430 F1 actuator plastic cover seeping | FerrariChat
Discussion in '360/430' started by Robby Johnson, Jan 21, 2019.
  1. Robby Johnson
    Robby Johnson Rookie
    Jun 28, 2018
    25
    Robby Johnson
    I have an 07 F430 that has fluid very slowly seeping from the black plastic cover on the actuator. I can remove the cover, and clean the small gasket, and get it to stop for awhile, but it will come back. I haven't found a place that I can order just the black plastic cover. Anyone have any ideas? Is this a bigger problem I should look into? I don't have any issue with pressure build up, or pump run times, or shifting. Its not even enough that I, or the previous owner has had to worry about fluid levels.
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,680
    Central NJ
    Dominick
  3. BlacktopRacing
    BlacktopRacing Formula Junior
    Sep 18, 2016
    916
    Pittsburgh
    Dale
    Call Ricambi... they have, or can get, anything!
  4. Rifledriver
    34,106
    Austin TX
    Those are not supplied separately. I'd check with the guys who repair them They might have one from a core.
    But...do not be surprised if they say no. Those getting broken is not unusual so there may be a shortage.
  5. Robby Johnson
    Jun 28, 2018
    25
    Robby Johnson
    Is it normal for there to be fluid behind that cover?
  6. mike01606
    mike01606 Formula Junior
    Feb 21, 2012
    794
    Cheshire UK
    Mike M
    No....it’s a dust cover.
    There may be a slight weep past one of the high pressure seals and unless there is a lot leaking I’d leave well alone.
    Sealing it is pointless.
    Robby Johnson, Skidkid and flash32 like this.
