430 - 4-1 headers and the power dip on the dyno once and for all... | FerrariChat
430 4-1 headers and the power dip on the dyno once and for all...
Discussion in '360/430' started by Zed82, Jun 9, 2020.
  1. Zed82
    Zed82 Formula Junior
    Sep 28, 2017
    490
    Sweden
    As many of you know, there have been various reports that 4-1 headers cause a power dip between 4-6000 rpm but i have also seen reports of Fabspeed and Agency Power headers that don´t have the power dip on an untuned car.
    I have a full IPE-system on my 430 and i´m thinking about getting a tune mostly because i suspect the engine is running rich and has a significantly increased fuel consumption so i guess it wouldn´t hurt to optimize things. However i´m not sure if the tune will make any difference in the power dip. As someone in a thread mentioned, if you starting from a hole it´s hard to make up for the initial losses (power dip).
    What is your take on the subject? I need input from you that have experience.
    Reference material with respect to the initial poster:
    https://www.ferrarichat.com/forum/threads/dyno-comparison-with-stock-header-and-aftermarket.530482/#post-144873303
    https://www.ferrarichat.com/forum/threads/problem-with-performance-with-ipe-full-exhaust.581182/?fbclid=IwAR2wJ2IBVLWmaJBYrLfho4D0-TOevQEsOP1aJSGb0GFaF28fwLKOBoOw7CY
    Red = stock
    Green = iPE headers, 200 cell cats, iPE X-Pipe
    Black = iPE headers, 200 cell cats, stock muffler
  2. BruceC
    BruceC Karting
    249
    Tucson, AZ
    I have the full IPE system with 200 cell cats on my 430 and don't see a pronounced power dip, but as I understand it comparing dyno results isn't always apples to apples for a variety of reasons. Mase Engg did an ECU tune on his dyno with the following results - Steve was wonderful to work with BTW, and I'm sadly a bit negligent for not having updated this thread over a year ago when the work was done. I hope this helps.
    (blue = before tune)
  3. Zed82
    Sep 28, 2017
    490
    Sweden
    Great stuff! Did you notice any improvement in the fuel consumption? I guess the feeling is night and day power wise?
  4. BruceC
    BruceC Karting
    249
    Tucson, AZ
    I can't say that I've noticed any impact on fuel consumption and to be honest, I've never actually checked fuel mileage. Living where I did up until recently, there weren't many places where you could really let loose easily unless you had utter disregard for traffic, cops, etc. but when I finally got lined up with a C7 Vette from our car club at a traffic light I couldn't hold back any longer. The power difference caught me by surprise hitting the rev limit much faster than I expected in 1st & 2nd. All around, very happy with the IPE sound & setup combined with the ECU tune.
    Zed82 likes this.
  5. freshmeat
    freshmeat F1 Veteran
    Aug 30, 2011
    7,257
    #5 freshmeat, Jun 9, 2020
    Thanks for posting more dynos on this topic. I never bought into the 4-2-1 is better for mid-range argument; if it's good enough to go racing with 4-1 on F1 cars, it's good enough for my car.
    Also worth emphasizing, 4-2-1 layouts produce a sound that carries a deeper tone (I liken it to muscle cars) and produces more gurgles at low rpm, but once the car hits the upper rev band both 4-2-1 and 4-1 layouts produces a sound that is marginally distinguishable, with a slight tip of the hat to the 4-1 for being higher pitched.
    Either way, the gains in emotion and laughter > actual performance.
    Zed82 likes this.
  6. hwyman
    hwyman Formula Junior
    Jun 25, 2015
    329
    Canada / Los Angeles
    Zed, might be worth getting the injectors sent in for a cleaning and inspection. Some of them could be leaking. Worth doing at this age anyway
    Zed82 likes this.
  7. Zed82
    Sep 28, 2017
    490
    Sweden
    Thanks. Actually the car became very thirsty when I changed the headers in the first place. I get around 11 mpg on a tank. Between 2-3000 RPM the car is considerably more frugal but above 3000 RPM I always get 10-11 mpg.
  8. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,645
    Silicon Valley
    LOL. That’s because when you drive, you’re always at 6k RPM or more!
  9. RichardCH
    RichardCH F1 Rookie
    4,661
  10. freshmeat
    Aug 30, 2011
    7,257
    Meh, it just sounds like that but I'm really under 4.5K
    Need4Spd likes this.
  11. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,641
    England
    Mark
    F430 - Stock
    Claimed data:
    Horsepower 490 Hp at 8500 rev/min
    Torque 465 Nm at 5250 rev/min
    Actual data:
    Horsepower 472.9 Hp at 8205 rev/min
    Torque 471.4 Nm at 5450 rev/min.
    F430 - Supersprint manifolds, cats, and rear section
    Supersprint:
    - Manifold 391301
    - Front exh.R. kat 391302
    - Front exh.L. kat 391322
    - Rear exhaust 391334
    - Endpipes Kit 391326
    Actual data:
    Horsepower 509.4 Hp at 8300 rev/min
    Torque 501.6 Nm at 5050 rev/min.
    F430 - Stock vs. Supersprint Full System
  12. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,641
    England
    Mark
    There are various things going on with the engine management to optimise torque including changes to the variable geometry inlet manifold, so swapping the manifolds ideally should be accompanied by a tune - not least because of the pre-cat removal - but there isn't anything wrong with a 4-1 manifold - in fact I think the power delivery much better suits the car.
  13. gatago
    gatago Karting
    Jun 28, 2019
    119
    Marco
    Very interesting thread!!!
    I've got a fabspeed header on my 05 430, no tune (although I think I might invest in one based off this discussion) but I will add that I can't feel any noticeable dip in hp/torque above as I accelerate up in a gear. Feels very linear.
    Also, unless cruising to work/grocery store, i.e. on spirited driving in the countryside, I operate in the 4.5-7.5 'ish range almost all the time. I don't track it so I have zero input there. But I naturally start my pulls out of corners around 5k. I don't have any formal training on tracks either, so I might be driving inefficiently, but instinctively that where I end up and feels like I'm getting the most of the car's performance.
  14. RichardCH
    RichardCH F1 Rookie
    4,661
    Mark I know you are the expert, but isnt the ECU supposed to learn to readjust to such changes, I know on my Boxster GTS when I got the original cat cores replaced by something more free flowing I was disappointed for the first 200 km but then suddenly everything changed after that (as I had been informed it would)
  15. RichardCH
    RichardCH F1 Rookie
    4,661
    #16 RichardCH, Jun 10, 2020
    fwiw my F430 Spider has Capristo 4-1 headers & actually a bench ECU tune (from 2008) from before I replaced the headers, it feels properly fast, throughout the whole rev range to the raised 8,800 rpm limit, strangely more so than my 430 Scuderia ever did, (noting that 430 Scud doesn't have cats in the headers, like the F430)
  16. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,641
    England
    Mark
    Quite right, Richard; there are adaptions for calibration such as fuel trim which are learnt over time and can be reset if required, however these are designed to allow for wear in the engine over time and different operating conditions/fuel grades rather than something more fundamental like removing the cat and changing the manifold flow characteristics.
  17. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,641
    England
    Mark
    P.S. careful with the raised rev limit. The F430 rods, bolts, and bearings are at their limit with the stock rev limit.
  18. RichardCH
    RichardCH F1 Rookie
    4,661
    #19 RichardCH, Jun 10, 2020
    well I did it 12 years ago .... and its only another 300 rpm... and its properly fast.. if fact the engine performance has never been this strong
  19. RichardCH
    RichardCH F1 Rookie
    4,661
    every manufacturer has a safely limit built-in which is usually at least 500 rpm
  20. RedTaxi
    RedTaxi F1 Rookie
    3,253
    New Zealand
    Glen
    And Nascar run 4-2-1 headers, high revs, go figure.
  21. ttforcefed
    ttforcefed F1 World Champ
    18,873
    normal super car guy just did a 430 video about ECU tuning fwiw
  22. Flea7
    Flea7 Formula 3
    1,904
    PNW
    SKIM
    You mean the guy who's F'ed up his car numerous times......one being catching his car on fire??? no thanks..:rolleyes:
    Mase Engineering would be my only choice for a tune. Steve at Mase supports the challenge series.
    For those who want peak performance in our engines, ...if you can..., take the silly cats out and put in a tune. Get an exhaust system that allows you to silence the catless exhaust with a valve system.
    nessus-gte, Dicecal and gatago like this.
  23. ttforcefed
    18,873
    Im going to have my 06 dynoed - it has capristo headers and capristo 200 cell hiflow cats. I may do the ecu and then will dyno again.
    JaguarXJ6 likes this.
  24. tazandjan
    38,054
    NASCAR engines have 90 degree cranks, Ferrari engines have 180 degree cranks. Apples and oranges.
    freshmeat likes this.
