456 / 550 / 575 Cross Reference, Interchangeable Parts Source Thread | Page 13 | FerrariChat
Discussion in '456/550/575' started by Cribbj, Jan 9, 2013.
  1. Andrew D.
    Andrew D. F1 Rookie
    Jul 6, 2008
    3,979
    Goodwood Ontario
    Andrew D.
    Re headlight lifting motor. Hard to get for a reasonable price. Volvo 480 motor also hard to get, Anyone know if another makers motor would fit which Ferrari sourced? Would be a benefit for all flip up headlight motors for most models.
  2. Reynaldo
    Reynaldo Rookie
    Oct 19, 2011
    3
    Many thanks
    I cannot trace a comparable Merc part though I'm sure you're right. If you have a number or model reference, that would be great. Thanks
  3. LjT
    LjT Karting
    Feb 26, 2013
    146
    Anyone has any solution on a 550 multi function warning light display unit? Really expensive for a new unit. Can it be repaired?
    Regards
  4. bergxu
    bergxu Formula 3
    Aug 16, 2005
    1,307
    OnTheSerpentMound
    Aaron
    Rear hub bearing assembly on a 456 is p/n 157901 which crosses to a Maserati 3200GT. Both cars use the same part #. Replaced the LR hub on my 456 using the Maser-boxed part, it is 100% identical to the Ferrari item and was less $.
  5. bay
    bay Formula 3
    Mar 13, 2011
    1,268
    Belgium
    Bernard
    179087: INERTIAL SWITCH
    Fits: Ferrari 360 Challenge (2000), 360 Challenge Stradale, 360 Modena, 360 Spider, 430 Coup�, 430 Scuderia, 430 Scuderia Spider 16M, 430 Spider, 456 M GTA, 458 Italia, 550 Barchetta, 550 Maranello, 575 Superamerica, 575M Maranello, 599 GTB Fiorano, 612 Scaglietti, Enzo, F50
    ALFA ROMEO 156 / 147 / GT 1.9 JTD - CRASH CUT OFF SENSOR 7790538
  6. bay
    bay Formula 3
    Mar 13, 2011
    1,268
    Belgium
    Bernard
    145030: TANK PLUG
    Fits: Ferrari 355 (2.7 Motronic), 355 (5.2 Motronic), 360 Challenge (2000), 360 Challenge Stradale, 360 Modena, 360 Spider, 430 Challenge (2006), 430 Coup�, 430 Scuderia, 430 Scuderia Spider 16M, 430 Spider, 456 GTA, 456 M GTA, 458 Challenge, 458 Italia, 458 Speciale, 458 Speciale Aperta, 458 Spider, 488 GTB, 488 Spider, 550 Barchetta, 550 Maranello, 575 Superamerica, 575M Maranello, 812 Superfast, California Turbo, Enzo, F12 Berlinetta, F12 TDF, F50, FF, GTC4 Lusso, GTC4 Lusso T, La Ferrari, La Ferrari Aperta
    Citroën 1306E7
    Référence Gates RC213
    F456M likes this.
  7. asgor
    asgor Formula Junior
    Sep 8, 2016
    711
    Virginia, USA
    Well... depending on what's wrong with it there are several places that will repair LCD displays (we are talking about an LCD display, right?).
    For starters: are lines missing through the display or is it completely out? In short: it can most likely be repaired but will require the removal of the instruments pod (I am not immediately familiar with the 550 setup, but I seem to remember the display is built into the tach)
  8. tazandjan
    39,007
    Give these guys a call and ask. They repaired my Superamerica instrument cluster.
    Franchorchamps of America, Inc.
    935 Sunset Dr Suite A
    Costa Mesa, CA 92627
    (949) 631-6373
    Rod Drew
    [email protected]
    Will White
    http://www.ferrarioc.com/
  9. asgor
    Sep 8, 2016
    711
    Virginia, USA
    #309 asgor, Oct 31, 2017
    This part controls coolant delivery to the heater core (cabin heat) and works in sync with the temperature selection knob located in the center console (456, 550, not sure about 575)
    Ferrari part 61079000 (ELECTRO-MAGNETIC VALVE) is interchangeable with Bosch part #1.147.412.013. As that Bosch part is becoming increasingly difficult to locate, cross-reference with Bosch 1.147.412.008 - commonly used in BMW and MB applications and easily found online.
    Also, oftentimes the culprit for the malfunctioning of this item (= no cabin heat) is actually the inner valve component. R/R just inner valve with the following MB part: 000-835-06-44-MBZ.
    For additional information refer to this thread: https://www.ferrarichat.com/forum/threads/brrrr-no-heat-in-the-cabin.563083/
    ///Mink likes this.
  10. F355 Fan 82
    F355 Fan 82 F1 Veteran
    Jul 22, 2006
    9,063
    Not really a "parts" question but Im looking for a 575 cover for my car and I called the collection in miami, ferrari of ft lauderdale, and ferrari of west palm. Nobody can get me one, they only have a showroom cover for $600 which is just basically a sheet. Im looking for an original cover with the steering wheel and seat covers for a 575 with daytona seats. Do any of you know where I could source that? Thanks
  11. tazandjan
    39,007
    E-bay and the 550 sets are identical. There was a 550 set above in Ferrari Parts and Collectibles recently.
  12. Konadog06
    Konadog06 Formula Junior
    Aug 22, 2007
    963
    Daytona Beach, Florida
    Bill
    As Taz says, EBay, just be patient. Every couple months they seem to pop up. May have to purchase the seats and wheel cover seperately and you should be able to find all for around the $600.
    At one point Eurospares in the UK had an attractive price, might be worth a look.
    Bill
    FL
  13. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
    In the process of building up the heads on my 575 engine.
    Ferrari want £255 plus post for the 48 valve stem seals, and eurospares £199 plus post.
    They are a fairly common looking item so did my research. Their size is 7/9.8/13.2 - 10 which is exactly the same as many VW, alfa etc etc stem seals. Elring are the leading supplier of such seals.
    Managed to buy 50 genuine Elring seals for £24 inc post !!!!!!! and they fit perfectly :)
    Part numbers shown on the attached pic. The 612, SA and 550 use the same seals as the 575 not sure on the 456 though. Image Unavailable, Please Login
    F456M, ///Mink and bay like this.
  14. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,573
    Argent/Brasil
    Guido
    New fuseboards for 456, 550, 575 models.
    Since 2007 I'm producing new motherboards for fuseboards for the following models : TR, testarossa, 512tr old model board, 328, all mondials, 400i, 412 and F40.
    I'm willing to produce also boards for 456 (old model) and 456 (new model), 550 and 575.
    I purchaged an OEM 456M board to copy the internal wiring diagram and to measure all components like female, male and relais connectors.
    For the old model 456 board I just need to find the internal diagram. If someone is in the need for a NEW 456 old model board,we can make a deal. A discount on the new board of 200€ when you can loan me your old board for 1 week. Arrangements for shipping cost can be discused.
    For the 550 board someone promissed me to send his old one for copying that diagram.
    For the 575 board a verification can be done to see if it has a 456 or 550 internal diagram.
    More information you can find :
    https://www.ferrarichat.com/forum/threads/new-motherboards-for-fuseboxes.563211/
    or on this website :
    http://redbaycars.com/remanufactured/ferrari%20parts.html
    Guido
    paulchua, F456M and bay like this.
  15. ferraridriver
    ferraridriver F1 Rookie
    Aug 8, 2002
    4,150
    Bay Area Calif.
    Dave
    I was the one with a 550 board, just waiting for you to tell me where and when to send it.
    bay likes this.
  16. theunissenguido
    Jan 21, 2004
    2,573
    Argent/Brasil
    Guido
    yes, Dave, you're the man who will help me to get that 550 wiring diagram ! Thanks for that...
    Just waiting to get back in Belgium begin may. Will give you a sign.
    Have a nice carvanalweek to all ....I just arrived in Buzios near Rio de Janeiro to enjoy carnaval over here.
    Guido
    paulchua and bay like this.
  17. abilliet
    abilliet Formula Junior
    Dec 5, 2006
    403
    Antony Billiet
    Looking for a grommet to seal the steering column where it passes through the firewall
    for a 1997 456 gt (or 550) to prevent heat entering the cabin. The part 167341 is no longer available .
  18. asgor
    Sep 8, 2016
    711
    Virginia, USA
    F-chat member stekkefun is currently parting out a 456M (in Belgium - I believe). It may be worth contacting him about this part.
  19. abilliet
    Dec 5, 2006
    403
    Antony Billiet
    Thanks asgor. Stekkefun has the grommet and it’s on the way to Sydney !
  20. asgor
    Sep 8, 2016
    711
    Virginia, USA
    Excellent! Everyone likes a happy ending.
  21. MotoMeccanica
    MotoMeccanica Formula Junior
    448
    Calgary Alberta
    Just FYI, Ferrari North America still stocks 167341, they have qty 16 on hand.
    Scott
  22. yunita
    yunita Rookie
    Feb 2, 2018
    18
    yunita ar
    subscribed, this seems like a very interesting thread[​IMG]
  23. pkl03
    pkl03 Formula Junior
    521
    Sydney, Australia
    Peter
    Not affiliated
    https://www.ebay.com/itm/Genuine-Ferrari-550-indoor-car-cover-with-sport-seat-steering-cover-BRAND-NEW/152548987303?hash=item2384a0d1a7:g:ZKQAAOSwrhBZDP1n&vxp=mtr
  24. Laserguru
    Laserguru Formula 3
    Aug 7, 2016
    1,255
    New Hampshire
    Eric
    This thread is worth more than you can imagine. These cars would border on impossible to keep going without all these cross-references to the common parts used by numerous manufacturers. Any subscription fee for FerrariChat disappears like smoke on the wind the day you get to buy some Alfa or MB parts that cost 1/10 the Ferrari cost if they are even available at all from Ferrari. NLA appears to be the corporate motto.
    Anybody else wonder what the guys in the Ferrari restoration shop sit around and talk about when their own parts aren't available? Hey, Guido, isn't that the same O2 sensor from the Alfa Sud? No, Luigi, that one is from the Renault. There ought to be sub-titles on your restoration documentation!!
    F456M, paulchua and wbklink like this.
  25. wbklink
    wbklink F1 Rookie
    Sep 2, 2009
    3,414
    Los Angeles
    Bill Karp
    F456M and paulchua like this.
