456GT gearbox bearing failure? | FerrariChat
Discussion in '456/550/575' started by franschman, Nov 7, 2022.
  1. franschman
    franschman Formula Junior
    Dec 18, 2017
    362
    Holland
    Bart
    Last weekend I did a short, 10km, test drive. When I got back home, put the car in neutral, opened the door and released the clutch (in that order), I noticed a sound of a rumbling bearing coming from underneath the car. I pressed the clutch and the noise disappeared, released it and the noise came back, louder this time. I got out and poked my head under the car and the rumbling became an awkward rattling within a minute. I pushed the car into my garage and onto the lift and started again, armed with a stethoscope to try hear which bearing it was. I only listened for half a minute or so as I couldn't stand the noise and my diagnosis is inconclusive.
    It is definitively a bearing, sounds like a ball is split or broken. Epicenter of the noise is the front end of the gearbox although I am not 100% sure it is not the aft bearing in the torque tube. In all gearbox problem posts on here I read that the problem is most likely the tube, not the box. Anyway, I need to drop the box to investigate...
    Any suggestions? Anyone ever experienced failure of bearing #3 in below diagram?
    Not amused as this means yet another job this winter but perhaps I should count myself lucky as this happened in front of my garage door?
  2. Timmo
    Timmo Formula Junior
    Aug 26, 2017
    639
    Continental Europe
    What's the mileage of the car and the throwout bearing?
  3. franschman
    Dec 18, 2017
    362
    Holland
    Bart
  4. franschman
    Dec 18, 2017
    362
    Holland
    Bart
    Well, I bit the bullet and removed the the bearbox. There's a M14x1,5 threaded hole in the bottom of the box, exactly in the center of gravity of the box and torque tube together. I made an adapter that screws into the box and sits onto a transmission jack and with these tools removal of the box is not that difficult.
    Upon opening the box, and removal of the forward two sections, the root cause of the noise became apparent. The reverse auxiliary gear is held in place by two seeger rings which sit in a groove on the shaft. The upper one seeger ring was not in the groove at all but rather at the top of the shaft, firmly pressing against the casing. How it got there is beyond me. The only thing I can think of is wrongly mounted by someone before me. Without this seeger ring the gear is free to move up the shaft and hit the gear above it, which is obviously did. Bad news.
  5. franschman
    Dec 18, 2017
    362
    Holland
    Bart
    Now in order to disassemble the box further, I need to undo a ring nut on the differential side. In order to get there, you need to take off the oil pump. And in order to take the oil pump out you need to remove the differential/crown wheel assembly. But how???
    The manual simply says 'remove diff/crown wheel assembly', but it just doesn't seem to fit.
    Any help please from someone who has done this before.
  6. tazandjan
    39,007
    Reverse gear retention was a problem on the 456, 456M, 550, and 575M before transaxle number 1869. At that point Ferrari revised the retention mechanism to strengthen it. The problem usually occurred when too much torque was suddenly applied while in reverse. Not sure if the updated retaining system can be adapted to earlier gearboxes, but you can take a look at the 575M parts catalog to see what I am referencing.
    Rifledriver and Qavion like this.
  7. franschman
    Dec 18, 2017
    362
    Holland
    Bart
    I can easily make two bushes either side of both seeger rings that positively keep these in place, as apparently Ferrari also did. But in my case the damage is done already. Luckily I didn't drive and the steel chips collected at the filter and, as far as I have now seen, have not entered any of the bearings. As far as I can now see only the aux wheel and the reverse synchromesh ring have been damaged. But I will surely flush and carefully check every other component for damage or wear and replace bearings if there is any doubt. But I have first to get the diff out and I don't see how!
  8. Qavion
    Qavion F1 World Champ
    13,806
    Ian Riddell
    Bart, it may be best to ask this question on the technical forum. There are plenty of gearbox experts there.
    Be careful how far you disassemble the transmission. There are lots of expensive and impossible-to-find assembly & alignment tools required for Ferrari gearboxes.
    The gearbox on my F355 self-destructed after one of the main bearings failed. Years after a major overhaul of the gearbox, I'm still trying to find tools to stop it jumping out of second gear.
    By "retention", do you mean "staying in gear"... or the reverse gear "staying on the shaft"?
  9. franschman
    Dec 18, 2017
    362
    Holland
    Bart
    #9 franschman, Dec 5, 2022
    Thanks, done that.
    And I am very much aware of the difficulties and special tools required, tools that nobody has the exact specifications of. Also the WSM is of little use. Luckily the box is of rather old fashioned layout (very similar in construction to Lancia Aurelia 1-3 series, except that these had the clutch in the transaxle and were 4 speed), but obviously of very high standard otherwise. I will make the tools as I go along; I will need to wash/check all bearings anyway.
    Gearboxes are the equivalent of a mensa test; getting a box back together is one thing, getting it really 100% quite another. I like gearboxes.
    Qavion likes this.
  10. tazandjan
    39,007
    Ian- Reverse gear tended to come loose from its shaft.
    Qavion likes this.
  11. franschman
    Dec 18, 2017
    362
    Holland
    Bart
    It's like one of these impossible Chinese puzzles that are actually quite simple. After struggling with this most of Sunday, tonight I walked past my workbench, gave it one more try and 10 seconds later I hold the diff in my hands...
    I now have access to the third ring nut which, off course, has different dimensions to the other two so will now proceed to make a spanner.
  12. franschman
    Dec 18, 2017
    362
    Holland
    Bart
    I've made progress on my gearbox issues and will do a write up shortly, as I think chances are high that other 456/550 owners may have the same issue. I have seen the insides of 4 gearboxes now (2 456, 1 550 and one 575) and apart from the 575 all boxes had the same issue with the reverse gear.
    @Taz, do you have the WSM for the 575M, gearbox section, and can you please share?
    I'd like to check dimensions and tolerances of this 575 manual box before putting it up for sale as I can not use (or test) it on my 456.
    Thanks.
  13. tazandjan
    39,007
    All our V12s up to the 575M with transaxle No. 1869 have the same reverse retention problem. I am not sure if the later 575M retention fix can be applied to earlier transaxles. Is this what you want?
  14. franschman
    Dec 18, 2017
    362
    Holland
    Bart
    Thanks, this will do.
  15. Auraraptor
    Auraraptor F1 World Champ
    Sep 25, 2002
    13,849
    MO
    Omar
    This is interesting.
    Taz or Franschman, do you happen to have the dimensions for the automatic gear box by chance?
  16. franschman
    Dec 18, 2017
    362
    Holland
    Bart
    Sorry, don't know anything about the auto boxes.
  17. tazandjan
    39,007
    There is virtually nothing on the automatic transmissions in either the 456 GT or 456M WSMs. Best source would likely be GM 4T80E tech data. Here is some service data I put together from GTA owners on FChat. Not sure if it is helpful or not.
    Auraraptor likes this.
  18. Rifledriver
    36,750
    I have one sitting on the floor. What dimensions do you need?
  19. Rifledriver
    36,750
    Whether it will or not its not much different than what I had thought of years ago. Make 2 bushings out of aluminum round stock to take up the empty space fore and aft of the reverse idler gear on the shaft. Let the bushings control the thrust of the gear. Snap rings were a really dumb idea on a car with that much torque.
  20. tazandjan
    39,007
    I found a 30 Mb 4T80E workshop manual online for free.
    Brian- Sounds like a worthwhile investment next time I get my clutch changed.
    Rifledriver likes this.
  21. Vilhuer
    Vilhuer Karting
    Aug 3, 2008
    156
    Helsinki, Finland
    Simplest way to make reverse stronger could be to change stock design snap ring to Spirolox style. It is very likely factory part is some standard DIN size which can be directly replaced. Could make sense as long as its stronger than stock.
    Smalley Spirolox® Retaining Ring vs. Stamped Circlip/Snap Ring | Smalley
    575 style spacer fix is obviously prefered method but it looks like its not so easily doable with factory parts.
  22. Jaredsalinsky
    Jaredsalinsky Formula Junior
    Feb 8, 2023
    653
    tampa FL
    Jared salinsky
    Guys, new to 456’s. Just bought a ‘95 GT. Taking delivery hopefully next week.
    This is the first i’m learning about reverse retention issues. Is this a common enough occurrence to warrant preemptively fixing the gearbox before anything catastrophic happens?
  23. Rifledriver
    36,750
    If you promise to be gentle in reverse It doesn't happen too often. If I had one I'd probably do it at some point. How is the clutch? Be a good time.
  24. tazandjan
    39,007
    No burn-outs in reverse and no really sudden clutch engagements and, like Brian said, wait until you have to yank the transaxle anyway. Good time to see what kind of shape the synchro rings are in.
    Brian- I assume we have brass synchro rings like the V8s?
