430 AC Controls in a 360 | FerrariChat
Discussion in '360/430' started by wiscobadger, Oct 4, 2017.
  1. wiscobadger
    wiscobadger Karting
    52
    Wisconsin
    Cory Eastman
    Is it possible to put the 430 AC controls in a 360? They look to be the same thing with different knobs?
    I'm missing the center knob from my 360 controls, but can't find a replacement without buying a whole unit. I prefer the look of the 430 knobs so figured I'd go that route if it is plug and play.
    Anyone tried this? Thanks!
  2. hessank
    hessank Formula 3
    1,728
    Canada, Florida
    Fred
    The question will be "are the AC CPUs talking the same language or will your AC ECU respond to the newer controls when on Auto (the 430 being newer and all)?
    It should, however, work on Manual. I've incorporated the 430 vents in my 360 because I think they are purdier. Was basic swap.
  3. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    The housing for the 360 and 430 are the same with the following exceptions:
    1) The dials (as you mentioned)
    2) The laser etched graphics are different
    I have no idea if the electronics are the same or different but you could swap the electronics out.
    The 360 dials are garbage plastic and break easy (and often). Getting the dials out is a bit tricky and you run the risk of breaking the tabs.
  4. derekmines
    derekmines Formula Junior
    Dec 12, 2013
    284
    Melksham, UK
    Derek
    Now that's a nice idea.... going to have my dash re-leathered next year, might do that upgrade at the same time!
  5. hessank
    hessank Formula 3
    1,728
    Canada, Florida
    Fred
    Completely reversible in 1/2 hour
    Before you purchase 430 vents, here's what they look like on my 360. YBTJ
    I'm 360 Canuck likes this.
  6. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    IIRC, the only difference between 360/430 vents is the 430 inner rings are a silver/ gray and 360's are black. We could refinish them that way but I would need to get the color matched.
    I can't recall of the top of my head but some of the eyelets are different.
    These vents are similar but slightly different on several models.
