458 usb not 30pin, can't connect Bovee 1000 ? | FerrariChat
Discussion in '458 Italia/488/F8' started by Hugo fong, Jan 27, 2018.
  1. Hugo fong
    Hugo fong Rookie
    Jan 27, 2018
    2
    Hugo Fong
    hi everyone, my 458 is usb from glove box not 30pin , that mean i can't use bovee ?or i have to change the cable to 30pin?
    because i had buy the bovee 1000 and using the 30pin cable to connect the usb, however i can't use it....Thx everyone....
  2. Ricky Angel
    Ricky Angel Rookie
    Nov 20, 2017
    14
    Ricky Angel
    If you don’t have the iPod connector in the glove box it sounds like your car doesn’t have the option fitted...? I think the USB is just for transferring music to the hard drive...
    bball16 likes this.
  3. Hugo fong
    Hugo fong Rookie
    Jan 27, 2018
    2
    Hugo Fong
    Omg.....a u sure for that?can i contact the dealer to upgrade to ipod connector and firmware?
  4. dustman
    dustman F1 Veteran
    9,049
    Bovee is for use with iPod cable.
    bball16 likes this.
  5. SoFLFerrari
    SoFLFerrari Karting
    Apr 23, 2015
    202
    South FL
    To my knowledge, the 458 infotainment system has two connectors: a USB cable to update the firmware and upload music, and a 30pin cable and connector for the Bovee or iPhone. It could be that the 30pin has fallen behind the glove box.
  6. Surfah
    Surfah F1 Rookie
    Dec 20, 2011
    3,135
    My 458 had the 30 pin connector in the glove box which was a $795 option. I tried and returned the Bovee after a few days. POS device that required manual re-pairing of my Iphone to the Bovee nearly everytime I started the car. Ended up parking an Ipod Nano to the 30 pin connector and leaving it in the glove box. YMMV.
    FWIW my iphone X pairs via Bluetooth to my Huracan and Mini Countryman 100% of the time automatically.
  7. Scout123
    Scout123 Formula Junior
    496
    Yeah, I have a Bovee installed, and have the same issue with having to manually turn off Bluetooth and turn it back on to re-sink. Then it works just fine. The only time this is not an issue is when the car is turned off for a very brief time.
  8. Rory breaker
    Rory breaker Formula Junior
    Apr 17, 2017
    269
    Ditto. It could be worse for sure, just flick Bt on your phone off and on again, but it is lame. Would love a fix.
    tr328 likes this.
  9. Carnut
    Carnut F1 Rookie
    3,797
    Gladwyne PA
    Morrie
    It is correct there are two ports back there. I bought and extra cable thinking it could be rewired to lighting cable, but it does not appear that it can be done. I have used the bovee and other BT connectors in my other cars in the past and none of them had the connection problems the 458 has. The other units connect right away and every time.
  10. PTG1
    PTG1 Formula Junior
    Oct 7, 2017
    783
    Pete
    This is 100% correct
    Sent from my CLT-L09 using FerrariChat.com mobile app
  11. Tarek307
    Tarek307 Formula 3
    1,294
    Long Beach, CA & Alexandria,Egypt.
    Tarek Salah
    Thats what i'm about to do, sick of having to reconnect the Bovee every single time and it is always also cutting out can't really enjoy a song that way. I have a nano around here somehwere i'll just put in the glovebox
  12. 458Spider2013
    458Spider2013 Karting
    Dec 1, 2021
    171
    Pete Gregory
    My car only has a usb cable in the glove area. I have the upgraded JBL stereo system and I find it hard to believe that It would lack the 30 pin phone connector having the upgraded stereo. Im puzzled.
    You guys are also saying that in terms of the USB cable that its primary function is for uploading music but this cable charges my phone when I plug a lightning cable to it.
    Can we dive deeper into how this all works as Im needing to use my phone as my head unit.
  13. jc1
    jc1 Formula Junior
    Feb 9, 2021
    267
    Greenville, SC
    Joey (2012 458 Spider)
    The IPOD Connection and the JBL were separate options.
    My options list has them listed as:
    SNDB HIGH POWER HIFI SYSTEM
    IPOD IPOD CONNECTION
    It's possible the original buyer purchased SNDB but not IPOD.
  14. 458Spider2013
    Dec 1, 2021
    171
    Pete Gregory
    #14 458Spider2013, Jul 2, 2022
    there has got to be a way to retrofit iPod after the fact...no?
    what can a stereo shop do?
    Is my only option to get a fm transmitter?
    Also can I do handsfree bt phonecalls without music?
  15. jc1
    jc1 Formula Junior
    Feb 9, 2021
    267
    Greenville, SC
    Anything is possible. I was just commenting that just because it has JBL doesn't mean it has the iPod connector.
  16. 458Spider2013
    Dec 1, 2021
    171
    Pete Gregory
    sorry wasn't trying to be an ass. Just frustrated that the OB opted out of phone integration....I understand purists that only want to hear the engine purr but phone calls?
  17. jc1
    jc1 Formula Junior
    Feb 9, 2021
    267
    Greenville, SC
    Totally understand. I'd be annoyed too.
    If you just want phone calls, you don't need the iPod Connector. Does your car have Navigation? I think bluetooth came with that.
    NAVC RADIONAVI SYSTEM + BLUETOOTH
  18. 458Spider2013
    Dec 1, 2021
    171
    Pete Gregory
  19. 458Spider2013
    Dec 1, 2021
    171
    Pete Gregory
    The cable can be had for 300 bucks regardless how the car was born. Plug and play.
