Hi guys Can you please share the torque needed on the center lock nut of 458 Challenge? Also what’s the size of the wrench would be appreciated! Thanks!
I can look up the spec for the 458GT3 when I get home. I assume it’s the same. I got the socket from one of the dealer teams.
Ferrari wants the wheel nut torque be applied with the vehicle lifted and with someone inside the car to keep the brake pedal pressed. The fastening torque is 550 Nm. Socket size is 80mm. Sent from my SM-G986U1 using Tapatalk
Six is what I have. Paoli makes them. B.28.0037 is the part number. It's listed for the F430 Challenge. Sent from my SM-G986U1 using Tapatalk
Hi guys Give me a hand, here you are a screenshot of GT3 manual, as you can see it states 1000Nm instead of the 550 you mentioning in this post. Any ideas? Difference is massive. Image Unavailable, Please Login Enviado desde mi iPhone utilizando FerrariChat
458 CHP is 550 Nm from Ferrari training manual, Please use Molykote 1000 (copper grease) on the thread and on the conic surface of nut-rim coupling, as for the 430 Challenge.
Agreed, if you don’t grease the cone, the nut can catastrophically get sized to the wheel and ultra mega force with specific equipment will be required to remove it again. Enviado desde mi iPhone utilizando FerrariChat
