1982 400i auto Has anyone removed and possibly photographed the A/C evaporator in our cars? The parts and service manual only shows a box with outlets, no info on the fans or evaporator. How hard is it to remove the evaporator? Complete dash removal? I'm looking for: 1) The evaporator make and model number or the dimensions at the very least. 2) My fans make a lot of commotion but has very little air coming out of the upper center vents. The A/C air is supposed to come out of the four vents on top of the dashboard, correct? I'm trying to come up with a cunning plan to improve the cooling power of the A/C. It's unfortunately been converted to 134 so it's tepid at best. I'm thinking of either converting back to R-12 or changing the compressor/evaporator/condenser out to a system that is matched to 134. But I'd still like to understand why the fans make a bunch of racked but doesn't blow much
You do have to remove the whole dashboard in order to access the evaporator. The evaporator unit itself seems specific to Ferrari, the motor can be replaced (see links below) The blower mesh screen (meant to capture the water droplets) is often clogged which spoils the airflow, I removed it entirely, works great now. Some do upgrade it (see links below) R134a is not such a good idea unless the original oil was fully flushed. You'd better use R416 which is R134a plus a bit of propane that can "soften" the old petroleum based oil. Alternatively you can use pure proprane (a.k.a Envirosafe, Freeze 12 , Duracool, HyChill). If you use R134, you should also replace the expansion valve so as to use one that is properly calibrated to R134. Here are a few links : Evaporator blower upgrade : https://www.ferrarichat.com/forum/threads/need-to-improve-interior-comfort.497678/#post-144149701 Another discussion on the subject (R12 o R134a conversion) ; https://www.ferrarichat.com/forum/threads/r12-to-r134-for-365gt4-2-2.613469/ Blower motor alternatives from the 308 forum : https://www.ferrarichat.com/forum/threads/diy-ferrari-308-ac-system-everything-you-wanted-to-know.344660/#post-146725032 Aspera compressor maintenance : https://www.ferrarichat.com/forum/threads/air-conditioning-compressor.299341/#post-139941930 (please note that the ASPERA specific parts are now available on ebay and do work better than retrofitted york parts) Carl Rose 308 AC upgrade : http://www.ferrari.cdyn.com/carl_rose_docs/
