456 / 550 / 575 Cross Reference, Interchangeable Parts Source Thread | Page 16 | FerrariChat
Discussion in '456/550/575' started by Cribbj, Jan 9, 2013.
  1. niftyfivefifty
    niftyfivefifty Formula Junior
    366
    PacNW
    #376 niftyfivefifty, May 30, 2020
    Quick update on the O2 sensors, I found the generic Bosch part numbers which come up as much lower pricing from Amazon, Rockauto, etc.:
    Catted: Ferrari p/n: 169953 Bosch p/n: 13819
    Catless: Ferrari p/n: 165170 Bosch p/n: 13820
    456GT w/cats Motronic 2.7 O2 sensor: 158730 Bosch p/n: 13309
    456GT w/o cats Motronic 2.7 O2 sensor: 158231 Bosch p/n: still looking
    F456M, brogenville and Auraraptor like this.
  2. fridolin_pt
    fridolin_pt Karting
    Mar 25, 2008
    162
    Germany NRW
    Fritz
    These tie rods for the 456 GTM are no longer available:
    The original ZF steering certainly was not exclusive Ferrari.
    Any idea for a replacement?
    Thank you for help
  3. JC1720
    JC1720 Karting
    Jan 21, 2016
    102
    Does anyone know of an alternative source for the NLA light adjusting potentiometer part number 153073, as used on a MY2000 RHD 550?
  4. arkferrari
    arkferrari Karting
    211
    Hot Springs, AR
    B.F. Mitchell
    What Bosch O2 sensors are indicated for a catless (mine were removed) 456M GTA with 5.2 Motronic?
  5. niftyfivefifty
    366
    PacNW
    Just the front two, correct? I believe they are both 165170 (one is listed as 168928 which I have read is superseded by 165170). Bosch part 13820.
  6. fridolin_pt
    fridolin_pt Karting
    Mar 25, 2008
    162
    Germany NRW
    Fritz
    Qavion and MRY like this.
  7. tazandjan
    38,087
    F456M and Qavion like this.
  8. fridolin_pt
    fridolin_pt Karting
    Mar 25, 2008
    162
    Germany NRW
    Fritz
    F456M likes this.
  9. sully456
    sully456 Rookie
    Feb 21, 2011
    40
    New Zealand
    Steve O'Sullivan
    #384 sully456, Jul 17, 2020
    FORD EXPLORER 1995-2001 FRONT INNER RACK END
    FORD EXPLORER 4.0L 244 V6 1995 - 2001 - About $25 each and heavy duty - same thread and length - perfect fit both sides,
    They fit my 1995 456GT
    F456M, Qavion and fridolin_pt like this.
  10. F456M
    F456M F1 Rookie
    Jan 8, 2010
    3,665
    Oslo
    Erik
    This cost about 15 dollars at our European parts supplier Autodoc... Not bad to be Ferrari - Saab part!!
  11. F456M
    F456M F1 Rookie
    Jan 8, 2010
    3,665
    Oslo
    Erik
    I just had two steering joints installed locally. The tech said it was a fraction longer, but it was no problem fitting them! Paid about 350 dollar for two new ones including two houres of work. The car became quite a bit better to drive! Will change out some more bushings too soon. Then a full alignment. In the workshops database, the part was for a Saab 9-5.
    Rian84, ferraridriver and Qavion like this.
  12. tazandjan
    38,087
    Hard for me to believe I spoke fluent Norwegian when I was 13 years old and lived in Oslo. Cannot make heads or tails of it now.
    tantumaude and F456M like this.
  13. F456M
    F456M F1 Rookie
    Jan 8, 2010
    3,665
    Oslo
    Erik
    Du får komme til Oslo og lære språket på nytt!! :)
  14. tazandjan
    38,087
    Erik- Visited in 1989 and it came back pretty quickly, but that was a long time ago. Loved Norway, especially Norwegian girls.
    F456M likes this.
  15. ferraridriver
    ferraridriver F1 Rookie
    Aug 8, 2002
    4,137
    Bay Area Calif.
    Dave
    Konadog06 and 308 GTB like this.
  16. papou
    papou Formula 3
    1,577
    plantation Fla
    daniel ross
    Fennicus, Qavion, F456M and 2 others like this.
  17. papou
    papou Formula 3
    1,577
    plantation Fla
    daniel ross
    Adrian is on the forum,precision360cs he also solved the pop up headlight problem it’s a quick cheap fix.
  18. henri66
    henri66 Karting
    Oct 10, 2006
    109
    Previously Maranello
    i searched for this information but could not find it. Do you have a link?
  19. papou
    papou Formula 3
    1,577
    plantation Fla
    daniel ross
    Adrian Farinato 954-818-9321, mention my name and Fchat.
  20. henri66
    henri66 Karting
    Oct 10, 2006
    109
    Thanks. I was more after explanations on the forum as I live in France and will not use their services.
  21. papou
    papou Formula 3
    1,577
    plantation Fla
    daniel ross
    He has the small part sent to him from world wide clientele .
  22. bay
    bay Formula 3
    Mar 13, 2011
    1,224
    Belgium
    Bernard
  23. vic7or13
    vic7or13 Rookie
    Sep 19, 2019
    1
    Monterrey Mexico
    victor manuel
    Fuel filter for 456m gta. Autozone G3744
  24. Fennicus
    Fennicus Formula Junior
    Apr 10, 2015
    592
    Helsinki, Finland
    Pekka T.
    Hi,
    Maybe a bit far fetched, but now that I might need one, according to the parts books and browsable stuff on Eurospares UK, that Ferrari part number 158231 was the same also for F355 and 512M at the time. The older part numbers given for those with the same Bosch Motronic 2.7 would link to this "Lambda" O2 sensor:
    • EAN: BOSCH 3165143342336 = BOSCH 15727, BOSCH LS06, BOSCH LSH24
    As it's available locally for about €46,- euros I think I'll get two and try if I can get the old ones out and use this ones and see if there is any change.
    Cheers!
    niftyfivefifty likes this.
  25. niftyfivefifty
    366
    PacNW
