456 Torque Tube Bearings | FerrariChat
Discussion in '456/550/575' started by skl63, Apr 29, 2016.
  1. skl63
    skl63 Karting
    Dec 13, 2007
    227
    Melbourne, Australia
    Scott
    Hi,
    Can anyone help me with the dimensions of the TT bearings from a 456GT or know the difference between GT and GTA TT bearings (other than price and NLA status of GT bearings).
    Cheers
    Scott
  2. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,380
    The Cold North
    Tom
    You are going to have to pull it apart, and get the numbers off of the old bearings.
  3. skl63
    skl63 Karting
    Dec 13, 2007
    227
    Scott
    It is apart and I know the part numbers.
    GT bearings are NLA and GTA bearings are over a thousand dollars each bearing and there are 3 of them, if you can get them.
    I have the dimensions of GTA, just need measurements for GT. Some documentation says they are interchangeable, some says they are not.
    They are like most TT bearings, a simple SKF, with vulcanised rubber around the outside to grip inside of TT and a rubber insert to grip the prop shaft.
  4. au-yt
    au-yt F1 Veteran
    5,834
    Burradoo... Actually
    Graeme
  5. Vilhuer
    Vilhuer Karting
    Aug 3, 2008
    122
    Helsinki, Finland
    If its difficult to find bearings or stock part is expensive it might make sense to get aftermarket solution. In Porsche transaxle world these guys do quality parts for 928 and 944 torque tubes.
    Black Sea R&D
  6. skl63
    skl63 Karting
    Dec 13, 2007
    227
    Scott
    Thanks Vilhuer,
    I have actually been speaking with Constantine Black Sea) about getting some bearings produced going forward. They look very good, however the lead time will be a couple of months at least,
    Cheers
    Scott
  7. 2000 456M
    2000 456M F1 World Champ
    Sep 29, 2007
    12,600
    Portland, OR
    Allan
    Can you provide the part numbers? I think that, in addition to the 3, there is also a bearing on the differential, too. (I may need the bearings for my MGTA *sigh*).
  8. oss117
    oss117 F1 Rookie
    Jan 26, 2006
    4,185
    Plantation, Florida
    Alfredo
    Have you tried to source them from a bearing house rather than the dealer ?
    Ferrari does not make the bearings and there may be bearings sold commercially that would fit.
  9. 2000 456M
    Sep 29, 2007
    12,600
    Portland, OR
    Allan
    #9 2000 456M, May 6, 2016
    Just got the word from the dealer. Parts not available; recommended I find a driveline shop; however, Ricambi has the bearings (need 3) at $922.50 each! We'll find an alternative, I'd bet.
  10. MaurizioAM
    MaurizioAM Karting
    Sep 5, 2018
    104
    Plano Texas
    Maurizio
    Was there ever any update on a source for these bearings. It appears my new to me 99 456m GTA is having the same type noise while idling in park or neutral. My mechanic just had the tranny pulled and converter rebuilt and changed a few other parts but most of the noise is still there indicating what may be the problem of the torque tube bearings.
    Has anyone figured out any other solutions to this issue by chance?
  11. Stackhouse
    Stackhouse F1 Rookie
    Feb 14, 2004
    4,714
    IN YOUR TRUNK
    CT.. AKA Pimp Daddy
    Bump-
    Does anyone know if the bearings in the Torque Tube for the Automatic are replaceable and if so does anyone have a source for replacement? (SKF...etc?)
    Thanks!!!
    CT
  12. MaurizioAM
    MaurizioAM Karting
    Sep 5, 2018
    104
    Plano Texas
    Maurizio
    There's a shop near me that has another 456m taken apart at the moment, bearing has been sourced. However, sourcing the bearing isn't really the issue as the tooling needed to remove and replace the bearing in the precise location is not a real tool but something that needs to be crated to do the job. I will follow up as I receive more information.
    Il Tifoso likes this.
  13. treedee3d
    treedee3d F1 Rookie
    Apr 1, 2011
    3,721
    Montreal
    Fab
    You can re-use the existing ones by just changing the bearing inside and rebuilding the housing if your outer rubbers are still in good shape.
  14. skl63
    skl63 Karting
    Dec 13, 2007
    227
    Scott
    These are not easily replaceable. I have had these remanufactured and they are really nice (see my earlier post). Price including high quality bearings should be about USD250.00 each, depending on order quantity. Turnaround time approx. one week. Let me know if any interest.
  15. Tdr2j
    Tdr2j Rookie
    Jun 19, 2018
    8
    Rock Hill
    Reuben Johnson
    I’m interested in getting your bearings I have a 2000 456gta automatic how can I contact you
  16. Dal308
    Dal308 Karting
    123
    Coppell, TX
    Dude
    I just got my replacement bearings from Scott (skl63) and although we haven't installed yet, they appear to be exactly as promised.
  17. Tdr2j
    Tdr2j Rookie
    Jun 19, 2018
    8
    Rock Hill
    Reuben Johnson
    I had posted earlier that I was interested in the bearings but never got a reply back on how to contact
  18. MaurizioAM
    MaurizioAM Karting
    Sep 5, 2018
    104
    Plano Texas
    Maurizio
    Send him a private msg and he will respond back. He got back to me within a day or 2 with information.
    Sent from my Nokia 6.1 using FerrariChat.com mobile app
  19. Tdr2j
    Tdr2j Rookie
    Jun 19, 2018
    8
    Rock Hill
    Reuben Johnson
