430 - 430 Exhaust OEM valves not opening | FerrariChat
430 430 Exhaust OEM valves not opening
Discussion in '360/430' started by Paul Kane, Feb 23, 2021.
  1. Paul Kane
    Paul Kane Karting
    May 27, 2020
    228
    Rickmansworth UK
    Paul Kane
    Had the car on C Tec charger.
    Full power, started first push.
    Sun out so had to go for a trip, still cold wind though. Car stored in garage for 4 months.
    Get onto the motorway, booted it and no roar after 3000 revs. It was fine before being garaged.
    I presume my OEM exhaust valves are not opening.
    When exhaust had cooled down I found the 2 valves were free by pushing the rod in and out, they were squeaky but free.
    Any pointers to my problem?
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    Follow the 2 rubber hoses on the valves , i think they go to a solenoid
  3. SCKOMS
    SCKOMS F1 Rookie
    3,849
    Lake County, IL
    Spiro
    Check for vacuum on the hoses
    Sent from my Galaxy
  4. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    If you look on eurospares web site i think it shows the setup on the parts list, including the solenoid arrangement
  5. Paul Kane
    Paul Kane Karting
    May 27, 2020
    228
    Rickmansworth UK
    Paul Kane
  6. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    Looking at the diagram there are 2 solenoid valves which get a signal to open the exh valves from the ecu. If neither of the exh valves are opening, then you have either lost the electric signal or you have no vaccum in the tank. It shows another solenoid valve between the engine and the vac tank so this might not be working, gives no vac and hence valves dont work. Take the pipe off and see if it sucks when engine running. You either have no vac or no electric signal. Might be a leaking pipe seal ring
  7. tazandjan
    38,058
    F430 exhaust bypass valves are fail open. If they are not opening, you have vacuum all the time to keep them closed.
  8. gsworld2014
    gsworld2014 Formula 3
    Dec 23, 2014
    1,061
    South Florida
    Greg S
    On of the solenoids might have went bad
  9. Paul Kane
    Paul Kane Karting
    May 27, 2020
    228
    Rickmansworth UK
    Paul Kane
    After playing around with the valves and solenoids with a fettle, poke and prod all is working again.
    Thanks all for your guidance.
  10. LorenzoR
    LorenzoR F1 Rookie
    Same problem. Took my girlfriend out for a ride and everything was running good. 2 days later I took a ride and the exhaust valves are no opening....The vac lines going to the solonoids look fine. Any ideas where to look next is appreciated Thanks
  11. GogglesPisano
    GogglesPisano Formula 3
    1,458
    East Bay, California
    Joe
    I'm confused, are we talking about your girlfriend or your car? :D
  12. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    Are you getting a vacuum in the hoses ?
  13. LorenzoR
    LorenzoR F1 Rookie
    I was under the impression that if the valves are closed all the time which mine are because they aren't opening, that means there is vacuum on them. Does that sound correct?
  14. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    If you are not getting the vac on either, then look at the on/ off valve as that is a master valve to the vac tank
  15. LorenzoR
    LorenzoR F1 Rookie
    I'm going to go start it right now and check the vacuum going to the valves
  16. LorenzoR
    LorenzoR F1 Rookie
    I took both vacuum lines off and plugged them. Started the car went to the back and unplugged one at a time and yes. confirmed vacuum going to each bypass valve
  17. MKTViper
    MKTViper Karting
    205
    Swan Point MD
    Can you test the vacuum above 4K rpm or under heavy load to see if the vacuum is being interrupted? You'd probably have to attach a hose to the solenoid and route it into the cabin with a vacuum gauge on it. Then drive it around to see if the vacuum is getting interrupted.
    Maybe try replacing the solenoids, they're pretty cheap on Amazon (although suspicious that BOTH solenoids would fail at the same time). My guess would be whatever signal tells the solenoids to close (prevent vacuum) isn't getting to the solenoids.
  18. LorenzoR
    LorenzoR F1 Rookie
    well Mike32 brings up the fact that there's is a on/ off master valve to the vacuum tank. I'm trying to find it now
  19. sammyf
    sammyf Karting
    Aug 13, 2004
    209
    This is going to be a weird one... but I saw it on my Gransport as well as another FChatters 360. Check for pending codes -> specifically a coolant temp sensor one. Whenever this code was pending, the valves would stay closed.
    Qavion likes this.
  20. LorenzoR
    LorenzoR F1 Rookie
  21. LorenzoR
    LorenzoR F1 Rookie
    Sammy thanks, i will check for any code rite now
  22. MKTViper
    MKTViper Karting
    205
    Swan Point MD
    I assume when you plugged the lines to check vacuum, the valves did open? If not, they're probably jammed up enough to work only under the right heat/vibration.
    I think (emphasis on think) the job of the "master" solenoid valve is to maintain negative pressure in the tank. That doesn't seem to be your problem... That solenoid is part #315769 in the pneumatic actuator system diagram if you need help locating it.
    FWIW, my valves failed OPEN because the plastic connectors in the tubing downstream of the solenoids got sucked into the solenoids as well as clogged the tubing. That prevented vacuum from reaching the valves. I replaced the solenoids and tubing and fixed the issue. Opposite problem of yours, just a data point...
  23. LorenzoR
    LorenzoR F1 Rookie
    yes when i plugged lines to check vacuum, the valves opened...
  24. Some Guy in the sky
    Some Guy in the sky Formula Junior
    Sep 19, 2018
    347
    I had the same problem on my 360 this summer. Actually the valve opening has been fairly sporadic since I've owned the car but they finally stopped opening. I assumed the solenoid was the problem and replaced it. After that the problem was solved.
  25. LorenzoR
    LorenzoR F1 Rookie
    No codes but thanks for coming in Sammy. Never hurts to check
