for my 512 tr $1100. I would take about 6 weeks, but that is a deal. No affiliation!
Talked to Coleman Racing, raysur is correct. They can make them for a very resonable price and a 10 day 2 week turnaround. I will be buying my rotors if I can not get mine resurfaced.
