400i Heater Valve and engine mount | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by Astonish78, Jun 20, 2019.
  1. Astonish78
    Astonish78 Karting
    Sep 11, 2014
    137
  2. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,091
    Canada
    Newman
    Lamborghinis use that mount
  3. Astonish78
    Astonish78 Karting
    Sep 11, 2014
    137
    Is it not possibly synonymous of a Fiat or something like that. I would like to buy these, but find the price as Ferrari spare part very expensive. I was hoping someone would recognize these components from another car and I could then purchase them from another parts supplier.
  4. Ak Jim
    Ak Jim F1 Veteran
    8,450
    North Pole AK
    Most Fiats have 4 cylinder engines, I don't think the mount would be strong enough for a V12.
  5. Arvid
    Arvid Formula Junior
    668
    Norway
    Arvid Andersson
    #5 Arvid, Jun 21, 2019
    Heater valve is also a Opel part with part nr.1820106. Used on Kadett B, Manta A, Opel GT
  6. SouthJersey400i
    SouthJersey400i Formula 3
    Mar 14, 2007
    1,591
    Romulus, NY (Finger Lakes)
    Ken Battle
    Those mounts are generic and can be found in a GOOD hardware store or maybe McMaster-Carr.
    Ken
  7. samsaprunoff
    samsaprunoff F1 Rookie
    4,160
    Edmonton, AB Canada
    Sam Saprunoff
  8. raemin
    raemin Formula 3
    Jan 16, 2007
    1,825
    Lyon (FR)
    R. Emin
    The valve is indeed expensive, but the mounts are approx 100GBP each which is is not horrendous for a vintage car.
  9. samsaprunoff
    4,160
    Edmonton, AB Canada
    Sam Saprunoff
    I did some additional checking and the Motor Mount looks to be the same as used on the Daytona as well. Eurospares lists the mount to be 106 mm in diameter. Interestingly, Cicognani has the Daytona mount for 60 Euro:
    http://www.cicognaniguarnizioni.it/Ferrari-163/365-gtb4-daytona-163-l20/supporti-cambio-e-motore-_cad._-16320410_6885
    Cheers,
    Sam
  10. Arvid
    668
    Norway
    Arvid Andersson
  11. Newman
    Dec 26, 2001
    14,091
    Canada
    Newman
    The valve is the same but you need to alter / transfer the riveted nut and pinch bolt to the new valve. Not a 3min job.
  12. SouthJersey400i
    Mar 14, 2007
    1,591
    Ken Battle
    My bad, I did not see this was for a motor mount. Ken
  13. Astonish78
    Astonish78 Karting
    Sep 11, 2014
    137
    Hello,
    thank you very very much for your help.
    Best regards
    Zdenek :)
  14. Arvid
    668
    Norway
    Arvid Andersson
    #14 Arvid, Jun 24, 2019
  15. Astonish78
    Astonish78 Karting
    Sep 11, 2014
    137
  16. Tojo
    Tojo Formula Junior
    Apr 12, 2002
    481
    Tim
    Just adding some info here for future reference.
    400 engine mounts are 106mm. The diff mounts are 86mm. An email to Cicognani has confirmed they only sell the 86mm mounts. This is a shame as €60 is substantially cheaper than the £100-115 that Superformance, Maranello, etc charge.
    Does anyone have any thoughts on what difference 20mm would make if you did use the smaller ones as engine mounts?
    Sent from my SM-G935F using FerrariChat.com mobile app
  17. raemin
    raemin Formula 3
    Jan 16, 2007
    1,825
    Lyon (FR)
    R. Emin
    I wouldn't...
    The oil hose that comes from the oil filter and feeds the engine is really close to the chassis, additional slope could end up as a major oil failure. See Ak Jim photo, you can even see that the hose has been rubbing against the chassis :
    On my car I have replaced this fitting by the one from the oil cooler (with a sharp bent), this implied to revert the oil cooler and use longer hoses. This sharp bent fitting does clear the hose away from the chassis, but that's still a very tight fit (0.5cm). I would not take a chance in a less beefy engine mount.
  18. Tojo
    Tojo Formula Junior
    Apr 12, 2002
    481
    Tim
  19. Arvid
    668
    Norway
    Arvid Andersson
    raemin likes this.
  20. raemin
    raemin Formula 3
    Jan 16, 2007
    1,825
    Lyon (FR)
    R. Emin
    Thanks @Arvid , these are indeed an exact match to my own 400i valve.
    I have to say however that on the 365 the valve is different and bolted on the engine block (not on the firewall like on my 400i). I did not check on others cars, but there must have been some variations. Maybe also that some mechanics did replace/relocate the original valve as the access is quite troublesome.
    For the record, that's how it is mounted on my own car:
  21. Ak Jim
    Ak Jim F1 Veteran
    8,450
    North Pole AK
    Gotta love Ferrari! Remove the engine to change a heater valve.
  22. Arvid
    668
    Norway
    Arvid Andersson
    It's in a thight spot for sure and I will have to change mine this season.
    They are originally Ranco valves - Ranco H28-104 is the number stamped on them. Isn't Ranco an American brand ? They are probably used on American built cars but which ?
  23. Ak Jim
    Ak Jim F1 Veteran
    8,450
    North Pole AK
    Not an expert on all American cars but all of the ones I’m familiar with don’t regulate the heat by controlling water flow but instead mix cold air with the heated air from the heater core. They are usually called blend doors because they look like a door and blend unheated air with heated air.
  24. Arvid
    668
    Norway
    Arvid Andersson
    Thanks,I didn't know that. I thought maybe GM or GMC had same part since Opel was under the GM umbrella.
  25. Newman
    Dec 26, 2001
    14,091
    Canada
    Newman
    All the factory ones I've seen have a pinch bolt in a threaded bung that the cable goes through. You can't connect the stock cable to that lever with a pin hole in the end
