365 BB Chassis 17553 Nut and Bolt Restoration | Page 18 | FerrariChat
Discussion in 'Boxers/TR/M' started by cnpapa24, May 11, 2019.
  1. 2008F430
    2008F430 Karting
    Apr 30, 2020
    106
    St Augustine
    It’s just incredible what can be done with a tremendous amount of time, work and money. Fascinating to watch the process. Keep it coming. You should make a book out of this when it’s done.
    Newman likes this.
  2. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,387
    The Cold North
    Tom
    Nobody can shine up your nuts like Paul can..;)
    As usual Paul's work speaks for itself. He is indeed one of the best out there. Proud to call him my friend.
  3. buzzm2005
    buzzm2005 Formula 3
    Aug 23, 2005
    1,734
    NYC
    Buzz
  4. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,155
    Canada
    Newman
    Original fuse blocks and different than the later cars, just cleaned up. Like any production car, corners get cut to keep costs down. These blocks are better than the later cars and clearly more expensive to produce.
    of2worlds likes this.
  5. Newman
    Dec 26, 2001
    14,155
    Canada
    Newman
    512 had core plugs in the rear hub carriers, these have a specific cover plate with slot head screws. And no I didn't have too much to drink when I painted the yellow marks on the one spring. I copied what was there originally. Maybe it was their first day on the job?
    Black happening next week
    Nice to see wheels on it. The engine will be in soon.
    Once I finish up the engine harness I'll run the crossover for the tanks and put in the engine bay side panels. Note heat exchanger near left fuel tank on early cars.
    Spring identification marks were randomly placed and ended up inside on the left suspension. Whoever put the springs on the shocks back then didn't worry about lining the marks up in any specific orientation so neither did I, its a production car after all.
  6. Edward 96GTS
    Edward 96GTS F1 Veteran
    9,302
    are you missing the yellow stencil on the gray cannister?
  7. Newman
    Dec 26, 2001
    14,155
    Canada
    Newman
    Not missing, just not on there yet.
    crinoid likes this.
  8. Newman
    Dec 26, 2001
    14,155
    Canada
    Newman
  9. Bertocchi
    Bertocchi Formula 3
    Jan 28, 2004
    2,182
    Austin, Texas
    David Castelhano
    Everything is beautifully done and finished.
    Newman and crinoid like this.
  10. ronc52
    ronc52 Karting
    Aug 25, 2010
    132
    Ron
    Sorry if you all ready posted the answer to this but have you located the seat material yet?
  11. Newman
    Dec 26, 2001
    14,155
    Canada
    Newman
    Its being made as we speak. Covid really threw a wrench into things. Closures and delay after delay but its finally at the sample stage.
  12. Newman
    Dec 26, 2001
    14,155
    Canada
    Newman
  13. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    8,931
    romano schwabel
    paul, you put the flansh on the diff right side for the shaft when the engine is inside? would be easier to do it as long as the engine is outside. you have a reason to do so?
    right side it looks like it is on?
    even when I enlarge I not see it right
  14. Newman
    Dec 26, 2001
    14,155
    Canada
    Newman
  15. buzzm2005
    buzzm2005 Formula 3
    Aug 23, 2005
    1,734
    NYC
    Buzz
  16. buzzm2005
    buzzm2005 Formula 3
    Aug 23, 2005
    1,734
    NYC
    Buzz
    Stop right there. Don’t put anything else on that engine.
    If you zoom in and take most of the engine bay out of the pic , it almost looks like a spacecraft I will try to photoshop same: create harsh contrast and dim out the background big time. The carbs are going to look amazing....
  17. Newman
    Dec 26, 2001
    14,155
    Canada
    Newman
  18. of2worlds
    of2worlds F1 World Champ
    16,474
    ON
    CH
    what is happening on the 'yello peril' since; May now? :(
    ronc52 and Grease Donkey like this.
  19. Newman
    Dec 26, 2001
    14,155
    Canada
    Newman
    Lots. I just need to update the thread which I'll do in the next few days. Sorry for the delay!
    Grease Donkey, spider_s and of2worlds like this.
  20. Newman
    Dec 26, 2001
    14,155
    Canada
    Newman
    First this happened on May 15th and I couldn't work.
    Then two weeks later after the swelling went down they changed the cast. I still couldn't walk but I could do this as long as my ride had no destination other than back home....
    So I lost a solid month then modified hours for another 4 weeks. 6 weeks in a cast and 2 more hobbling around after that. I walk with a limp for now and my foot doesn't approve of full days but Im so much better than I was even just two weeks ago.
    samsaprunoff and of2worlds like this.
  21. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,680
    Central NJ
    Dominick
    Feel better Paul ..take it easy .. you want it to heal properly
    Newman and samsaprunoff like this.
  22. of2worlds
    16,474
    ON
    CH
    Wow at least the roof didn't blow off, I hope! Take care of yourself and continue improving.
  23. George Vosburgh
    George Vosburgh F1 Rookie
    I hope all is healing correctly Paul!
  24. Newman
    Dec 26, 2001
    14,155
    Canada
    Newman
  25. Newman
    Dec 26, 2001
    14,155
    Canada
    Newman
    This is the only time you'll see these blower motors. I restored the originals and added my decals
    Front clam and bumper shortly.
    Doors finished, rear shelf, carpet done.
    Early tail light panel on left with rust holes, replacement to its right. No idea why they added the third hole as the inboard light is a reflector without a concave reflector housing needing no clearance. Can't get the correct ones so I made what I needed.
